Spotted in the wild: x88 King x922
Originally posted by greenstone View Post
Test was done with the original software from manufacturer after the firmware upgrades. I did make some changes to the build.prop but those are mostly small tweaks that wouldn't really effect the results.
What I would like to get is a way to get playstore working properly - I tried spoofing it but like I have read but that didnt seem to work for me, and using magisk in recovery mode seems tedious not sure if it would even fix the problem. So workaround seem to be the best solutions.
As far as Antutu 8.1.1 - I got the software from upanddown appstore - I got aida64 from google playstore.
I upgraded kodi by using the preinstalled version 8.1 (pie 318), then going to kodi.tv and downloading the newest one.
The amazon appstore you can get directly through e-mail from amazon by "purchasing" it but its free. They send you an e-mail with the link.
This is the upanddown appstore link: https://en.uptodown.com/android
You can also get aptoide, and fdroid appstores.Last edited by greenstone; 03 January 2020, 13:06.
Originally posted by greenstone View PostNothing new yet but I did find a link to the most recent stock firmware that someone got on a russian forum.
https://dropmefiles.com/mKSwa
Originally posted by greenstone View PostWhat I would like to get is a way to get playstore working properly - I tried spoofing it but like I have read but that didnt seem to work for me, and using magisk in recovery mode seems tedious not sure if it would even fix the problem. So workaround seem to be the best solutions.
Originally posted by raruba View Post
I tried AnTuTu 8.2 and it says box is not compatible. Thats on the 12/11/2019 firmware. By the way its running real good with this firmware.
Originally posted by Porkie View Post
I got 123'000, but like I said, the box only seems good for emulators at the moment. I mostly use my android boxes for streaming, but this box would be perfect for playing retro games all the way up to the PSP.
I have not really used the box at all. I turned it on updated it, fixed a couple minor things, ran antutu, ran a couple apps just to see what the performance would be, and maybe had it on for a total of 2 hours. I realized it would just be a headache ring to use the box, so I will just wait till a sable ROM or firmware comes along before I use it. Hopefully the issues get worked out.
I am using the stock updated rom - the biggest problem I have is the play store not being certified - then not having a status or notification bar - I tried the russian rom but it had too many problems so I went back to the original which runs fine but has the above issues.
So far I can stream fine I have:disney+, hbo go, showtime go, kodi, #animania, amazon prime video, hulu, and a bunch of other smaller streaming apps tubi, xumo,so on, I can make a full list if anyone wants it.
(I haven't used IPTV but lots of people say the same thing that it causes the box to reboot after a while..)
Games however I haven't found anything that I really want to play - I can play hearthstone and lots of card games without issues - but driving games and the like I don't have a android controller that works well yet so haven't really played anything.
I will try and get the antutu 8.2.2 see if I can get a score.
I did make changes to the build.prop but only stuff I have seen on the forums that actually might work.
I tried to use the Amlogic Customization tool to unpack a few roms and do comparisons between them but I can not find the Customization tool/unpacker that doesn't give errors for android 9 pie - so for example if I unpack alvatech's rom it gives me an error when I do it - same for the official rom for x88 king - I can see the files but due to the error I can not repack if I try to modify something. Which sucks.
Originally posted by greenstone View PostI tried to use the Amlogic Customization tool to unpack a few roms and do comparisons between them but I can not find the Customization tool/unpacker that doesn't give errors for android 9 pie - so for example if I unpack alvatech's rom it gives me an error when I do it - same for the official rom for x88 king - I can see the files but due to the error I can not repack if I try to modify something. Which sucks.
Just seen a new s922x box called the Magicsee N6 Plus, and it also as 128GB of storage. I am willing to bet the firmware is interchangable, but will still have the same exact problems that the X88 King has. The good part is if the firmware is interchagable and the source gets released for the N6 Plus we wil be able to fix our device based on the changes done to that device. A lot of these boxes use interchangable firmware, so lets hope the firmware for the N6 Plus intechanges with the X88 King.
There are currently 1804 users online. 1 members and 1803 guests.
