CloudnetGo CR11S
    Yes, the cloudnetgo firmware is the best, but they sell model T's like the others.
    JDfense --->I8160
      JDfense --->I8160
      Is the T better?? or is it also locked at 1.4 that's the issue I have with any of these devices don't want a locked cpu that I cant get to run mod roms on....... its a crap shoot right now and I just want to get some verification from them.
        It seems they are locked, but some are not. We don't understand it.
        JDfense --->I8160
          OK cloudnetgo just confirmed the cr11s comes with 3188T not the 3188, as well main board will be standard and not chipset changes to it,
          There tech departmgarment will be sending more details shortly and will post more once all get back from holidays.
            Very good. Maybe cloudnetgo could help us.
            JDfense --->I8160
              Were can I buy this in the US?
              Donations--> Paypal
                Better to buy here http://www.aliexpress.com/item/2013-...424683447.html than buy in the USA, because you will be in control of your money all the way, until the product gets in your hands ... Plus you will receive your product very fast, because you are on the west coast ... Maybe in a few days, if you choose the right carrier ...!
                  Thanks for the reply. Would this one be the same without the 5mp camera? Thanks
                  http://www.amazon.com/Alldaymall%C2%...=RK3188+camera
                  Donations--> Paypal
                    Yes ...!
                      This Box run only with 1.4Ghz max and lag very much on Gameloft Games.
                      And my box go on retoured. Realy shit these RK3188 Hardware. And all Product are fake so very much.
                      SO im so angry after 10 android equiment that i play better on win os and never more android.
                        HOW TO MAKE STOCK IR REMOTE START BOX
                        HELLO, CAN ANYONE PLEASE PROVIDE A SOLUTION FOR TURNING THIS BOX ON. CS968 ECT... I HAVE FLASHED THIS ROM AND CANT FIND A WAY TO SWITCH IT ON WITHOUT UNPLUGING THE POWER FROM THE BACK OFF THE BOX,THANKS.
                          Hello on mine when I shut the device it will auto power when the tv is restarted ( turn off the device, turn off the tv then turn on the tv and the device should auto boot ) - mine does cs968 rev 2 board with rk3188t inside.
                            Power On-Off
                            Hello,
                            I was having the same problem untill I removed my HDMI switch from the equation!
                            As Rosty said power on via Hdmi automatically when TV is turned on. Power off with remote or power icon on home screen.
                            Hope this helps.
                              cs968 turning off and on.
                              Cheers for the replies. was thinking more of an apk to sort the problem but the box is that good I can live with it. Thanks again.
                                I'm new to the android community.,I have the CR11 and unfortunately the system locked with PIN so Im not able to factory restore when I contacted the supplier he advised that I have to press on the reset for 5 seconds to restet the devise but still nothing changed and Im still getting the PIN security for factory restore and I think I wont be able to add new ROM. please help me to unlock MY device and please help ME to install the latest ROM.
