thx SaX
live TV for all rk3188 using XBMC and tvheadend
AF9015 DVB-T USB on AllFine Fine9 Glory Tablet
I managed to work AF9015 DVB-T USB on AllFine Fine9 Glory Tablet.
I uploaded the following modules:
insmod dvb-core.ko
insmod dvb-pll.ko
insmod mt2060.ko
insmod qt1010.ko
insmod af9013.ko
insmod mxl5007t.ko
insmod tda18218.ko
insmod mxl5005s.ko
insmod dvb_usb_v2.ko
insmod dvb-usb-af9015.ko
and
dvb-usb-af9015.fw firmware.
DroidTV starts, scans the channels and displays the channels, but when I choose a channel, the sound is working normally but the picture freezes.
Does anyone know what could be the problem?
I think is problem in MPEG 4 codec!Last edited by sax; 05 October 2014, 21:23.
At the end of works of tvheadend that most stable version (lates master source build)
no crash (dvr config and other issue)
perfectly work with dvb-s (find and map all channel HD and SD)
ONLY DELET OLD .hts folder and
change path of .hts folder init.d scrip
data/.hts
I think no need to compile new execbinary for tvheadend. that is enough
new execbinary
And new tvheandend can record tv channel webm format with xbmc
Second issue
TVHclient play mpeg2 channel hw decode with mxplayer
TVHclient play MPEG4/Avc/h264 hw decode with mxplayer ( only dropped 45 second) but playing perfectly than dvdplayer of xbmc.
All with minix X7 rk3188Attached FilesLast edited by taki; 12 October 2014, 15:50.
Hi Taki.
I need your help. I try to compile v4l follow step by sam321 in second post of this topic. I have Ubuntu 12.04 64bit with3.13.0-32-generic and compiled RK3188 kerner with Marvin the Paranoid Android Kernel Builder (https://github.com/phjanderson/marvin). Now I have folder Kernel-3188 with compiled kernel in my home/sax/android/Kernel-3188 directory.
Then I follow steps 5,6 and 7:
5. git clone --depth=1 git://linuxtv.org/media_build.git
cd media_build
6. make download untar
7. make menuconfig ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- SRCDIR=/home/sax/android/Kernel-3188/
and then i get this output:
make -C /home/sax/android/media_build/v4l menuconfig
make[1]: Entering directory `/home/sax/android/media_build/v4l'
No version yet, using 3.13.0-32-generic
make[1]: Leaving directory `/home/sax/android/media_build/v4l'
make[2]: Entering directory `/home/sax/android/media_build/linux'
Applying patches for kernel 3.13.0-32-generic
patch -s -f -N -p1 -i ../backports/api_version.patch
patch -s -f -N -p1 -i ../backports/pr_fmt.patch
patch -s -f -N -p1 -i ../backports/debug.patch
patch -s -f -N -p1 -i ../backports/drx39xxj.patch
patch -s -f -N -p1 -i ../backports/v3.16_netdev.patch
patch -s -f -N -p1 -i ../backports/v3.16_wait_on_bit.patch
Patched drivers/media/dvb-core/dvbdev.c
Patched drivers/media/v4l2-core/v4l2-dev.c
Patched drivers/media/rc/rc-main.c
make[2]: Leaving directory `/home/sax/android/media_build/linux'
./scripts/make_kconfig.pl /home/sax/android/Kernel-3188/ /home/sax/android/Kernel-3188/
Preparing to compile for kernel version 3.13.0
WARNING: This is the V4L/DVB backport tree, with experimental drivers
backported to run on legacy kernels from the development tree at:
http://git.linuxtv.org/media-tree.git.
It is generally safe to use it for testing a new driver or
feature, but its usage on production environments is risky.
Don't use it in production. You've been warned.
RC_ST: Requires at least kernel 3.15.0
Created default (all yes) .config file
/home/sax/android/Kernel-3188//scripts/kconfig/mconf ./Kconfig
./Kconfig:718: unknown option "Say"
./Kconfig:719: unknown option "which"
./Kconfig:720: unknown option "The"
./Kconfig:722:warning: multi-line strings not supported
./Kconfig:722: unknown option "If"
make[1]: *** [menuconfig] Error 1
make: *** [menuconfig] Error 2
And now I'm on dead end. Please help me.
THX SaX
[QUOTE=JoKeRz;202145]Hi Taki - these are the steps I use to compile:
Compilation
1) Get kernel and compile it
1.1) download the kernel source of your preference. For 4.2.2 I use phjanderson_Kernel-3188.
