live TV for all rk3188 using XBMC and tvheadend
    Originally posted by taki View Post
    look 416 405 topic
    i try it now v tvheadend from post 416 & 405 =
    1- tvheadend not stable ~ time to time ~ work ~ not work ... i try reboot but not stable
    2- HD channel bad play and freaz
      hi taki
      i want ask for:
      1- update Transponders list in tvheadend ... how i do that ? i need 26E but not in list ...
      2- any way to run cccam in tvheadend & android ?
        Originally posted by nayef View Post
        hi taki
        i want ask for:
        dvb scan path you must identify for 26e
          mpeg2 channel work smoot with kitkat?
          new tvheadend (use esexplorer)
          copy tvheadend to /data/dvb/
          all so files to /system/lib
          may be need some so files rename. if tvheadend dont start. you must be find Which library so rename
          for this
          open termianal write
          ./data/dvb/tvheadend -C -c /data/data/.hts
          terminal say which library needed and dont found. you find /system/lib and rename
          "for examle libvorbisfile.so neededby tvheadend you change name libvorbisfile.so.3 to libvorbisfile.so with esexplorer"
          pls test report
          so sory I forget this. new tvheadend no create related fıles for .hts folder. thus we need copy old .hts folder to /data/data/.hts
          I send to .hts folder. cpoy to /data/data/.hts
          later try
          you can access web interface
          user=admin
          pass=admin
            later try
            user=admin
            pass=admin
            after try :
            u0_a63@manta:/ $ su
            root@manta:/ # ./data/dvb/tvheadend -C -c /data/data/.hts
            WARNING: linker: libx264.so.142 has text relocations. This is wasting memory and is a security risk. Please fix.
            2014-12-16 14:25:02.510 [ INFO] main: Log started
            2014-12-16 14:25:14.504 [ INFO] dvr: Creating new configuration ''
            2014-12-16 14:25:14.505 [ INFO] dvr: Creating new configuration 'okey'
            2014-12-16 14:25:14.506 [ INFO] dvr: Creating new configuration 'new'
            2014-12-16 14:25:14.530 [ INFO] capmt: ok active
            2014-12-16 14:25:14.533 [ ERROR] capmt: ok: Cannot connect to 127.0.0.1:9000 (Connection refused); Do you have OSCam running?
            2014-12-16 14:25:14.533 [ INFO] epggrab: module eit created
            2014-12-16 14:25:14.533 [ INFO] epggrab: module uk_freesat created
            2014-12-16 14:25:14.533 [ INFO] epggrab: module uk_freeview created
            2014-12-16 14:25:14.533 [ INFO] epggrab: module viasat_baltic created
            2014-12-16 14:25:14.534 [ INFO] capmt: ok: Automatic reconnection attempt in in 60 seconds
            2014-12-16 14:25:14.652 [ INFO] epggrab: module opentv-ausat created
            2014-12-16 14:25:14.652 [ INFO] epggrab: module opentv-skyuk created
            2014-12-16 14:25:14.652 [ INFO] epggrab: module opentv-skyit created
            2014-12-16 14:25:14.653 [ INFO] epggrab: module pyepg created
            2014-12-16 14:25:14.653 [ INFO] epggrab: module xmltv created
            2014-12-16 14:25:14.992 [ NOTICE] START: HTS Tvheadend version 0.0.0~unknown started, running as PID:1830 UID:0 GID:0, CWD:/ CNF:/data/data/.hts
            2014-12-16 14:26:14.000 [ ERROR] capmt: ok: Cannot connect to 127.0.0.1:9000 (Connection refused); Do you have OSCam running?
            2014-12-16 14:26:14.000 [ INFO] capmt: ok: Automatic reconnection attempt in in 60 seconds
            2014-12-16 14:27:14.000 [ ERROR] capmt: ok: Cannot connect to 127.0.0.1:9000 (Connection refused); Do you have OSCam running?
