[ROM] Beelink GT1-Mini ALVATECH Android TV - ATV (9.0 Pie) S905X2
I have GT1 mini with B95X serial.
I use this ROM to upgrade my device.
every steps goes well and I received Successful for upgrade.
when I attach my device to TV the light turns but no have signal.
After 40 min, I have signal and config my device and update it, But after shutting down the device and turning up, TV does not have signal and the signal is back in about 40 min.
I downgrade my device to Android 8.1 original and it works well.
I tried original android 9 ROMs and all related in forum but I still couldn't handle it.
1- any one have any idea about it?
2- I cant find Android TV 8.1 ROM, any one can help me?
Regards,
"Very Important! If you use this ROM on a GTMini-A box, when flashing your box either by USB or SD-Card NEVER use the option Force Erase All only use the Normal Erase option or you will lose DRM Widevine L1."
I installed the rom on version "DDR4_GT1-Mini-A_116N0_20190604" which has Widevine L1 None of the options in usb burning tools keep Widevine L1
* Normal erase
* Erase all
and
* Disabled erase flash does not keep Widevine L1....
There are currently 1251 users online. 0 members and 1251 guests.