1.2) Compile the kernel source. You need to have a good .config file in the root of the kernel directory. b
select all dvb driver with driver menu
make menuconfig ARCH=arm CROSS_COMPILE=arm-linux-gnueabi-[/CODE]
later
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi-[/CODE]
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- modues[/CODE]
2) Get the v4l package and compile it
2.1) download video4linux:
Code:git clone --depth=1 git://linuxtv.org/media_build.git
Code:cd media_build make download untar
Code:make menuconfig ARCH=arm CROSS_COMPILE:=/path to your toolchain/ SRCDIR=/home/sax/android/Kernel-3188
2.4) Compile v4l
Code:make ARCH=arm CROSS_COMPILE:=/path to your toolchain/ SRCDIR=/home/sax/android/Kernel-3188
Code:make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- SRCDIR=/home/r/
sax use this method. different only your kernel sorce and config
THX Taki, but I still have problem when I try to
Here is my whole procedure (I have already compile Kernel-3188)
(Commands are marked bold and strange output and error are marked as bold and Italic):
sax@ubuntu:~/android$ git clone --depth=1 git://linuxtv.org/media_build.git
Cloning into 'media_build'...
remote: Counting objects: 134, done.
remote: Compressing objects: 100% (122/122), done.
remote: Total 134 (delta 13), reused 71 (delta 7)
Receiving objects: 100% (134/134), 181.85 KiB, done.
Resolving deltas: 100% (13/13), done.
sax@ubuntu:~/android$ cd media_build/
sax@ubuntu:~/android/media_build$ make download untar
make -C linux/ download untar
make[1]: Entering directory `/home/sax/android/media_build/linux'
wget http://linuxtv.org/downloads/drivers...ST.tar.bz2.md5 -O linux-media.tar.bz2.md5.tmp
--2014-10-19 22:45:55-- http://linuxtv.org/downloads/drivers...ST.tar.bz2.md5
Resolving linuxtv.org (linuxtv.org)... 130.149.80.248
Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 101 [application/x-bzip2]
Saving to: `linux-media.tar.bz2.md5.tmp'
100%[======================================>] 101 --.-K/s in 0s
2014-10-19 22:45:55 (10.2 MB/s) - `linux-media.tar.bz2.md5.tmp' saved [101/101]
cat: linux-media.tar.bz2.md5: No such file or directory
--2014-10-19 22:45:55-- http://linuxtv.org/downloads/drivers...LATEST.tar.bz2
Length: 5094787 (4.9M) [application/x-bzip2]
Saving to: `linux-media.tar.bz2'
100%[======================================>] 5,094,787 536K/s in 9.9s
2014-10-19 22:46:05 (503 KB/s) - `linux-media.tar.bz2' saved [5094787/5094787]
tar xfj linux-media.tar.bz2
rm -f .patches_applied .linked_dir .git_log.md5
make[1]: Leaving directory `/home/sax/android/media_build/linux'
--2014-10-19 22:46:09-- http://linuxtv.org/downloads/drivers...ST.tar.bz2.md5
2014-10-19 22:46:09 (12.9 MB/s) - `linux-media.tar.bz2.md5.tmp' saved [101/101]
sax@ubuntu:~/android/media_build$ make menuconfig ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- SRCDIR=/home/sax/android/Kernel-3188
./scripts/make_kconfig.pl /home/sax/android/Kernel-3188 /home/sax/android/Kernel-3188
/home/sax/android/Kernel-3188/scripts/kconfig/mconf ./Kconfig
first unpack ndk
for example tar -xvf android-ndk-r9c.tar.bz2
later create folder this
home/yourusername/android-ndk-r9c
later use thsi cript script (for 64 bit)
perl buildndk
Code:#!/bin/bash export ANDROID_NDK=android-ndk-r9c export ANDROID_NDK_TOOLCHAIN_ROOT=android-toolchain-14a $ANDROID_NDK/build/tools/make-standalone-toolchain.sh \ --system=linux-x86_64 \ --toolchain=arm-linux-androideabi-4.6 \ --platform=android-14 \ --install-dir=$ANDROID_NDK_TOOLCHAIN_ROOT
/home/yourusername/android-toolchain-14a
donwload mumudvb source unpack
/home/yourusername/mumudvb
here is mumudvb build script
Code:#!/bin/sh # Build script to android. Change the variables on "Path block" to the correct path. # Path block ANDROID_NDK=/home/new/android-toolchain-14a # Android NDK path SRC_DIR=/home/new/mumudvb # Path to MuMuDVB source INSTALL_DIR=/home/new/mumudvb/out # Path to android MuMuDVB install INCLUDE_DIR=$ANDROID_NDK/sysroot/usr/include # Path to linux/dvb headers (obrigatory) and iconv.h LIB_DIR=$ANDROID_NDK/sysroot/usr/lib # Path to libiconv.a (optional) export PATH="$ANDROID_NDK/bin/:$PATH" export SYS_ROOT="$ANDROID_NDK/sysroot/" export CC="arm-linux-androideabi-gcc --sysroot=$SYS_ROOT" export CXX="arm-linux-androideabi-g++ --sysroot=$SYS_ROOT" export CPP="arm-linux-androideabi-cpp --sysroot=$SYS_ROOT" export LD="arm-linux-androideabi-ld" export AR="arm-linux-androideabi-ar" export RANLIB="arm-linux-androideabi-ranlib" export STRIP="arm-linux-androideabi-strip" export LDFLAGS="-L$LIB_DIR" export CFLAGS="-I$INCLUDE_DIR" export LIBS="-lc -lgcc -liconv" ./configure --host=arm-eabi --enable-android --enable-coverage --enable-scam-support --enable-tune_old --enable-duma --prefix=$INSTALL_DIR make make install
if you look pthread_cancel erro. I dont know how to fix it for cw. but you use disable-scam-support
Just been reading through this thread and I understand half of it. Can someone answer my question to see if it's possible.
