CoreElec / LibreElec builds for GT1 Mini 2 S905X3 ?
Originally posted by clarkss12 View PostOriginally posted by clarkss12 View PostDoes your CoreELEC play high bit rate videos?? Download some sample videos with different codec formats and see how it performs......... If you have not already done that.
Setting netflixe the same but not smooth, many
.skip frames
Could you run cpu benchmark Stress-ng via ssh, system-tools from the coreelec repository. I want to check cpu performance
stress-ng --matrix 0 -t 5m --times
stress-ng --mq 0 -t 5m --times --perf
my box
and geekbench Android. Thank so much
Originally posted by sogoku_vn View Post
Playing the sample files are very smooth, perfectly
.skip frames
my box
For geekbench 4.3.4, single core 866, multi core 2343.
Originally posted by bluesmanuk View PostFor anybody having issues with the latest CE nightlies, there are a few bugs related to performance with the kernel, so if you want more stability, go back to 9.2.1, which works very well on the whole.
I will try Amlogic and Amlogic-ng with dtb s905x3... Can not run.
Nothing much you can do with respect to Netflix 1080p.
I suggest we can ask people who has TX3 4 GB ram to try this. At least it could to help to get bottom of the fact of this problem, is it the size of the ram or is it the speed of the ram which makes the difference.
Originally posted by mctiew View Post
So the nightly changes necessary for s905x3 to run have not even made it to Amlogic and Amlogic-ng.
Not sure how much of a impact this is but the last time i looked at CE and actually built the EE sources they both were still building with x2 settings which is Cortex A53 while the x3 SoC;s are actually Cortex A55's which are not exactly the same animals...
Unless the nightlys are being corrected which i don't know i can't say for sure but I do know the mainstream 9.2 gits are not corrected for the x3 on both CE and EE. i no longer build CE but did build the EE Amlogic-ng on the weekend and it definately worked better correcting the Cortex..
just sayin...
Originally posted by Koxx View PostHello !
I am planning to buy a GTmini with s905x3 chip.
Is everything working fine with latest CoreElec ?
HDMI CEC ?
network at 1Gbps ?
wifi ?
thanks !!!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1300 users online. 1 members and 1299 guests.