            2014-12-16 14:27:14.000 [ INFO] capmt: ok: Automatic reconnection attempt in in 60 seconds
            2014-12-16 14:28:14.000 [ ERROR] capmt: ok: Cannot connect to 127.0.0.1:9000 (Connection refused); Do you have OSCam running?
            2014-12-16 14:28:14.000 [ INFO] capmt: ok: Automatic reconnection attempt in in 60 seconds
            2014-12-16 14:29:14.000 [ ERROR] capmt: ok: Cannot connect to 127.0.0.1:9000 (Connection refused); Do you have OSCam running?
            2014-12-16 14:29:14.000 [ INFO] capmt: ok: Automatic reconnection attempt in in 60 seconds
            2014-12-16 14:30:14.000 [ ERROR] capmt: ok: Cannot connect to 127.0.0.1:9000 (Connection refused); Do you have OSCam running?
            2014-12-16 14:30:14.000 [ INFO] capmt: ok: Automatic reconnection attempt in in 60 seconds
            2014-12-16 14:31:14.001 [ ERROR] capmt: ok: Cannot connect to 127.0.0.1:9000 (Connection refused); Do you have OSCam running?
            2014-12-16 14:31:14.001 [ INFO] capmt: ok: Automatic reconnection attempt in in 60 seconds
            2014-12-16 14:32:14.000 [ ERROR] capmt: ok: Cannot connect to 127.0.0.1:9000 (Connection refused); Do you have OSCam running?
            2014-12-16 14:32:14.000 [ INFO] capmt: ok: Automatic reconnection attempt in in 60 seconds
            2014-12-16 14:33:14.000 [ ERROR] capmt: ok: Cannot connect to 127.0.0.1:9000 (Connection refused); Do you have OSCam running?
            2014-12-16 14:33:14.000 [ INFO] capmt: ok: Automatic reconnection attempt in in 60 seconds
            how fix "127.0.0.1:9000 (Connection refused)" ?
              tvheadend web page seletect camp and delete line.
                i delete : "a7154889ee0d4b84c13383724b68e813" and working finally
                  Merry Christmas to all and happy new year!
                  Alessandro
                  Inviato dal mio Nexus 5 utilizzando Tapatalk
                    windows 7/8 VLC tvheadend plugin
                    hapy new year all people
                    "perfect streaming device is minix x7. but minix devoloper no need assist us. only dcw otg error that raxda fix it. may need to use other usb dvb stick but we know to have solition for this error."
                    windows Installation Instructions
                    • Go to http://ci.btbn.de/job/vlc-htsp-plugin/
                    • Click "win32"
                    • Click "Last Build"
                    • Underneath "Build Artifacts" click "libhtsp_plugin.dll"
                    • Save this to your desktop or downloads folder..
                    • Open Windows Explorer / My Computer and navigate to "C:\Program Files\VideoLAN\VLC\plugins\access
                    • Copy the file you downloaded to this folder - When UAC asks for permission to write to this directory - say yes.
                    • Open VLC and click "Tools", "Preferences"
                    • At the bottom left under "Show Settings" click "All"
                    • In the search box at the top left type "HTSP"
                    • Next to "HTSP Server Address" enter the IP address of your TVheadend install
                    • Click "Save" then close VLC.
                    Using the Plugin
                    • Open VLC, and click "View", "Playlist"
                    • Double Click "Local Network"
                    • Double Click "TVHeadend HTSP"
                    • Double Click "All Channels" (or an appropriate group name)
                    • Double Click the channel you wish to view
                      server of tvheadend minix x7 streaming to vlc perfectly
                      my laptop fast zapping channel than dvb receiver (vu duo2). that is amazingly
                        14012015 tvheadend and library for rk3188
                          Update Now ...
                          must clean old .co ? or just copy new file only ?
                            Copy and paste with esexplorer.overwrite
                            First delete old tvheadend binary later copy and paste
                            Lib files copy and paste overwrite
                            Restart
                              Kodi 15 nigtly build tvh addon api 19. Perfectly worl that I say
                                nice box dvbs android :
