Spotted in the wild: x88 King x922
Agree the whole firmware stinks if by middle of Dec there is no firmware upgrade I will probably send it back to Amazon for a full refund - since its basically a dead weight right now. My old android 4 box can play more apps than it currently can.
The one thing I did find out it can do is play Disney Plus through Chrome - although if you use any other browser it fails - im supposing you can do the same with Amazon prime and Netflix - but having to open a browser to get to these services doesn't make a lot of sense.
Again it comes with a version of kodi - but you have to do a trick with the calculator to get it to self install - find that rather strange.
Originally posted by greenstone View PostAgree the whole firmware stinks if by middle of Dec there is no firmware upgrade I will probably send it back to Amazon for a full refund - since its basically a dead weight right now.? My old android 4 box can play more apps than it currently can.
darkstar with Amlogic and Android PIE none of the standard ways to root a device will work using TWRP. Everything has to be done manually, either you decompile the stock firmware .IMG and manually insert the required root binaries into .IMG and then burn the .IMG file with PC, or you have to manually do a bunch of commands through adb to pull, edit, and then push the required root files into place.
Originally posted by RiCkLaR_atvX View Postdarkstar with Amlogic and Android PIE none of the standard ways to root a device will work using TWRP. Everything has to be done manually, either you decompile the stock firmware .IMG and manually insert the required root binaries into .IMG and then burn the .IMG file with PC, or you have to manually do a bunch of commands through adb to pull, edit, and then push the required root files into place.
I tried reapplying the firmware using the burning tool, worked however same issues. No Amazon prime, no disney plus, no world of tanks or hearthstone, no angry birds list goes on and on... Security issue with the box still exists as well. No firmware upgrade available so far.
Going to give it two more weeks if this box still doesn't get an update will return it to Amazon.
Originally posted by ClarkKent View PostNot sure you'all would be okay without L1 widevine, but I think the Ugoos am6 Would Be... money far Better Spent.
~ just say'n.
~ just say'n
Best money spent is on a device with S922X is the Odroid-N2, can flash a LineageOS firmware and then it is Android heaven for your TV, and of course CoreELEC has firmware especially made for the N2 if you'd rather have the best Kodi software for an Amlogic chipset. $80 Kit (not counting shipping/taxes) for the Odroid-N2/CoreELEC with 4GB ram.
~ just say'n
I haven't heard a complaint, yet, from a N2 owner...granted!
There are currently 1543 users online. 0 members and 1543 guests.
