CoreElec / LibreElec builds for GT1 Mini 2 S905X3 ?
    sogoku_vn . Wrxtasy from the Kodi forum, has posted an ssh command to increase the speed of the GPU. It may help. It is easy to do, using Putty to access your box. Here is what he posted.
    " For some reason GPU Max clocking has been removed in CoreELEC 9.2.x
    To crank it up to 792MHz, from memory...
    echo "echo 2 > /sys/class/mpgpu/scale_mode" >> /storage/.config/autostart.sh
    A faster microSDHC also helps like the the Samsung EVO ones, but nothing is as fast an eMMC storage."
    You may want to post on that link and see what Wrxtasy has to say.
      How did you get the different information screen?? Did you change skin?
      Did you test you box with Alda64 and cpuz to find out if your box truly has a S905X3 SoC??
      Also, the Amlogic S905X2 will software decode Netflix in 720p, but NOT 1080p, that makes me wonder if they sold you a S905X2 and said it was an X3............. Maybe open the box and look at the CPU (SoC).
      Another thought, go to the CoreELEC forum and ask if there is a ssh command that will tell you what the CPU actually is...... You can use Putty to access your box with the ssh command..
      Which part of Alda64 will tell us the actual CPU model ? I only see for mybox 4xArm cortex-A55 @ 1908 MHz, rev r1p0.
        You are correct, I misspoke.
          I teardown my box, It is S905X3 with SAMSUNG DDR3L K4B2G0446D. I overclock GPU speed by ssh command but nothing change, still CPU 100% and not smooth when many fight scenes. S905X3 has 4xA55 so Aida64 is true cortex-A55 @ 1908 MHz while S905X2 has 4xA53
            Then I have no clue why the Beelink plays in 1080p perfectly, but not yours.......... I thought the CPU was what gave it the power to software decode the 1080 stream.....
            Also, does while under CoreELEC and go to system information, hardware, does it tell you the CPU??
            I checked my Beelink King, and King Pro and the Mini2....... here are the pics of them.
ID:	794247Click image for larger version
ID:	794248Click image for larger version
              sogoku_vn Do you show any dropped or skipped frames????
                it is an interesting problem in that sense.
                I would also suspect because the size of the memory is smaller, and therefore the default buffers allocated for the decoding is kind of short.
                But the posted picture also revealed memory has not been max-ed out right ? Maybe the default size of buffers were not been allocated correctly ( by the chrome OS decoding library ).
                  adding a big heatsink and a fan, temp CPU decrease. But still dropped frame, not smooth or slow and CPU ~100%,
                  Cpu-Z
                  Aida64
                  kodi android info
                  while my RPI 4 is smooth, play well with same SD card, same monitor and 4k TV
                    I just noticed, you are running an older Kodi version. Are you sure you're running the nightly of CoreELEC????
                      pic above is Kodi android
                      Yes, newest nightly CE
                        Your CoreELEC shows 50hz, maybe that has some effect??
                        Just had another CoreELEC update, now it shows the correct CPU for this box...........
ID:	794265Click image for larger version
ID:	794266Click image for larger version
                          sogoku_vn I think the problem is your frame rate.........
                            Updating newer CE and change frame rate to 60Hz. It is still not smooth and skip frame
                            CE and hardware info,
                            recognize CPU S905X3
                            Still skip frame, lag
                              You can try with usb stick(coreelec on usb)?maybe is something with card reader on that box .Is posible beelink have superior hw vs tanix (2vs 4 ,ddr3 vs ddr4)
                                Here are my Netflix and Inputstream adaptive settings............ Long shot, but out of ideas..
ID:	794292Click image for larger version
ID:	794293Click image for larger version
ID:	794294Click image for larger version
ID:	794296Click image for larger version
ID:	794297Click image for larger version
