Pipo M7 Pro RileyROM 1.9 AND 2.0
The boot.img in my ROM's don't have a kernel embedded. It's only the stock boot.img that has the kernel. Also, stock recovery has a kernel, but it's only used if you boot to recovery. CWM does not have a kernel embedded on my ROM, either.Randy
Originally posted by ginman View PostOff topic.......
Does anyone know of an app that gives brightness control beyond stock? I want to be able to dim the screen all the way down or close to it. Thanks
G
ginman,
try this one https://play.google.com/store/apps/d...nevod.loggraph it really works.
Randy, I know that there is no kernel embedded in your ROM, just discovered that stock one has. BTW, stock recovery has own kernel embedded too.
Sv: Pipo M7 Pro RileyROM 1.9 AND 2.0
To install crossbreeder , just download the crossbreeder zip from xda forum. Search for it on Google. Then boot in to cvm recovery and install zip from sdcard. The kernel can be downloaded from a link earlier in this thread. Then replace the kernel in the rileyrom folder with the one you just downloaded. Use the one with stock gpu and cpu values.
Crossbreeder only boosted the antutu score with 200 but it feels more stable. Could be my imagination though :-P only time my tablet gets slow and hangs sometimes is when I download using ttorrent and trying to do something else at the same time.
Don't know about battery yet. But it seems to be the same as when I was on 1.8. Pretty good according to me.
Skickat från min M7pro via Tapatalk 2
cheeks80, the only way is if you can get USB to 2.5mm jack adapter in time.
Otherwise, just plan your trip. You should have a lot of onboard entertainment on such a long flight. Save your tablet just for a time when you'll have nothing to watch/listen/play. And you may have even Internet access on intercontinental flights these days.
Use great caution with attempting to charge a Pipo tablet with ANYTHING other than the stock charger!!!!!! The charger circuits are VERY sensitive and burn out easily. I've done it. I had to pronounce the device DOA!!!!!
Luckily...I had a spare tablet on MY trip to use.Randy
Originally posted by MFinchy View Postfr0zenfr0g,
the Rk3188 drivers do not work with Windows 8.1
There are currently 2905 users online. 2 members and 2903 guests.
