live TV for all rk3188 using XBMC and tvheadend
    Originally posted by juan3211 View Post
    anybody ?
      anybody ?
      YES !
        I have a question
        What files do I need to download in order to get dvb-t working with my minix neo x7 mini and does anyone have them? .
        My dvb-t device is this:
        Does it beed a driver too? If needed, how do I install it?
        Sent from my thl 5000 using Tapatalk
          Originally posted by taki View Post
          sam look at this. diffrent compilation. work perfectly
          tvheadend for Hisilicone 7136c based android player. files structur like tvheadend of linux. use decoding video android library.
          http://www18.zippyshare.com/v/59691752/file.html
          You can share the source for tvheadend for Hisilicone 7136c?
          I want to make it to work with my STB.
            look this webside. Download android firmware. Has android tvheadend exec binary and xbmc (pvr dvbapi for special hisilicone) needed files. No need recompile tvheadend. root your device after copy paste. after restart you have dvbreceiver kofi-xbmc
              Look this
              Diese Website steht zum Verkauf! xbmc4stb.net ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf xbmc4stb.net alles. Wir hoffen, dass Sie hier das Gesuchte finden!
              Firmware
                evo xfinity like your box.
                For compile tvheadend read all topic that we explaned before
                  When tvheadend run i giver erro: "Security Check Fail!"
                    http://m.youtube.com/watch?v=hiOYqxzjeEU
                    Android on my STB is 4.2.2 now.
                    When I try run I get message libhi_flash.so, and lib from 4.0.3 not work on 4.2.2
                    Yes I already compiled tvheadend but problem is, tvheadend not support hisilicon, need adapt code to work.
                    Yu have source with hisilicon support?
                      You must be add your compiler dvb folder of kernel. Kernel include dvb
                      Need add openssll after compile must be work.
                      Tvheadend opensource and you need truely compiler for your cpu and related truely dvb api (yours must be 5.3). At thistime rockchip and amlogic uses 5.10 dvb api. And we can use rockchip and amlogic same tvheadend.
                        But the problem is, DVB API work with /dev/adapter% and hisilicon not have this.
                        Only have hi_tuner, hi_ir...
                          ls /dev
                          alarm
                          apm_bios
                          ashmem
                          avcmd
                          binder
                          block
                          bus
                          console
                          cpu_dma_latency
                          cpuctl
                          device-mapper
                          extcmd
                          front
                          full
                          fuse
                          gmac
                          graphics
                          hi_adec
                          hi_adsp
                          hi_aenc
                          hi_ai
                          hi_ao
                          hi_avplay
                          hi_ca
                          hi_cipher
                          hi_demux
                          hi_disp
                          hi_gfx2d
                          hi_gpio
                          hi_hdmi
                          hi_i2c
                          hi_ir
                          hi_jpge
                          hi_keyled
                          hi_log
                          hi_mce
                          hi_mem
                          hi_module
                          hi_omxvdec
                          hi_otp
                          hi_pdm
                          hi_pm
                          hi_png
                          hi_pq
                          hi_pvr
                          hi_pwm
                          hi_sci
                          hi_sethdcp
                          hi_stat
                          hi_svdec
                          hi_sync
                          hi_sys
                          hi_tde
                          hi_tuner
                          hi_userproc
                          hi_vdec
                          hi_venc
                          hi_vi
                          hi_vo
                          hi_vpss
                          hi_wdg
                          input
                          ion
                          jpeg
                          kmem
                          kmsg
                          log
                          loop-control
                          mali
                          mem
                          mmz_userdev
                          network_latency
                          network_throughput
                          null
                          ppp
                          psaux
                          ptmx
                          pts
                          random
                          rfkill
                          snd
                          socket
                          sw_sync
                          tty
                          tty0
                          tty1
                          tty10
                          tty11
                          tty12
                          tty13
                          tty14
                          tty15
                          tty16
                          tty17
                          tty18
                          tty19
                          tty2
                          tty20
                          tty21
                          tty22
                          tty23
                          tty24
                          tty25
                          tty26
                          tty27
                          tty28
                          tty29
                          tty3
                          tty30
                          tty31
                          tty32
                          tty33
                          tty34
                          tty35
                          tty36
                          tty37
                          tty38
                          tty39
                          tty4
                          tty40
                          tty41
                          tty42
                          tty43
                          tty44
                          tty45
                          tty46
                          tty47
                          tty48
                          tty49
                          tty5
                          tty50
                          tty51
                          tty52
                          tty53
                          tty54
                          tty55
                          tty56
                          tty57
                          tty58
                          tty59
                          tty6
                          tty60
                          tty61
                          tty62
                          tty63
                          tty7
                          tty8
                          tty9
                          ttyAMA0
                          ttyAMA1
                          ttyAMA2
                          ttyAMA3
                          ttyAMA4
                          ubi_ctrl
                          uinput
                          urandom
                          vcs
                          vcs1
                          vcsa
                          vcsa1
                          vinput
                          xt_qtaguid
                          zero
                            I changed assembly in two tvheadend to return always valid in function "security_check" and now I can run tvheadend.
                            BUT not detect my tuner. In this tvheadend already have tuner configured in source code and always have this tuner in DVB Adapter "Hisilcon AVL6211" and in other tvheadend have "Hisilcon LGDT3305".
                            To understand bether.
                              Hello, I am new to Android and I am trying to use a USB DVB-S device in Android. I am using Android 4.2.2 with 3.4.39+ Kernel version. I am using a USB DVB-S stick and loaded dvb-fe-ds3000 firmware to system/etc but when I plug it, the device is not recognizable. I am using the device in Ubuntu without any problem. I also tried to insmod the "ko" files and that didn't work for me either. What approach should I follow now to successfully introduce the usb device and to use dvb modules?
                                Hey there. Sorry, but how to install tevii s660 drivers to Minix X8?
