Pipo M9 Pro RileyROM 1.8
    performance
    Originally posted by devilmc View Post
    Even if antutu scores almost 19000 points, the system is extremely low in performance, slow, stuttering and slow motion even in android home screens without any animation... not to talk about games, real racing 3 goes faster on my 5000 point antutu score mobile device... any suggestion?
    does the same slowdown happen if you flash the tablet with the offical Pipo ROM from pipo.cn? If it is still slow, then the RileyROM is not to blame. If it only is slow with the RileyROM, then there's a chance we can do something about it here.
      Real Racing 3
      OK Devil, I just found this game on Google Play store - it is telling me it is NOT COMPATIBLE with any of my devices - that's a Galaxy Note, this PipoM9 Pro and a generic android 4.1.2 tablet. I also found a few add on apps that tweak the graphics and there are MANY reviews complaining that the game doesn't work on their devices. SO...........Check again with the app supplier (the developers EA Swiss sarl) before complaining again on this site. go back to playing it on your phone. As I suggested in an earlier post - try something else. I was actually going to give it a try in an attempt to help you out but cannot - you have time to play games, so use the time to do some of your own research!!!!!
        i solved also the bootanimation screen lock on/off with power button issue, but now i have a much more important issue to solve... performance.
        any suggestion?
        Does your 5000 point antutu score mobile device have the SAME resolution / pixel density? It's not fair to compare another device with less than 1920x1200. Most 'well written' APPs will "try to" scale up when it encounters better specs. The additional pixels will 'stress' the entire system.
        Sam
        Sam
        PiPo M6 Max/Pro
        PiPo M9 Pro
          Boot Animations Root App
          One can replace the bootanimation.zip file easily with one of the app's animations or one's own with one touch and without going into the file system at all.
          Check it out - it's on Google Play here
          /Kastrup
            boot animations ?
            Not good reviews on the play store for that app Kastrup and it looks like you have to pay for animations - why not donate to Randy and get his one working instead!? I actually found some simply by googling bootanimation free download - and it was not exactly difficult to change the file the one time I bothered. I personally can't see the point of all this boot animation when it only gets seen if you need to reboot (which I do as little as possible myself - and when I do I don't exactly stare at the screen - do you??) (yes, OK I do when I'm testing something, but really guys, do we spend our lives watching boot screen animations???)
            Last edited by colinabroad; 30 October 2013, 07:33. Reason: Grammar again - must read before hitting that send button!
              You don't have to pay for the free ones... and others reviews are not a reason for not trying it on YOUR device ...
              However I used it for testing purposes with 1.9/T1 in order to eliminate the problem (then), using my own animation file (an option in the app).
              Naturally Randy should do his but for those who still struggle with any issues caused by the bootanimation it may be a easy temporary help.
              /Kastrup
                /Kastrup
                OK, fair enough - but my first read of the play store did not inspire me to try! I thought reviews were there to help make that initial decision? - I looked around the store for other app like thi sone and found one with more favourable reviews - and it is of course up to each of us to decide! Yes, for those who are not getting any joy from Test2 it could be a possible work around, but for me I will wait to see what Randy comes up with next as my test2 version is working fine.
                  No problem at all with 1.9test2 (great job !)... and I installed the Apex launcher has inspired me another member.
                  Just a little thing pretty annoying and must be resolved : when I reboot my wifi is not active.
                  I can make it immediately with the parameters/settings but I would like it to be from the boot and alone ...
                  Is there a solution?
                  Excuse me for my poor english writing...
                  I cna tpye 300 wrods pre mintue !!!
                    battery drain
                    I’ve switched from 1.8 to v1.9Test2 and it’s working fine for my M9Pro-3G. All functions available great work!
                    Since the basics are working, I’m now looking for details: I’ve got a battery drain issue. The device doesn’t seem to got to deep sleep.
                    I’m using BetterBatteryStats to track down the problem. It identifies “ril-rk29-dataonly” as issuer for 90,7% of all kernel wakelocks. The same problem seems to be with the Kasty rom (forumlink #10) but not with the stock rom. Couldn’t find any hint by now. Only some Chinese and Russian forums posting about the same problem (I love Google-Translate ), but without any ideas on how to solve the problem.
