[ROM] SLIMBOX X3 ATV and AOSP for N5MAX S905X3
Originally posted by raruba View Post
The box now is even in worse state, doesnt boot, TWRP is gone, has the original recovery and it fails all time do any thing.
fail to mount /cache (I/O error). An must of the error are trying to mount partition. I'm lost dont know how to recover the device. the USB burner fails, the SD card fails, the recovery fails.
I use ATV version. Ther are two problems for my Turawell T95 Max+ 4GB/64GB
First, It does not open the first time with the remote. I can use the remote after it is turned on.
Second, The front panel does not work. There is no light.Last edited by ahbecan; 07 June 2020, 13:11.
Guest
Originally posted by Jjgonzalez87 View Post...only twrp link that did not work...
Hi .
I have an a95x f3 air and the installation of the rom and the vendor went very well, the problem is that the "ok" button on the remote control does not work.
could you tell me how to solve this problem? maybe take a file from a stock rom and place it in this one with a root file manager?.
thank you for your job.
There are currently 2233 users online. 1 members and 2232 guests.
