22#ifndef AF9035_H 23#define AF9035_H 24 25#include "dvb_usb.h" 26#include "af9033.h" 27#include "tua9001.h" 28#include "fc0011.h" 29#include "fc0012.h" 30#include "mxl5007t.h" 31#include "tda18218.h" 32#include "fc2580.h" 33#include "tuner_it913x.h"
live TV for all rk3188 using XBMC and tvheadend
Originally posted by izitoon View PostI rename the extracted file to dvb-usb-it9135-01.fw and pasted to the firmware folder
rebooted and tested tvheadend, nothing device there.
whit terminal: DVB: Unable to find symbol af9033_attach()
open terminal
modprope /system/lib/modules/af9033.ko
modprope /system/lib/modules/tuner_it913x.ko
later try dmesg| grep dvb
may be no give error DVB: Unable to find symbol af9033_attach()
because look post 34 of this topic
Hello
modprope /system/lib/modules/af9033.ko and modprope /system/lib/modules/tuner_it913x.ko get me "tmp-mksh: modprope: not found".
modprobe /system/lib/modules/af9033.ko and modprobe /system/lib/modules/tuner_it913x.ko get me "modprobe: chdir(/lib/modules): no such file or directory"
dmesg | grep dvb = no errors, whit dmesg | grep -i dvb = dvb: unable to find symbol af9033_attach()
in tvheadend no device
It`s possible to take working dvb files from ubuntu and compile to android?
Originally posted by woomg View PostGreat News, Taki!!
You can build it immediately from now on...
Then I can focus to other issues...
tvheadend developer said that tryed ndk r9c gcc 4.6. I dont know that rk3188 kernel support. I will try later report in this topic
that is this topic
Originally posted by woomg View PostMain difference is kernel version. If RK3188's kernel is 3.0.x, you can not use NDK 9.
Sent from my iPhone using TapatalkI try to activate dbus that need expat library. but dont find example script
There are currently 3967 users online. 0 members and 3967 guests.
