V5 Changelog
-Based On Newest Beelink Firmware
-Updated Gapps
-Newer Tweaks for stability
-a bunch of other things but forgot lol
V4 Changelog
-Based On 007P0 system firmware
-Fixed Cec Bug (not saving settings)
-Improved Speed
-Smoother UI
-Optimized Voice Search
-Updated Gapps
-Updated Smartyoutube
V3 Changelog
-DPI Set To 320
-Fixed Playstore Not updating
-Added Nvidia Shield recent app layout ( Props to xvortex/slimhouse)
-Faster
-Debloated a bit
-Custom Black Leanback Keyboard
-Autoframerate App added as regular instead of system
-Made some more build.prop tweaks
-Better Visual UI Navigation Bar (Hidden By Default)
V2 Changelog
-Based On Beelink 005P0 Firmware
-007P0 Kernel
-"Alvatech" Framework (Amazing Developer)
-Rooted With SuperSU
-Added Gamers Tweaks
-Improved Wifi Speeds
-Added Autoframerate To System App
-Init.d Supported
-TWRP Recovery
-DPI Set To 280
-Improved Voice Search
-SystemUI Smoother
-TV Provision Added
-Leanback Keyboard
-Dolby Vision Disabled By Default
Special Notes
H96_MAX_X2 Build Users must flash init.d_FIX patch to have all the tweaks apps and all working
Boot Into Recovery ( Need Mouse ) Flash Init.d_FIX Patch twice to make sure system mounts and reboot
If the afrd kodi and su is not working repeat steps it will eventually work.
-In Playstore Disable Auto-updates and dont allow AndroidTV Home to update, It causes Black screen after video playbacks sometimes
Thanks for all your support sorry I didn't integrate the fix i physically don't have the device so its hard to do but patch works I have a user who tests for me
Downloads
Screenshots
https://imgur.com/ZxsCQug https://imgur.com/AzBA2wm https://imgur.com/YSJMtJE https://imgur.com/UKlgfQL https://imgur.com/wx5tal6
This Is My New Project which I welcome developers to make it even better with me
