Hello and thank you for your work but a question that works on x96 max 4/32 ddr4 s905x2 thank you for your answer.
[ROM] Beelink GT1-Mini ALVATECH Android TV - ATV (9.0 Pie) S905X2
Thanks for the firmware. My TV Box is TR99 2g16g, it does not recognize the wifi card or lan. I include 2 files that have the drivers. One is in Linux and the other is an addon that I use in libreelec. thanks for your
Remember guys!!
I can't make all of your different boxes work without the box physically in hand. It's very difficult to test all the different hardware and scenarios out there and make everything work with just one ROM. It's difficult to make custom ROM's without the box in hand period. So please understand you're using this ROM at your own risk and it is made for Beelink's GT1-Mini. I never mentioned that it is made for any other boxes. If you decide to use it for your box it may or may not work properly. It's your decision if you're happy with the results since you're using it for another box other than Beelink's GT1-Mini.
Thank you,
Alvatech
Originally posted by bergie2222 View PostHello and thank you for your work but a question that works on x96 max 4/32 ddr4 s905x2 thank you for your answer.
I don't own this box, so I can't answer that question. Sorry.
Thank you,
Alvatech
Originally posted by swdave View PostHow do I get recovery? It never works after flashing this rom.
I have no problem getting into recovery. If you're using this ROM for another box that is not a Beelink GT-Mini than more than likely it's not compatible for your box.
Thank you,
Alvatech
Originally posted by Vanto View PostAlvatech, awesome creation! Thanks a lot ...
... but having some issues here!
1. Remote is working only for switching OFF the box. In order to turn it ON, I have to disconnect the power cable or leave it on until I use my T95Q again.
2. What kind of root does your ROMs use? Is it Chainfire's SuperSU or is it Magisk (which I doubt) and how to change them!?
A)l the best and ...
Keep 'em coming (new ROMs)
Sent from my SM-G955F using Tapatalk
Thank you,
Alvatech
Originally posted by basheer12 View PostI have t95z tv box with 2/16 ddr3 is this rom work for my box
I don't own a T95Z box, so it's difficult to test things and troubleshoot anything without the box physically in hand. Maybe someone else who's tested this on that type of box can answer.
Thank you,
Alvatech
Hello,
I don't own that type of box, so it's difficult to test things and troubleshoot anything without the box physically in hand.
Thank you,
Alvatech
Originally posted by MaxX96 View PostHello. On X96 Max S905X2 watch work? Sleep-mode work like wake_lock? Noice reduction it's enabled or disabled?
Thank you.
I don't own that type of box, so it's difficult to test things, troubleshoot and create ROM's for these boxes without the box physically in hand.
Thank you,
Alvatech
I appreciate your attention. I was thinking and you correct me. Is it possible to put my firmware kernel in a zip file, next to the Wifi / Lan driver file? So you would not have to reconfigure a new firmware? Thank you
My fiemware, https://mega.nz/#!bFQwjA5Z!A53iRMCtp...UW_A2af9I99ZuI
Originally posted by teresa View Post
sorry but i can not understanding? with libreelec??? i try to reflash oreo and working but this pie img not working for me
Originally posted by teresa View PostHi alvatech, I am trying to update from your interior rom to this. But I don't get it. I am using the sd method, but when I restart the device by pressing the lower button I just get into twrp, it doesn't do the installation like other times, what am I doing wrong?
If you're trying to use the SD-Card method you need to make sure the card is formatted and made properly. Try to use the format option that the SD-Card application offers and then try to re-make the SD-Card again. Once you have it made then you should be able to hold the reset button on the bottom of the box and then plug in the power cord, keeping the reset button held in until you see an Android logo with a progress bar at the bottom, then you can let go of the reset button. Keep trying if it doesn't work try another SD-Card or try the USB Burning Tool method.
Thank you,
Alvatech
Thanks for this ROM. It's one of the few that I seem to be able to successfully USB-burn onto my YAGALA K92 (S905X2) Android TV box.
May I ask if it's possible to get Magisk to pass SafetyNet on this ROM? I saw your guide on the 8.1 ROM, but I can't get the 8.1 ROM to flash successfully for some reason.
Originally posted by andrei56 View PostHello. Your firmware is based on what firmware Beelink GT1 Mini (004P0)?
yes this is based off of the latest Beelink ROM at the time of writing.
Thank you,
Alvatech
Originally posted by alessa View PostHello. the rom is based on which version of Android 9? The last (004P0)?
Originally posted by ScrawnyB View PostThanks for this ROM. It's one of the few that I seem to be able to successfully USB-burn onto my YAGALA K92 (S905X2) Android TV box.
Magisk is not working at the moment with these type of ROM's with Android 9. From what I heard last is, that they are aware of it but don't know the status. My suggestion would be, is to try and ask on the XDA forum on the appropriate Magisk thread for some more answers if needed. Glad the ROM is working for your box. That's weird that the 8.1 won't work but the 9 version will.
Thank you,
Alvatech
There are currently 1966 users online. 0 members and 1966 guests.