                    Are there only a few like me how are having this type of problem?
                    Any Ideas what’s behind “ril-rk29-data only”?
                      Riley 1.9 Test2 progress
                      In the meanwhile i succesfully flashed to Riley's 1.9 Test2.
                      Pretty slick as i would say. I've only got 2 things:
                      - Cannot get my 3G working. No 3G button and no succes in getting a contact with my provider
                      (T-Mobile NL). Only with my WIFI on, the 3G connection seems working.
                      - Had 2 spontanious resets in 6 hours. After reset no WiFi would start till i rebooted my M9pro myself.
                      Further testing and waitin for more ....
                      Gr. Pete
                        I have also been on the quest of just getting a stable working rom on my M9 Pro. And v1.9 test2 certainly is the best so far.
                        With that said, know that the rom is stable, I can also start looking at the battery stats.
                        Like you, I noticed that there seemed to be excessive battery drain. And using CPU Spy I can confirm my M9 also rarely goes in to Deep Sleep. (see picture below)
                        I will need to run the BetterBatteryStats app to see if I observe the same wakelock culprit.
                          Originally posted by peeceecee View Post
                          I've read several reports that Pipo removed the 3G button from the drop down menu.
                          Look under Settings> Mobile Networks for the 3G options.
                          I've also read that some people have had success with 3G by Disabling Wifi, inserting sim and then reboot.
                          YMMV
                          I'm looking forward to getting the FREE T-Mobile data sim they are offering so I can test it out on my side.
                            Battery drain ?s
                            GulShiraz's post got me curious so I did a little searching, but I don't know how to quantify excessive battery drain. I'd be interested in anything I could do (including UNDERclocking) to extend the life, but my use isn't all that heavy - as others might be. I have only had it disconnected from the charger for 58 minutes, but the battery is 97%. There has been a lot of time in video off sleep, but that doesn't get included as CPU Spy deep sleep. Mine shows 27 hours total, 17 hr 312 MHz, 7 hr Deep Sleep, 2.5 hr 816 MHz ... and Deep Sleep isn't "growing".
                            Anyhow, my search for
                            ril-rk29-dataonly produced a lot of references to incoming calls, disconnect, ... and the posts here seem to be3G. I'm WiFi only and the only things I find in MY build.prop when searching for dataonly or ril are:
                            #rild.libpath=/system/lib/libreference-ril.so
                            #rild.libargs=-d /dev/ttyUSB2
                            ro.ril.ecclist=112,911
                            ril.function.dataonly=0
                            But some website's build.prop post contains these:
                            rild.libargs=-d_/dev/ttyUSB1
                            ril.pppchannel=/dev/ttyUSB2
                            rild.libpath=/system/lib/libril-rk29-dataonly.so
                            ril.function.dataonly=1
                            ro.ril.power_collapse=1
                            ro.ril.disable.power.collapse=0
                            My GUESS is that eventhough I seem to have a daemon process running named
                            /system/bin/rild
                            that my WiFi version isn't exercising it much. It MIGHT be worth disabling 3G, reboot, and see how much the battery goes down / hour compared to present discharge rate.
                              I've found out that the battery drain issue is definitely in the kernel. There are voltage problems when the deep sleep is activated that causes the tablet to shut down, so Pipo has disabled this until they get a solution....so it isn't something I've been doing.
                              Our kernel guys are working on a solution on our end.
                              The good news is there is a possibility of custom overclocked kernels with some other tweaks available soon. In fact, I may go ahead an include an optional overclocked kernel in the next ROM.
                              Stay tuned!!!!!!!
                              Randy
                                One quick reply: My tablet was fully charged this morning (8:00 am), used for about 30min (video on train) and was in standby for about 10h with wifi and 3g off. The tablet is now down to 54% battery with 10h 41min for "ril-rk29-dataonly".
                                I'll give it a test with a reboot on disabled 3G...
