SPMC
One or more files failed to play
I've just moved over to SPMC from beyond XBMC and have found that I keep getting the following error message "One or more files failed to play" Check your log. I have done some searching on google and note that this message has cropped up before not only on the SPMC but on other devices. However, so far I haven't found any solution to rectify the problem. Can any one help!!
Originally posted by berrani View PostPlease, no one is using this future on Android?
Your lcd must to be compatible 24/25/50/60hz.. That's it.
It ok with my rk3288 device... don't know with 3188... just try it
Originally posted by Koying View PostRelevant video options are displayed, including "View Mode".
What options are missing on what device?
What I did was edit android.xml in /data/data/com.semperpax.spmc/cache/apk/assets/system/settings/. The only thing I changed was I set all the options in <section id="system"> to <visible>true</visible>. Then I saved it, restarted SPMC and now I have all the correct options available while viewing a video (such as those listed above).
Seems like in an older version this was under guisettings, maybe? Anyway, that's not exactly what I expected to happen when I set these to true. Before I have done that and it added the ability to turn off fake display, change resolution, etc in system video settings. So, after changing this, my system video settings looks the same and I now have back the zoom functions and such which I was missing before.
Hope this helps! Cheers!
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
There are currently 2327 users online. 0 members and 2327 guests.
