but i can try copy init file from root file
live TV for all rk3188 using XBMC and tvheadend
nayef I extracted .config, dtb and initfram.gpio. I will make new kernel but your device meson8b_m201_1G.dtb not has avl6211 i2c gpio. has other amlogic dtv demod tuner si2168?
I will add dvbsky960 driver. I dont know but may be lost on board dvb tuner for this kernel. but tvheadend and vdr works with kodi. I try to add avl6211 driver.
why "avc: denied" read in dmseg ???
here info dmesg | grep dvb:
Code:2|root@m201_th12:/ # dmesg | grep dvb <4>[ 3.219323@0] DVB: aml dvb init <4>[ 3.219495@0] DVB: probe amlogic dvb driver <6>[ 3.219638@0] DVB: registering new adapter (amlogic-dvb) <5>[ 142.168715@1] type=1400 audit(794769422.850:45): avc: denied { read } for pid=2045 comm="re.rootexplorer" name="dvb0.demux0" dev="tmpfs" ino=2750 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file <5>[ 142.183927@1] type=1400 audit(794769422.870:46): avc: denied { open } for pid=2045 comm="re.rootexplorer" path="/dev/dvb0.demux0" dev="tmpfs" ino=2750 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file root@m201_th12:/ #
Originally posted by Shadi86 View PostHow can you guys watch live TV channels via tvheadend, i mean the spmc crash when I play a channel or no video only audio problem and I have test all spmc version and i have these problem on all my rk box, so how can you watch without problem? Sorry if I have missing something
use this kodi :
Originally posted by taki View PostDVBsky 960 rk3188 kitkat modules (pls nayef tested and repot) (hardwerguru waser for minix and others)
http://www17.zippyshare.com/v/57833551/file.html
Could you reupload these modules pls?
Originally posted by taki View PostMinix X8/X8-H/plus tvheadend
all files cpoy todata/dvb copy to data/dvbsystem copy to systemif your rom support init.d pls reboot everhing is ok open web browser wirıte 127.0.0.1:9981must be look tvhedend web setup pageyour rom dont support init.dopen terminal writemkdir /dev/dvbmkdir /data/data/.htsmkdir /dev/dvb/adapter0ln -s /dev/dvb0.frontend0 /dev/dvb/adapter0/frontend0ln -s /dev/dvb0.demux0 /dev/dvb/adapter0/demux0ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0.tsmkdir /dev/dvb/adapter1ln -s /dev/dvb1.frontend0 /dev/dvb/adapter1/frontend0ln -s /dev/dvb1.demux0 /dev/dvb/adapter1/demux0ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0.tschmod 777 /data/data/.htschmod 777 /dev/dvb*chmod 777 /data/dvb*/data/dvb/tvheadend -C -c /data/data/.hts*
http://www71.zippyshare.com/v/93833722/file.html
Best regards,
Hi guys, I have a Android 4.0.3 STD with 3 tuner hisilicon.
Details:
/proc/msp # cat tuner
---------Hisilicon TUNER Info---------
Port: 0
LockStat: locked
I2CChannel: 4
Frequency(KHz): 489000
SymbRate: 5217000
QamMode: QAM_256
DemodType: 3130_inside
TunerType: MXL603
Port: 1
LockStat: unlocked
I2CChannel: 15
Frequency(KHz): 0
SymbRate: 0
QamMode: QAM_INV
DemodType: avl6211
TunerType: AV2011
Port: 2
LockStat: unlocked
I2CChannel: 15
Frequency(KHz): 1370000
SymbRate: 22700000
QamMode: QAM_INV
DemodType: avl6211
TunerType: AV2011
So, how I can add hisilicon drivers to TVHeadEnd?
Very thanks guys for your help.
There are currently 3470 users online. 3 members and 3467 guests.
