Spotted in the wild: x88 King x922
raruba Yeah the autoupdate went through - I also reset the box - clearing cache and param - still have the same software issues. Many apps from the app store do not work and still have the security issue with the version of android 9. I was unable to find the ability to turn on root or anything specific that they may have changed. I am betting they just tweaked some settings to get a higher antutu score. Supposedly another update is coming in 7 days but I am really in doubt as to if they will fix anything with it.
Also the launcher sucks can't put your own background or anything so I am using squarehome3 which gives it a much nicer look and lets me put a background without any trouble. Also gives you easy access to the open recent apps command so it makes it easier overall.
Originally posted by greenstone View Postraruba Yeah the autoupdate went through - I also reset the box - clearing cache and param - still have the same software issues. Many apps from the app store do not work and still have the security issue with the version of android 9. I was unable to find the ability to turn on root or anything specific that they may have changed. I am betting they just tweaked some settings to get a higher antutu score. Supposedly another update is coming in 7 days but I am really in doubt as to if they will fix anything with it.
raruba Hmm I turned on root so I can use fdroid apps dns66 and adaway - which makes it nicer for me - however I still can't install amazon prime or disney plus from the app store - not mention hearthstone, world of tanks, angry birds - are you having the same problem?? Can you check?? Since I am wondering now if its only my box doing this.
I was able to install aida64 however I can't even install the antutu benchmark from the playstore and you have that running... I will have to look for the lucky patcher as you said.Last edited by greenstone; 10 December 2019, 11:48.
Originally posted by greenstone View Postraruba Hmm I turned on root so I can use fdroid apps dns66 and adaway - which makes it nicer for me - however I still can't install amazon prime or disney plus from the app store - not mention hearthstone, world of tanks, angry birds - are you having the same problem?? Can you check?? Since I am wondering now if its only my box doing this.
raruba Tried to use the luckypatcher to replace the play store but it wouldnt work - according to the app you should uninstall the playstore first then install a modded one - that just caused me to have to reset the box completely. (playstore is not easy to remove and replace it seems.) Anyway I will probably just wait for the next patch to get it working since the patcher is not working out for me.
Originally posted by greenstone View Postraruba Tried to use the luckypatcher to replace the play store but it wouldnt work - according to the app you should uninstall the playstore first then install a modded one - that just caused me to have to reset the box completely. (playstore is not easy to remove and replace it seems.) Anyway I will probably just wait for the next patch to get it working since the patcher is not working out for me.
raruba Thanks I was able to get the newest version installed - makes it a bit easier to deal with - however the app problem still persists - many games and apps are unable to install to this version of the OS. For example Hearthstone, World of Tanks, Angry Birds so on don't come up in the playstore. I am going to try and side load some - already tried installing a apk or two like disney + and amazon prime but they failed to run.
Originally posted by greenstone View Postraruba Thanks I was able to get the newest version installed - makes it a bit easier to deal with - however the app problem still persists - many games and apps are unable to install to this version of the OS. For example Hearthstone, World of Tanks, Angry Birds so on don't come up in the playstore. I am going to try and side load some - already tried installing a apk or two like disney + and amazon prime but they failed to run.
Seems to be really fast and the picture quality so far is great.
I wasn't able to get Disney+ installed since its not coming up in the app store - lots of apps aren't like I said.
So after some trial and error found a method for Disney+:
Basically once you install it, if it works,you probably won't have audio you need to go into your sound preferences and turn off auto and select all the codecs.
I am not working on the games seeing how I can get them working.
(I am still wondering why we have to go through a split file to get disney+ to work rather than a single backup apk.)
From what I am researching I would have to edit the build.prop (with root turned on) - back it up and reboot to get google play store to store saying incompatible files.
Problem is making the changes to the build.prop so that it will accept it as a device that works. So far I have been considering what changes to make.
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=PPR1.180610.011
ro.build.display.id=galilei-userdebug 9 PPR1.180610.011 20191207 test-keys
ro.build.version.incremental=20191207
ro.build.version.sdk=28
ro.build.version.preview_sdk=0
ro.build.version.codename=REL
ro.build.version.all_codenames=REL
ro.build.version.release=9
ro.build.version.security_patch=2018-08-05
ro.build.version.base_os=
ro.build.version.min_supported_target_sdk=17
ro.build.date=Sat Dec 7 09:43:48 CST 2019
ro.build.date.utc=1575683028
ro.build.type=userdebug
ro.build.user=foxluo
ro.build.host=hugsun
ro.build.tags=test-keys
ro.build.flavor=galilei-userdebug
ro.build.system_root_image=true
ro.product.model=X88King
ro.product.brand=Amlogic
ro.product.name=galilei
ro.product.device=galilei
# ro.product.cpu.abi and ro.product.cpu.abi2 are obsolete,
# use ro.product.cpu.abilist instead.
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.cpu.abilist=armeabi-v7a,armeabi
ro.product.cpu.abilist32=armeabi-v7a,armeabi
ro.product.cpu.abilist64=
ro.product.manufacturer=Amlogic
ro.product.locale=en-US
ro.wifi.channels=
# ro.build.product is obsolete; use ro.product.device
ro.build.product=galilei
# Do not try to parse description, fingerprint, or thumbprint
ro.build.description=galilei-userdebug 9 PPR1.180610.011 20191207 test-keys
ro.build.fingerprint=Amlogic/galilei/galilei:9/PPR1.180610.011/20191207:userdebug/test-keys
ro.build.characteristics=mbx,nosdcard
# end build properties
# ADDITIONAL_BUILD_PROPERTIES
ro.bionic.ld.warning=1
ro.art.hiddenapi.warning=1
ro.treble.enabled=true
persist.sys.dalvik.vm.lib.2=libart.so
dalvik.vm.isa.arm.variant=cortex-a9
dalvik.vm.isa.arm.features=default
dalvik.vm.lockprof.threshold=500
net.bt.name=Android
dalvik.vm.stack-trace-dir=/data/anr
ro.build.expect.bootloader=01.01.180822.152145
# begin fota properties
ro.fota.platform=S922X
ro.fota.type=box
ro.fota.oem=x88king
ro.fota.device=x88king
ro.fota.version=X88King_20191207-1003
# end fota properties
ro.expect.recovery_id=0x811716e3d7287246acbcf21694 143e8212a9c5e0000000000000000000000000
I am working on the build.prop to see if I can change it so it is recognized by the google play store. So far haven't been able to fix it. Was wondering if gt-king and ugoos am6 is having this problem and if not could we get a copy of their build.prop and use it to temporarily give us full access to the google playstore.
I also responded to the vendor who e-mailed me with some updated info about the firmware change and how to box is responding hopefully they will pass it on to the manufacturer.
Sent them screenshots of the DRM INFO and the security issue with android (not having the latest patches).
There are currently 2797 users online. 0 members and 2797 guests.
