live TV for all rk3188 using XBMC and tvheadend
Originally posted by taki View PostDmesg not found skystar .thus everting ok but we have to search for driver.
Why dont create dev/dvb¿
/dev/dvb ...
/tmp/virtual_adapter ...
and set 777
i don't why "mkdir" not working in "/tmp" ? and after restart not found ?
something wrong
no need tmp folder and virtusl adapter
you use
mkdir /dev/dvb
mkdir /data/dvb/.hts
mkdir /data/dvb/.hts/imagecache
mkdir /dev/dvb/adapter0
ln -s /dev/dvb0.frontend0 /dev/dvb/adapter0/frontend0
ln -s /dev/dvb0.demux0 /dev/dvb/adapter0/demux0
ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0
ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0.ts
ln -s /dev/dvb0/ca0 /dev/dvb/adapter0/ca0
mkdir /dev/dvb/adapter1
ln -s /dev/dvb1.frontend0 /dev/dvb/adapter1/frontend0
ln -s /dev/dvb1.demux0 /dev/dvb/adapter1/demux0
ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0
ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0.ts
must be create on boot thus need init.d
all modul loaded later automatic loading dvb-usb-SkyStar_USB_HD_FW_v17_63.HEX.fw firmware fw.
you can look dmesg. you can see
usb 1-1: new high-speed USB device number 2 using ehci-brcm
technisat-usb2: set alternate setting
dvb-usb: found a 'Technisat SkyStar USB HD (DVB-S/S2)' in cold state, will try to load a firmware
dvb-usb: downloading firmware from file 'dvb-usb-SkyStar_USB_HD_FW_v17_63.HEX.fw'
usbcore: registered new interface driver dvb_usb_technisat_usb2
usb 1-1: USB disconnect, device number 2
dvb-usb: generic DVB-USB module successfully deinitialized and disconnected.
usb 1-1: new high-speed USB device number 3 using ehci-brcm
technisat-usb2: firmware version: 17.63
dvb-usb: found a 'Technisat SkyStar USB HD (DVB-S/S2)' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (Technisat SkyStar USB HD (DVB-S/S2))
stv6110x_attach: Attaching STV6110x
usb 1-1: DVB: registering adapter 2 frontend 0 (Technisat SkyStar USB HD (DVB-S/S2))...
dvb-usb: Technisat SkyStar USB HD (DVB-S/S2) successfully initialized and connected.
Originally posted by taki View Postno need tmp folder and virtusl adapter
you use
mkdir /dev/dvb
my dvbs2 : "Technisat SkyStar USB 2" not "Technisat SkyStar USB HD"
maybe can't start with dvb-usb-SkyStar_USB_HD_FW_v17_63.HEX.fw
Originally posted by nayef View Posthello
can "Technisat SkyStar USB DVB-s2" working on Minix X7 ?
driver Linux i think here http://linuxtv.org/wiki/index.php/Te...SkyStar_USB_HD
i'am use last fw from Minix ...
any one can help me ?
has cı you device??? (cam slot)
I search modul for usb2)))))))
you have on board photos. whic chip used
here last lsmod & dmesg for i dvb:
root@android:/ # lsmod | grep -i dvb
dvb_usb_technisat_usb2 7998 0 - Live 0x00000000
dvb_usb_ttusb2 14320 0 - Live 0x00000000
stv090x 44153 1 dvb_usb_technisat_usb2, Live 0x00000000
dvb_usb 18179 2 dvb_usb_technisat_usb2,dvb_usb_ttusb2, Live 0x00000000
dvb_pll 8282 0 - Live 0x00000000
dvb_core 73999 3 dvb_usb_technisat_usb2,dvb_usb_ttusb2,dvb_usb, Live 0x00000000
root@android:/ # dmesg | grep -i dvb
<6>[ 67.363423] usbcore: registered new interface driver dvb_usb_ttusb2
<6>[ 67.429598] usbcore: registered new interface driver dvb_usb_technisat_usb2
root@android:/ #
Originally posted by nayef View Posthere photo
you load this modul later log dmesg (insmod other modul you know
insmod b2c2-flexcop.ko
insmod b2c2-flexcop-usb.ko
must be this device http://www.linuxtv.org/wiki/index.ph...B_/_Sky2PC_USB
or tuner demodulator
The following drivers are needed for this device:
- stv0299.ko or mt312.ko - b2c2-flexcop.ko - b2c2-flexcop-usb.ko
insmod stv0299.ko
insmod mt312.ko
Originally posted by taki View PostI think tahat you have old usb sksytar usb and only support dvbs no s2
my box support s2 and HD channel with driver windows
Originally posted by taki View Postmust be this device http://www.linuxtv.org/wiki/index.ph...B_/_Sky2PC_USB
insmod stv0299.ko
insmod mt312.ko
not have stv0299.ko or mt312.ko
There are currently 1980 users online. 1 members and 1979 guests.