I have minix neo x8 and the only thing missing from this beauty of a device is tuners. Is it now possible to use a usb tuner connected with the x8, run xbmc and receive live tv (and ability to watch one channel record the other?).
Are things like ccams going to work with this type of setup?. This is exactly what I want, an android based powerful box with abaility to use tuners. I am looking at a evo xfinity box if this cannot work.
What your kernel. I can compile tvheadend for x8 android
Which you want use dvb usb tuner.
good dvb android evo xfinity box. use tvheadend and mpeg2 and avc mpeg 4 part on works like enigma2 with xbmc. but single core and mali mp400 Hisislicone. x8 powerfull than Hisislicone.
Hi taki
can upload to me driver for dvbsky s960 & last tvheadend
Minix 7 & FW10
here my info
2|root@android:/ # dmesg | grep -i dvb
<4>[ 74.073858] dvb_usb_digitv: Unknown symbol dvb_usb_generic_rw (err 0)
<4>[ 74.073972] dvb_usb_digitv: Unknown symbol dvb_usb_device_init (err 0)
<4>[ 74.074048] dvb_usb_digitv: Unknown symbol dvb_usb_device_exit (err 0)
<4>[ 74.074091] dvb_usb_digitv: Unknown symbol dvb_usb_generic_write (err 0)
<4>[ 74.666820] em28xx_dvb: Unknown symbol dvb_dmxdev_init (err 0)
<4>[ 74.666912] em28xx_dvb: Unknown symbol em28xx_write_reg (err 0)
<4>[ 74.666986] em28xx_dvb: Unknown symbol em28xx_stop_urbs (err 0)
<4>[ 74.667075] em28xx_dvb: Unknown symbol em28xx_gpio_set (err 0)
<4>[ 74.667137] em28xx_dvb: Unknown symbol em28xx_set_mode (err 0)
<4>[ 74.667183] em28xx_dvb: Unknown symbol dvb_register_adapter (err 0)
<4>[ 74.667256] em28xx_dvb: Unknown symbol em28xx_alloc_urbs (err 0)
<4>[ 74.667343] em28xx_dvb: Unknown symbol dvb_dmx_release (err 0)
<4>[ 74.667407] em28xx_dvb: Unknown symbol em28xx_uninit_usb_xfer (err 0)
<4>[ 74.667537] em28xx_dvb: Unknown symbol em28xx_write_reg_bits (err 0)
<4>[ 74.667646] em28xx_dvb: Unknown symbol em28xx_unregister_extension (err 0)
<4>[ 74.667699] em28xx_dvb: Unknown symbol dvb_net_init (err 0)
<4>[ 74.667744] em28xx_dvb: Unknown symbol dvb_dmx_swfilter (err 0)
<4>[ 74.667791] em28xx_dvb: Unknown symbol dvb_dmxdev_release (err 0)
<4>[ 74.667842] em28xx_dvb: Unknown symbol dvb_frontend_detach (err 0)
<4>[ 74.667883] em28xx_dvb: Unknown symbol dvb_net_release (err 0)
<4>[ 74.667935] em28xx_dvb: Unknown symbol em28xx_register_extension (err 0)
<4>[ 74.667994] em28xx_dvb: Unknown symbol dvb_unregister_frontend (err 0)
<4>[ 74.668058] em28xx_dvb: Unknown symbol em28xx_init_usb_xfer (err 0)
<4>[ 74.668098] em28xx_dvb: Unknown symbol em28xx_tuner_callback (err 0)
<4>[ 74.668156] em28xx_dvb: Unknown symbol dvb_frontend_resume (err 0)
<4>[ 74.668197] em28xx_dvb: Unknown symbol dvb_register_frontend (err 0)
<4>[ 74.668255] em28xx_dvb: Unknown symbol dvb_frontend_suspend (err 0)
<4>[ 74.668295] em28xx_dvb: Unknown symbol em28xx_setup_xc3028 (err 0)
<4>[ 74.668345] em28xx_dvb: Unknown symbol em28xx_free_device (err 0)
<4>[ 74.668387] em28xx_dvb: Unknown symbol dvb_unregister_adapter (err 0)
<4>[ 74.668483] em28xx_dvb: Unknown symbol dvb_dmx_init (err 0)
[1] + Done (1) dmesg |
Done (2) grep -i
root@android:/ #Last edited by nayef; 01 December 2014, 13:14.
Hi Taki I really admire your work!
I have a similar box to the Minix Neo 8 - a S802 chip based M8 (square box) running kernel 3.10.33. The source code is available from http://openlinux.amlogic.com:8000/download/ARM/kernel/. My box is 2GB ram and K200 config.
I have 2 usb tuners IT9135 and rtl2832u.
I would really appreciate if you could compile tvheadend for my M*
ThanksLast edited by sd26; 01 December 2014, 11:51.
There are currently 3079 users online. 0 members and 3079 guests.
