CoreElec / LibreElec builds for GT1 Mini 2 S905X3 ?
Originally posted by sogoku_vn View Post
I turn on/off nothing change, play not well, not smooth,cpu ~98 100%
Settings->system->display->refresh rate
Try one-by-one available refresh rates to see if one of them improves.
I purchased a faster microSD card, and reinstalled everything. I just installed Netflix again to test "The Witcher".
I am running CoreELEC version from Dec. 30, 20-19. The Witcher is running in 1080p mode with DD+ audio and subtitles enabled. It is playing perfectly, no lags or audio/video out of sync....
I did not make any changes in the video settings, just changed the audio settings to use HD audio......
This is running on a Beelink GT1 Mini 2 with Amlogic S905X3. With MinixFreak's ATV version 4 Android OS...........
Originally posted by clarkss12 View PostI purchased a faster microSD card, and reinstalled everything. I just installed Netflix again to test "The Witcher".
[/ATTACH]
1. ddr4 Vs ddr3.
2. Better sdcard vs ...
3. Maybe Beelink uses higher CPU clock speed
720p, smooth, play well
CPU clock same Beelink 1.9Ghz but DDR3, Tonight I will test with faster uSD SamSung EVO U1.
How to show this info,
I pressed Ctrl+Shilf+O but only
I believe there is one more factor to the equation, ie the TV which your box is connected to. If you are connected to a fair recent TV, capable of 4K, maybe it should be a non-issue. But if you are using an older TV, there is really no guarantee that the TV could be smooth at a particular refresh rate required by the frame rate of the movie.
Originally posted by mctiew View PostI believe there is one more factor to the equation, ie the TV which your box is connected to. If you are connected to a fair recent TV, capable of 4K, maybe it should be a non-issue. But if you are using an older TV, there is really no guarantee that the TV could be smooth at a particular refresh rate required by the frame rate of the movie.
Did you test you box with Alda64 and cpuz to find out if your box truly has a S905X3 SoC??
Also, the Amlogic S905X2 will software decode Netflix in 720p, but NOT 1080p, that makes me wonder if they sold you a S905X2 and said it was an X3............. Maybe open the box and look at the CPU (SoC).
Another thought, go to the CoreELEC forum and ask if there is a ssh command that will tell you what the CPU actually is...... You can use Putty to access your box with the ssh command..MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1341 users online. 1 members and 1340 guests.
