test that firmware and see if the wifi and ethernet works for you thats what i based it off
[ROM] Spartan_ROM ATV S905X2
wifi, ethernet and bluetooth don't work
I will hopefully get a chance to test the rom on mine today
edit: downloading now. I hope it works, else will be a lot of time resetting up my apps for nothing hahaLast edited by dudese; 24 May 2020, 13:37.
The rom seems to work fine! Wifi is certainly working https://ibb.co/dLqmnNC
Will test it out properly now but so far so good. Many thanks!
Originally posted by dudese View Post
Are you sure you have the new t95q that came with 9.0 as stock? And not the old one with 8.1? As it has the 8822 chip so minixfreaks rom should work, especially the stock one as ive used that rom before myself I think.
Thats why yours isnt working then.
Everything seems perfect so far on this rom, except on my airmouse i cannot click on things on the on screen keyboard like before, however clicking web links and using it elsewhere seems fine. Not a massive deal as theres a keyboard on the back of the remote just strange thats all.
also cant seem to get bluetooth working. Theres an option to pair but doesnt seem to find anything, but am yet to properly test that out, and am hopeful it does work.
Originally posted by dudese View Posthttps://mega.nz/file/Gc8x2KxS#222usi...8tehm--kMCUQxk
This is the 9.0 fw i use on my t95q. It also seems to be the very latest version that exists as far as ive found. Its from a thread on here. Everything obviously works on the new t95q as its a stock fw.
Glad the new revision is working for you ... as for the remote not clicking in air mouse mode could be cause I mixed it with my s905x2 spartan rom so not completely stock could fix at a later time ... don't forget I made this completely blind ... worked on it for a full day and its the only custom firmware that works on new revisio t95q ... and for the old revision one I will work on it another time ...
Dont get me wrong im not moaning. Just pointing out anything I find for feedback. All things considering seems like a great rom so far and I appreciate it.
There are currently 2595 users online. 0 members and 2595 guests.
