[ROM] Beelink GT1-Mini ALVATECH Android TV - ATV (9.0 Pie) S905X2
Originally posted by Yodabacsi View PostHello Everyone.
I am new here. I just bought an Beelink GTmini-A TV box.
Unfortunately I made a mistake, and downgrade the softver to original GT1 mini (via SD card).
The main issue, I can not connect via USB the device to my laptop (win10). With SD card I tried to do create image with Burncard maker, but the Box not recognize the image.
Can you please help, what should I do, to update my little jewel?
Thank you for your understanding and support guys!
I would try to format the SD-Card again and then if not try another USB M-M cable or even try another computer. Sometimes these boxes are very picky when it comes to getting them flashed.
Also, I would be trying to flash stock ROM first if you're having problems then try another ROM if interested and you get things working.
Thank you,
Alvatech
Originally posted by vitaly.ivanoff View PostHi people!
Please tell me, is there support int.d on this firmware and how to enable noise reduction?
Thanks!
I do not have init.d support on this ROM. But the box is rooted by default so if you search the web you should be able to find a solution to your needs. I do not provide this type of support sorry.
Thank you,
Alvatech
Thank you,
Alvatech
Hello everyone,
sorry I've been absent lately. I have been working on a huge project and had to prioritize. I've also been doing a lot of different lifestyle changes lately, so still adjusting to that and trying to be productive at the same time. I haven't had much time to respond to different users and I apologize for that. I will see if time permits for me to make updates for these different boxes. But as of right now at the moment I still haven't had much free time. I hope things change for the better. Stay safe and healthy!
Thanks for understanding,
Alvatech
Originally posted by ALVATECH View Post[ROM] Beelink GT1-Mini ALVATECH Android TV - ATV (9.0 Pie) S905X2
Download ROM for SN:905X2 or SN:95X2:
GT1_MINI_AT_V2.0A_ATV9
try to update to this pie ATV from your 8.1 ATV using sdcard method, but it keep going to team win recovery after the android logo apear for a brief second. Please help me. Im using exactly the same method when im updating to your Oreo 8.1 ATV, the box keep going into teamwin recovery. Help. And i dont have a USB cable, i need to do it with sdcar method.
hello .
anyone use this rom in 4K? Do you have black screen blinking issues when playing video files? I explained my problem here:https://forum.freaktab.com/forum/tv-...very-5-seconds
thanks.
thanks.
Originally posted by RiCkLaR_atvX View Post
Don't use stock firmware, only use ALVATECH firmware ROM!
Originally posted by sakusyn View Posttry to update to this pie ATV from your 8.1 ATV using sdcard method, but it keep going to team win recovery after the android logo apear for a brief second. Please help me. Im using exactly the same method when im updating to your Oreo 8.1 ATV, the box keep going into teamwin recovery. Help. And i dont have a USB cable, i need to do it with sdcar method.
I would try to format the SD-Card with the tool and also make sure it's a compatible size to work with this box. Some people use really big size SD-Cards and the system doesn't recognize it for flashing. Also could be it needs to be formatted, but make sure you backup the SD-Card if there is anything important on it.
Thank you,
Alvatech
There are currently 1889 users online. 0 members and 1889 guests.
