Would you mind entertaining helping me in private to see some suggestions on trying to get my box back to 7.x or 8.x so I can use Magisk? I'm thinking it's bootloader-related, but I'm not positive. Unfortunately I don't have a good flashable image to get back to 'stock', just some TWRP backups.
[ROM] Beelink GT1-Mini ALVATECH Android TV - ATV (9.0 Pie) S905X2
Because you don't have an original ROM image this would make it difficult to try to get you back on an older Android OS.The best thing I can tell you is to try get more info online about your box and or post a new thread about your box and see if anyone else knows of an image that works for that box. If not you would need to take a risk and keep trying to flash different ROM's until you find one that works for you.
Thank you,
Alvatech
great rom! i like it! works well with my T95Q v1.
Google voice assistant working ok with my G10 air mouse.
hdmi cec working.
wifi and ethernet working.
ipega bluetooth gamepad working with navigation and games netflix sd working
youtube 4k working
kodi working
power on/off working with g10 air mouse
better if rom have, but not required:
Miracast
Aptoide TV
stock ir remote not working. i tried the remote config fix from other rom but did not work. please advise how to import other remote config from other roms. other than copying the config to vendor/etc and update permission what else to do? do i need to update a master config that says i have imported this config? i noticed that there are multiple remote.* files in the folder. does the system load all this files in memory?
Great ROM Alvatech! I'm glad I loaded it up on my GT1 mini SN:95X2. I tend to try all the new ROMs and this is the best so far. The video detail is way better in Cody and other related APKs. So I had a quick and possibly dumb question for anyone here.The stock remote for the GT1 mini works perfect. I bought an aftermarket Wechip 2.4ghz remote with USB plug antenna. It was working just fine with the 115NO Android 8.1 stock firmware. The back button doesn't respond on any of the Android 9.0 Firmware ROMs. Is there a way to get the back button to work properly on this ATV 9.0? I tried to use the IR learning function of the Wechip remote. No dice....the back button still wont respond. Any help in the right direction would be greatly appreciated.
Originally posted by majdi qurony View PostGreat job, tasted on T95Q works perfect.?
Alvatech
Originally posted by raptur3d View Postgreat rom! i like it! works well with my T95Q v1.
hdmi cec working.
youtube 4k working
kodi working
Miracast
Aptoide TV
You can take a look at one of my other threads where another user mentions a patch for the remote to work with your type of box. I'll post link down below.
I don't own that type of box so I wouldn't be able to test it.
Thank you,
Alvatech
Link:
This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original GT1-Mini Please read the entire first post before asking questions. Thank you. (There has been some hardware variants so please read carefully.) Best thing to do before flashing your box is to check which Serial Number you
Originally posted by NocturnalE View PostGreat ROM Alvatech! I'm glad I loaded it up on my GT1 mini SN:95X2. I tend to try all the new ROMs and this is the best so far. The video detail is way better in Cody and other related APKs. So I had a quick and possibly dumb question for anyone here.The stock remote for the GT1 mini works perfect. I bought an aftermarket Wechip 2.4ghz remote with USB plug antenna. It was working just fine with the 115NO Android 8.1 stock firmware. The back button doesn't respond on any of the Android 9.0 Firmware ROMs. Is there a way to get the back button to work properly on this ATV 9.0? I tried to use the IR learning function of the Wechip remote. No dice....the back button still wont respond. Any help in the right direction would be greatly appreciated.
I'm glad you're enjoying it. I will post some links down below that might be able to help you. Since I don't have that remote it's hard for me to help troubleshoot it without the remote in hand.
Here are the links down below.
Thank you,
Alvatech
Links:
Hello, after plenty of research and be able to finally download the KeyTest.apk app i succesfully remapped few buttons of my Hausbell mini H7 remote with Touchpad
Originally posted by andrei56 View PostОтличный ROM Alvatech!
Все работает. Спасибо.
Alvatech
Originally posted by Cristhian.ilian.10 View PostComo puedo poner TWRP recovery, al n5 max 4gb 64gb al firmaware stock???
I don't own the box you're referring to. You can try some of the links down below or ask on the appropriate thread.
Thank you,
Alvatech
Links:
https://forum.freaktab.com/forum/tv-...mlogic-devices
https://forum.freaktab.com/forum/tv-...2-u211-devices
Originally posted by atlakeem View Postdoes this rom have the app to where i can add more shortcuts to the homescreen? some downloaded apks wont show up by default. also, does ES file explorer work with this version of atv?
a lot of this stuff can be added after you install the ROM. You might try installing Aptoide TV to install additional apps needed. This will help you sideload other apps that are not normally in the Google Play Store.
Thank you,
Alvatech
There are currently 4578 users online. 0 members and 4578 guests.
