The official 1080p ROM (11-7-2013) update, can be found HERE http://en.cloudnetgo.com/_d275908309.htm! I just installed it on my CR11S, it's smooth as silk ... I know one thing, the CR11S is the best Google TV/Android Box, I have ever owned ... As a matter of fact, I'm getting ready to order me another one ! Also their is a direct link to the 1080p ROM here https://plus.google.com/communities/...20500984874818 !
CloudnetGo CR11S
New 1080p update ROM (11-7-2013)
Originally posted by Tech1 View PostThe official 1080p ROM (11-7-2013) update, can be found HERE http://en.cloudnetgo.com/_d275908309.htm! I just installed it on my CR11S, it's smooth as silk ... I know one thing, the CR11S is the best Google TV/Android Box, I have ever owned ... As a matter of fact, I'm getting ready to order me another one ! Also their is a direct link to the 1080p ROM here https://plus.google.com/communities/...20500984874818 !
I have a 2 mpx model can I Install this?
Originally posted by Tech1 View PostIf their is a method for rooting the CR11S, please point me to the instructions, thanks in advance. Also if anybody know of a XBMC.apk, that works very well with the MX Player as external player, please point me to it.
have at look at this:
The CS968 is identical to the CR11/s.
The CloudnetGo CR11S Now Has Root
Originally posted by mitglied View Post
Make sure USB Debugging is enabled on your CR11S (Settings -> Developer Options)
Connect your CR11S to a Windows PC via the mini USB port. (now only support rooted via Windows PC, no linux or Mac)
Your PC should detect a new device, and try to install the driver. You can download the driver HERE http://www.mediafire.com/download/55...CR11s_root.zip .... The RK3188_ROOT.rar unzip no password required ..... Drivers are included ...!
After having installed the driver, download HERE RK3188_ROOT.rar , and extract the files.
Click “ TPSparkyRoot.bat” and follow the instructions. After 2 reboot, your device should be rooted .....Last edited by Tech1; 07 December 2013, 01:52.
WHICH ANDROID TV BOX IS SUPERIOR
As you know, I have been testing the Neo X 7 and the CloudnetGO CR11S for the last several days ... So I guess you guys want to know which box is superior .... Guys please respect my opinion and I'm trying to be as unbiased as possible .....
After carefully testing each Android TV Box, based on ease of use for newbies, UI speed day to day smooth performance without latency, video resolution quality and audio ...
I find the CloudnetGO CR11S Android TV Box far SUPERIOR over the Neo X7 in all the above categories ... I was shocked at my finding, because the Neo X 7 is marketed as the best Android TV Box on the planet and clearly it's not ...
I have packed my new Neo X7 and I'm returning it tomorrow ...! I will be purchasing another CloudnetGO CR11S shortly ...!
Originally posted by Tech1 View PostThe official 1080p ROM (11-7-2013) update, can be found HERE http://en.cloudnetgo.com/_d275908309.htm! I just installed it on my CR11S, it's smooth as silk ... I know one thing, the CR11S is the best Google TV/Android Box, I have ever owned ... As a matter of fact, I'm getting ready to order me another one ! Also their is a direct link to the 1080p ROM here https://plus.google.com/communities/...20500984874818 !Originally posted by convict View PostYes but isn't this rom for the 5 megapixel model?
I installed the 2M WebCam version but can not configure FullHD (1920x1080).
Your WebCam is 5M or 2M?
Tks.
webipsum
CS968 - JESURUN
Here we go. Try this cloudnet ROM. I don't remember from which site I got it. Let me know, if it is a good start for a ROM.
cr11s_1080p_2MP
JDfense
There are currently 2435 users online. 2 members and 2433 guests.
