[ROM] Spartan_ROM ATV S905X2
Originally posted by minixfreak View Post
okay guess it will be for the new versions ... but like i said you better know how to recover your box if it doesnt boot
have messed about flashing roms before and am confident enough so think ill be ok. Have been looking into making a rom myself, but just dont have much of a clue haha. Not really my speciality, and no one seems to be supporting the new t95q. Was hoping you could just dump the network drivers from the stock rom and patch them into a custom rom with a tool or something. I found android kitchen but didnt get very far, and cant find any info and have decided im out of my depth so have given up.
Originally posted by dudese View Post
Pray it connects with the usb burning tool and reflash the stock rom would be my plan.
Originally posted by minixfreak View PostT95Q Build is up under test builds please let me know if it even boots
The t95q seems quite rom friendly, so hopefully should be fine.
Originally posted by minixfreak View Postuploading the fixed version of h96 max x2 that fixes droid settings .... also uploading t95q its going to be under test builds but make sure u know how to recover your box if it doesnt work ,,,, BE WARNED Now .... Hope it works tho
Originally posted by alessa View Posthello .
thanks to have rooted the v2 ;-)
is obligate to flash via pc to install the v2 or is possible to update the rom directly by the box (to avoid losing data and having to install everything again)
why disable dolby vision by default? it does not work?
There are currently 1718 users online. 0 members and 1718 guests.
