Spotted in the wild: x88 King x922
    Originally posted by Juasser View Post
    raruba, would be possible patch boot.img from original x88 to ALVATECH rom, or this is a crazy idea?
    Its a great ROM, I'm using it on my Beelink GT-King....works great.
      I was trying [ROM] Beelink GT-King ALVATECH Standard Android (9.0 Pie) S922X and seems that the only thing that dont works are the usb. I'd tried and Lan, wifi, bt, Ir... and all works, storage show 128Gb too. Would be wonderful if someone can make a patch to make usb works. I downladed an app from play store to see usb devices and seems that both are reconogised but no input or storage devices work. I post the log.
      Device Info
      Device Path: /sys/bus/usb/devices/usb1/
      Device Class: USB Hub (0x9)
      Vendor ID: 1d6b
      Vendor Name (reported): Linux 4.9.113 xhci-hcd
      Vendor Name (from DB): Linux Foundation
      Product ID: 0002
      Product Name (reported): xHCI Host Controller
      Product Name (from DB): not found
      Additional Info
      USB Version: 2.00
      Speed: 480
      Protocol: 01
      Maximum Power: 0mA
      Serial Number: xhci-hcd.0.auto
      Device Info
      Device Path: /sys/bus/usb/devices/usb2/
      Vendor ID: 1d6b
      Product ID: 0003
      Additional Info
      USB Version: 3.00
      Speed: 5000
      Protocol: 03
      Maximum Power: 0mA
      Thanks in advance
      Did you try going into Developer settngs and turning USB Debug on and off and checking the USB ports? I have had USB not work before, and that solved the problem.
        Juasser I wouldn't mind seeing the gt-king install, I tried and my box got stuck at the bootloader I probably grabbed the wrong rom. I keep looking at what ugoos has done for its box and more and more I am thinking about sending the x88 king back as the vendor gave me the ability to do so.
          greenstone I also feel disappointed with the software but I think it is a good hardware. I want it for more things than multimedia, such as home automation bridge and the features fit what I need. Also the price is very good. I have installed the rom that I put up and the original of the king pro and without problem, except the USB that I keep trying to make them work and remote. If you flash do not check the bootloader option. To use the infrared I use the application of my xiaomi A2 and look for the remote control of the minix, Then I already set up a bluetooth controller to move through the menus
            Has anybody tried the app 'USB Host Controler' to see if they can mount devices? Or has anybody tried to switch the USB mode? There are apps that will let you switch USB modes like MPT mode etc.
              Porkie You can turn on developer options in most of these builds and mess with the USB but you need a way to control the box if your mouse/controller is usb connected I think you cant do anything - not sure if I have a controller that will work so I haven't done the firmware again.
                I see Chinagadget's has post the X88 King Firmware(https://chinagadgetsreviews.com/?s=x88+king) that's a start. Hopefully someone can download it and modify it
                  But you can navigate. I was not asking about deveoper sett, I was asking if anyone had tried specific apps to see what would happen. I personaly do not think it can be fixed within the software, cause the device USB ports are not the same as the GT Kings, but that still does not mean I cannot suggest things to try. I think the fix is simple find someone to port the rom, but in the mean time does not hurt to try things. I am confused why nobody has made a thread asking for a developer to make a rom instead of lookin for help for something that likely cannot be fixed with porting the rom. I guess I will cut through the nonsense and simply make the thread myself
                    Great, thats what we need.....I'm with you to ask developer.
                      I have nothing either to control this box with the GT-King firmware.
                        raruba Porkie
                        - Turn on/off debug usb or apps dont work.
                        - I have managed to control the device with the infrared of the mobile and then accessing the bluetooth, can turn on and search for a bluetooth control
                        - The device recognizes usb, but fails to connect anything. with a dmesg it shows me this error "usb1 connect-debounce failed"
                        - In the specific forum of the rom I already asked if anyone could solve it, but it was clarified that this forum was specific to the GTKing
                        - I'm with you to ask developer too
                          Juasser I did a google search for that error regarding the android OS and they suggested turning on and off the USB in bios but since we cant do that I am supposing there is a USB module or something that can be replaced in the OS - I have no idea how to do this but I have tried to expand the alvatech rom and the original firmware and compare not sure what I am looking for other than stuff called USB. I have no idea how to replace it however if I do find something. Just keeping busy I guess.
                            Hello,
                            i don't understand Russian because i'm French but the fantastic Sasvlad hat built this Rom for the x88 king!!!!!
                            Friendly teddy ??????
                              tedeg Where did you find this? Thanks.
                                Ok I found it: https://translate.googleusercontent....YgtPGu2weXSyqQ
                                As a New Year's gift for all lovers of my opus!
                                X88King VolksWare by Sasvlad v.1.0
                                Thanks to the user gentenaar for the box provided to me, without it this firmware would not have existed.
                                The main changes in the firmware (I will not list everything - the page is not enough):
                                • fresh su binary installed
                                • installed patched SuperSu 2.82, which does not require updating
                                • removed the ancient chinese busybox and installed fresh
                                • USB debugging enabled by default, full AdbShell support, disabled Selinux
                                • UI animation speed set to 0.5
                                • Noise Canceled
                                • tcp buffer tweak for slow internet
                                • Auto Frame Rate (afrd) service management software installed
                                • translated launcher Lighthome into Russian
                                • replaced the central buttons of the launcher with the most commonly used
                                • Russified DroidTVSettings
                                • I rewrote the frameworks and the system interface so that a normal curtain with notifications and navbar appears
                                • autocover curtains and navigation bar
                                • fixed reboots when watching IPTV (they can still happen, it depends on broken streams. But much less often)
                                • Chromecut screensavers with cut ads
                                • added a saver control section in the side settings
                                • Android TV Remote service is installed to control boxing from a smartphone. You need to install Android TV Remote Control on your phone
                                • two voice searches of your choice (standard and AndroidTV, see screenshots)
                                • the firmware is cleaned of unnecessary files and garbage
                                • Built-in advanced TWRP recovery 3.2.3-1 with additional features for backup
                                • the default language is Russian and Central European time GMT + 2
                                • 13 WiFi channels
                                The following applications have been added:
                                • ES Explorer
                                • HD Videobox Pro
                                • power-menu to enter TWRP
                                • Smart YouTube
                                Known bugs:
                                • LAN works poorly (at least WiFi works for me without problems)
                                • The clock on the front panel does not work. This is a fee for a working curtain with a navbar. It is possible to write firmware with a clock, but without bars. I thought that for AOSP bars are more important. If it comes to firmware Android TV on the subject - there the bars are not so important, you can return the watch.
