[ROM] SLIMBOX X3 ATV and AOSP for N5MAX S905X3
I have one of those and its a junk box, i think its a fake
The one i got is black with graphics on the top, a clock in the front and when i took it apart it has a sticker on the bottom that says S905X3 / RK3318
The older X88 was silver and had the RK3318 processor and i think its a rehash of that chip reboxed because it performs horrible not even up to par with a 905X2
I think they have reprogramed the chip so that any chip info programs show up that its a 905X3 but and the speed and stuff but its not actually running at those speeds they are cheating the specs and stuff
Not sure what's changed, or what's going on with my TV Box, tried installing version 4.1, 5.1, both do the exact same thing. I do a fresh install of the stock rom, install the AOSP or ATV version via TWRP, wipe the cache/dalvik, reboot. It boots up, but gets to the home screen, shows "slimbox by slimhouse" in blue, the loading bar goes to full, then stays there (doesn't go away), but I can double click the home button, and the app list pops up, the bar on top is interactive, but the loading bar and logo do not go away, even if I reboot, it happens, have patched with vendors, without vendors, not sure what's up.
Ive had that, i had to just start over.
Load the stock rom back on and make sure everything works, wifi, bluetooth etc
Then load the rom with twrp, thn vendor then wipe just those 3 things.
I spent like 2 days trying things over and over and finally got both of my boxes loaded and my Benchmarks went from 68,000 on one box to 72,000 and 69k to 75k on the other they are both identical N5 max X3 boxes
Originally posted by BowerR64 View PostWhen you reboot it after the bar gets to the end what does it do?
Thanks for the help!
So your saying you cant view images posted on this forum?
I made a post over in the general section that i was having issues with the forum not loading images but the owner said its working fine.
I started thinking it was just my machine, if its not working for you either please go and post in that thread that its not working for you either so they can fix it.
At the bottom there is a list of users that are logged in the site and they are not showing correctly on my computer either
Originally posted by Jancales View PostJust notice there is a vendor file N5 Max X3 and N5 Max X3 -2019.
How to know which one is needed?
So just try all of the Vendor files till you find one that works
The main rom is like a patch, the way i get it is its just overlaying files or graphics or something over your original rom, then the vendor patches the patch if that makes sense?
This is why you need an original working rom to start with, then when you patch the slimbox rom its using an already working rom and laying over it
Then the vendor overlays the extra stuff needed for each specific box and the extra features each box has
I have about 10 boxes and some remotes work but the buttons don't do the same things on every box if i push home on the wrong box the volume goes up, the vendor patch is what corrects these little things.
I dont think it hurts anything to just try the different vendor files, don't forget to wipe those 3 things each time though
There seem to be quite a few problems with the forum.
I get 2 emails that BowerR64 has made 2 posts, one in which he quoted me, but when I click on the links my post #115 and #116 are the last posts in this thread.
I can refresh as often as I want, his posts aren't visible to me
Edit: And after I made this post they became visible
You have 10 N5 Max X3 boxes, and do the remotes now work properly on all 10 boxes or not?
There are currently 3013 users online. 0 members and 3013 guests.
