[ROM] SLIMBOX X3 ATV and AOSP for N5MAX S905X3
1. Download SLIMBOX, a patch for your box from the Patch_for_TV_BOX folder and an attached TWRP, write everything to a USB flash drive or memory card.
2. Install Titanium Backup and backup our programs and games.
3. Launch the Power menu program and boot into recovery. Download: Attached file PowerMenu.apk (114.49 ??) Number of downloads: 18
4. In the recovery, select Apply update from EXT.
5. Find the downloaded mounted TWRP and install it.
6. In TWRP, select the Russian language and allow changes with a swipe.
7. Make sure to backup your firmware!
8. Install SLIMBOX and then a patch for your TV box!
9. We make a selective wipe of data from the previous firmware: Cleaning-Selective cleaning-Dalvik / arte cache and Data.
10. Overloading the system!
Originally posted by SlimHouse View PostMain device Magicsee N5 Max (S905X3)
edit your build.prop and change Main Lang to English. so that everyone here can enjoy this awesome rom....... If not, im sure people will figure out how to get english
to work..
Thanks SlimHouse for the ROM it is good.
I am using N5 Max 4/32. I have installed the ROM and so far it is good except for the hardware monitoring.
When I enable the CPU temperature, do you know why I cannot see the numbers for the temperature? When I enable I can see a new symbol appearing in the status bar but it is not possible to see the temperature value. Same goes for CPU Load and also CPU freq. But the internet upload and download is showing fine.
Another thing is do you know how can I completely remove any traces of rooting? At first I have an app which works, but once I installed root, the app detects my root and do not work anymore. I tried to uninstall root, but the app still manages to detect root. I am not sure if there are some other folders I should delete?
Thanks so so much for your work on this ROM!
Originally posted by Fifty2019 View PostWhere can i download the PowerMenu.apk? can you give me a Link?The link on the Page 4pda.ru doesnt works..
There are currently 2618 users online. 1 members and 2617 guests.
