thank you
[ROM] Spartan_ROM ATV S905X2
Originally posted by bundyboy View Post
i forgat to ask you. does the box needs to be connected to power adapter, or only to usb cable during flashing ?
thank you
Originally posted by markshane View Post
Just USB cable is enough. Make sure to press the reset button in AV port while inserting the USB cable is black port (2.0). Once detected, it should immediately start flashing
but before that i need to click start in USB Burning Tool. ?
when I release the reset button ? iimmediately after I plug in the usb cable or I have to wait for the device to be detected ?
thank you
I have a few niggles with the rom, but so far still running smooth a week on (on my new t95q). Seems much better than stock on the whole. Playstore seems much more limited though but an easy workaround im sure. Plus I dont really use it anyway. Only thing I havent really tested is ethernet, but theres no reason why that wont work. Will be sticking with this rom from now on.
Originally posted by dudese View PostSeems much better than stock on the whole.
Originally posted by neon640 View Postminixfreak please... X96 Max.
can you do this application in x96max.
Unfortunately, the T95Q ROM does not work on my old version of the t95q, I will have to stay at version 8.1 ... minixfreak, could you tell me how can I make the led work on my custom ROM 8.1?
* The Spartan Rom version T95Q_NewRev is the only rom I found that the leds work. i wanted to put it on my personalized rom 8.1 ... Could you help me please ???
There are currently 1715 users online. 0 members and 1715 guests.
