CoreElec / LibreElec builds for GT1 Mini 2 S905X3 ?
As it is an enclosed Unit with small vent underneath and heat does rise i would get warm
If you live in a warm tropical Climate then it may cause some issues and if you are streaming a lot then keep it cool would be cool
Stand it on its edge with a small fan blowing thru vents may help run off usb port
Or pop the top drill some holes sit a fan on top (messy) but doable lots of ideas around to keep a hot box cool
look at the images here
https://forum.freaktab.com/forum/tv-...112#post788112
Remove the tin lid covering CPU
Use a large thermal pad between the CPU and metal Block on Plastic lid would improve things not us tin lid.
Of course do at your own risk
Originally posted by trebor View PostAs it is an enclosed Unit with small vent underneath and heat does rise i would get warm
Originally posted by mctiew View Post
Does it combination of CoreElec and Netflix plugin depends at all on the widevide level ? My understanding is that Tanix s905x3 is widevide level 3.
It does NOT depend on Widevine levels.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I am doing dual boot android and CoreElec now. But when I am in Android ( stock ROM), long press power button to choose reboot actually reboot back to CoreElec. How to avoid that ?
I already installed "reboot to LibreElec", so I want to reserve a way to reboot back into Android, from Android.
Originally posted by mctiew View PostI am doing dual boot android and CoreElec now. But when I am in Android ( stock ROM), long press power button to choose reboot actually reboot back to CoreElec. How to avoid that ?
CoreELEC give you many options, including reboot or reboot to internal nand......MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I have not found a solution to that problem either. When you re-boot, it boots from the microSD card. It would be nice to have an option.
This will make it possible one to choose a boot by the grub style menu.
Originally posted by fixide View PostHi,
Tried coreelec on my new beelink gt1 mini2. It's my first installation. Unfortunately with nightly don't work. I have the sdcard in , i do reset, i have the beelink logo and after nothing... Black screen.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1304 users online. 1 members and 1303 guests.
