[ROM] SLIMBOX X3 ATV and AOSP for N5MAX S905X3
Hi, thank you for your awesome ROM. I'm flashing Slimbox ATV 4.2 along with patch (X96Max+) using twrp 3.2.2, but the wifi and bluetooth is not working. Is there something I've missing during flashing the ROM.
Edit : After flashing, my storage shows 10gb internal instead of 32gb.Last edited by prisoner0093; 30 May 2020, 15:42.
Originally posted by raruba View Post
I also have a Magicsee N5 Max 4g 64g box, do I need to install the vendor for this? If so which one do I use?
Guest
Update: installed v4.4 AOSP and playback in setting still doesn't work. Just thought I would let u know.Last edited by raruba; 03 June 2020, 11:36.
I have this installed on a x88 pro x3, I wanted to replace the orginal firmware, not sure if I'm using the rigth one but I'm getting this from the burn tool
20:03:49 917][HUB3-4][Inf]--Download DDR.USB,size: 65536!
[20:03:49 918][HUB3-4][Err]--Download file failed, sequence 0
[20:03:49 918][HUB3-4][Err]--usbWriteFile len=4096, ret=-5 error_msg=libusb0-dll:err [_usb_reap_async] reaping request failed, win error: A device attached to the system is not functioning.
[20:03:49 918][HUB3-4][Inf]--Failure : 1, FailureMax : 3
[20:04:00 419][HUB3-4][Err]--Download file failed, sequence 0
[20:04:00 419][HUB3-4][Err]--usbWriteFile len=4096, ret=-116 error_msg=libusb0-dll:err [_usb_reap_async] timeout error
[20:04:00 419][HUB3-4][Inf]--Failure : 2, FailureMax : 3
[20:04:10 922][HUB3-4][Err]--Download file failed, sequence 0
[20:04:10 922][HUB3-4][Err]--usbWriteFile len=4096, ret=-116 error_msg=libusb0-dll:err [_usb_reap_async] timeout error
[20:04:10 922][HUB3-4][Inf]--Failure : 3, FailureMax : 3
[20:04:10 927][HUB3-4][Err]--[0x10103003]Romcode/Initialize DDR/Download buffer/USB transfer error
Anyone has the original firmware for the X88 pro x3? the one I got is x88pro-s905x3_d4_sp6255_x88prox3_20200115_r1, and is not burning
Originally posted by nmocruz View PostI have this installed on a x88 pro x3, I wanted to replace the orginal firmware, not sure if I'm using the rigth one but I'm getting this from the burn tool
There are currently 1463 users online. 0 members and 1463 guests.
