live TV for all rk3188 using XBMC and tvheadend
Zaapa ZT-MINDVBZP (RTL2832U) + T-R42 v2.0 (rk3188)
hi to all
First of all I want to thanks the job done by taky and sam321!. Thanks a lot!
I've read all the thread and i need a little help... I've a rk3188 stb (T-R42 v2.0, with wasser fw jb 4.2.2 (my kernel is 720p: http://www.freak-tab.de/wasser/kernel-wasser-t_r42_new-1.2.5.zip)) and a dvb-t usb stick "Zaapa ZT-MINDVBZP", I think with RTL2832U chip.
I think I need to build my own driver, or maybe i can use a pre builted one... And here is my problem, I'm pretty lost here...
Are there precompiled drivers for this dvb-t? Or could someone help me with this?
Originally posted by taki View Postfailed (File exists)=modules already loaded. no load again
pls open terminal write su
later write
dmesg | grep -i dvb
and dmesg
126|root@android:/ # dmesg | grep -i dvb
<6>[ 72.163416] usbcore: registered new interface driver dvb_usb_ttusb2
<6>[ 72.232954] usbcore: registered new interface driver dvb_usb_technisat_usb2
and later full dmesg send
dmesg > /sdcard/dmesg.txt
go to sdcard copy dmesg txt and send forum
Originally posted by taki View Postopen termnal and write lsmod (you can see which modul loaded)
later write dmesg dvb work or not
Code:u0_a82@android:/ $ su root@android:/ # lsmod dvb_usb_technisat_usb2 7998 0 - Live 0x00000000 dvb_usb_ttusb2 14320 0 - Live 0x00000000 stv6110x 4151 0 - Live 0x00000000 stv6110 4069 0 - Live 0x00000000 stv090x 44153 1 dvb_usb_technisat_usb2, Live 0x00000000 stv0900 48413 0 - Live 0x00000000 dvb_usb 18179 2 dvb_usb_technisat_usb2,dvb_usb_ttusb2, Live 0x00000000 dvb_pll 8282 0 - Live 0x00000000 dvb_core 73999 3 dvb_usb_technisat_usb2,dvb_usb_ttusb2,dvb_usb, Live 0x00000000 vpu_service 11639 0 - Live 0x00000000 rk29_ipp 9957 0 - Live 0x00000000 (C) mali 112485 7 - Live 0x00000000 ump 27320 19 mali, Live 0x00000000 rk30xxnand_ko 314328 0 - Live 0x00000000
everthing ok. you must be create . dmesg later find your tuner and loadded firmware.fw
mkdir /dev/dvb
mkdir /data/dvb/.hts
mkdir /data/dvb/.hts/imagecache
mkdir /dev/dvb/adapter0
ln -s /dev/dvb0.frontend0 /dev/dvb/adapter0/frontend0
ln -s /dev/dvb0.demux0 /dev/dvb/adapter0/demux0
ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0
ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0.ts
ln -s /dev/dvb0/ca0 /dev/dvb/adapter0/ca0
mkdir /dev/dvb/adapter1
ln -s /dev/dvb1.frontend0 /dev/dvb/adapter1/frontend0
ln -s /dev/dvb1.demux0 /dev/dvb/adapter1/demux0
ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0
ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0.ts
ln -s /dev/dvb1/ca0 /dev/dvb/adapter1/ca0
mkdir /tmp/virtual_adapter
and looked usefull link
I think will be work %100on android
Originally posted by taki View Posteverthing ok. you must be create . dmesg later find your tuner and loadded firmware.fw
mkdir /dev/dvb
file already exists ...
no have: /dev/dvb1 & /dev/dvb0
There are currently 2413 users online. 5 members and 2408 guests.
