Here we go. Try this cloudnet ROM. I don't remember from which site I got it. Let me know, if it is a good start for a ROM. cr11s_1080p_2MP
JDfense
Chief engineer, doctor and friend JDfense. P E R F E C T !!!
Now everything is 1920x1080 with my device: CS968.
Now
cloudnetgoCR11/S.
With firmware you indicated in the previous post:
CR11S_cloudnetgo_ap6210_1080p_20131019_update.img
I'll install applications and then I comment more.
Thank you so much.
As you know, I have been testing the Neo X 7 and the CloudnetGO CR11S for the last several days ... So I guess you guys want to know which box is superior .... Guys please respect my opinion and I'm trying to be as unbiased as possible .....
After carefully testing each Android TV Box, based on ease of use for newbies, UI speed day to day smooth performance without latency, video resolution quality and audio ...
I find the CloudnetGO CR11S Android TV Box far SUPERIOR over the Neo X7 in all the above categories ... I was shocked at my finding, because the Neo X 7 is marketed as the best Android TV Box on the planet and clearly it's not ...
I have packed my new Neo X7 and I'm returning it tomorrow ...! I will be purchasing another CloudnetGO CR11S shortly ...!
Do you check Rikomagic mk902?
Similar spec but flash memory 16GB
I have problem with miracast with my nexus 7 2013 with android 4.4.
The wifi app found the tab and my tab found the tv box in display option. Can the android 4.4 make problems?
Now
cloudnetgoCR11/S.
Thank you so much.
webipsum
CS968 - JESURUN - Now cloudnetgoCR11/S
So how do you like the CR11S 10800p ROM on the CS968 ....? I will test it out on my CS968 in a few minutes ...! This ROM doesn't work on my CS968, all it does is make the screen jump with the CR11S logo, strange ...! This CR11S 1080p ROM with the 5MP camera works better ... I will give this one a test run for several days ...!
Tech1. See my tests here ...
At the moment everything working ok here...
Good night and until tomorrow ...
Ok! Where is the link or mirror to the CS968 1080p ROM you are using ....? Reasons unknown to me, none of the CR11S ROMs will work on my CS968, the Ethernet connection will not work ...! maybe a driver problem ...!
[QUE=Tech1;117152]WHICH ANDROID TV BOX IS SUPERIOR
I have packed my new Neo X7 and I'm returning it tomorrow ...! I will be purchasing another CloudnetGO CR11S shortly ...![/QUOTE]
Hey i agree and for some reason everything works as stated out if the box???? I Switched to it as well.
Yes cafe king, it is possible. You need an app to change it. I assume that the external keyboard helper pro would do the trick for you. Or you find a similar app.
JDfense --->I8160
Thank you so much, mein freund! You have helped me so much!
Another quick question... Is there a custom rom that's the best for the CR11/S?
Tech1 made some good ones for tv and video friends
I work on one, I have not much time right now and I'm searching for the secret for the model T devices.
