live TV for all rk3188 using XBMC and tvheadend
      ok after copy to system/lib/modules and insmod ...
      u0_a82@android:/ $ su
      root@android:/ # lsmod | grep -i dvb
      dvb_usb_technisat_usb2 7998 0 - Live 0x00000000
      dvb_usb_ttusb2 14320 0 - Live 0x00000000
      stv090x 44153 1 dvb_usb_technisat_usb2, Live 0x00000000
      dvb_usb 18179 2 dvb_usb_technisat_usb2,dvb_usb_ttusb2, Live 0x00000000
      dvb_pll 8282 0 - Live 0x00000000
      dvb_core 73999 5 stv0299,cxd2820r,dvb_usb_technisat_usb2,dvb_usb_tt usb2,dvb_usb, Live 0x00000000
      root@android:/ # dmesg | grep -i dvb
      <6>[ 67.363423] usbcore: registered new interface driver dvb_usb_ttusb2
      <6>[ 67.429598] usbcore: registered new interface driver dvb_usb_technisat_usb2
      <4>[69724.772729] dvb_usb_cxusb: Unknown symbol dib7000p_set_gpio (err 0)
      <4>[69724.772827] dvb_usb_cxusb: Unknown symbol dib7000p_get_i2c_master (err 0)
      <4>[69724.773006] dvb_usb_cxusb: Unknown symbol dib7000p_i2c_enumeration (err 0)
      <4>[69724.773101] dvb_usb_cxusb: Unknown symbol dib7000p_set_wbd_ref (err 0)
      <4>[69724.773142] dvb_usb_cxusb: Unknown symbol dib0070_wbd_offset (err 0)
      <4>[69862.522203] dvb_usb_cxusb: Unknown symbol dib7000p_set_gpio (err 0)
      <4>[69862.523157] dvb_usb_cxusb: Unknown symbol dib7000p_get_i2c_master (err 0)
      <4>[69862.523441] dvb_usb_cxusb: Unknown symbol dib7000p_i2c_enumeration (err 0)
      <4>[69862.523606] dvb_usb_cxusb: Unknown symbol dib7000p_set_wbd_ref (err 0)
      <4>[69862.523765] dvb_usb_cxusb: Unknown symbol dib0070_wbd_offset (err 0)
      <4>[70100.516833] dvb_usb_cxusb: Unknown symbol dib7000p_set_gpio (err 0)
      <4>[70100.516909] dvb_usb_cxusb: Unknown symbol dib7000p_get_i2c_master (err 0)
      <4>[70100.517016] dvb_usb_cxusb: Unknown symbol dib7000p_i2c_enumeration (err 0)
      <4>[70100.517072] dvb_usb_cxusb: Unknown symbol dib7000p_set_wbd_ref (err 0)
      <4>[70100.517136] dvb_usb_cxusb: Unknown symbol dib0070_wbd_offset (err 0)
      root@android:/ #
        TechniSat_SkyStar_USB
        Originally posted by taki View Post
        must be this device http://www.linuxtv.org/wiki/index.ph...B_/_Sky2PC_USB
        or tuner demodulator
        The following drivers are needed for this device:
        - stv0299.ko or mt312.ko - b2c2-flexcop.ko - b2c2-flexcop-usb.ko
        insmod stv0299.ko
        insmod mt312.ko
        i think this : http://www.linuxtv.org/wiki/index.ph..._SkyStar_USB_2
        so there 4 Box From TechniSat:
        1- TechniSat SkyStar USB (USB1.1):
        1- TechniSat DVB-S Skystar USB (2) :
        3- TechniSat DVB-S2 Skystar USB HD :
        3- TechniSat DVB-S2 Skystar USB HD CI
          TVHeadend Android Patch for 3.9.1083
          Hi Taki,
          Long time no see^^;; I just got some time to involve this and, will try to coding for transcoder using MediaCodec. Of course... just try....
          Here is patch for 3.9.1083 version.
          MG.
            Originally posted by woomg View Post
            Hi Taki,
            MG.
            Big thanks will wait your improvement
              you must be identifi What tuner chip used
                [ATTACH=CONFIG]7190[/ATTACH]
                i open this box and i have 2 chip small :
                1- conexant
                QPSK DEMOD
                CX24123-11Z
                PGY10231AA
                0815 CHINA
                2- conexant
                24113A-12Z (or 7)
                81041027
                0817 KOREA
                For USB Chip :
                PLX
                NET2282-AB33PC F
                0811 C
                L35 JAPAN
                Big Chip :
                TechniSat
                Licensed by B2C2.Inc
                FLEXCOP IIB
                MQCFM-000
                0816
                  1- conexant
                  QPSK DEMOD
                  CX24123-11Z
                  PGY10231AA
                  0815 CHINA
                  2- conexant
                  24113A-12Z (or 7)
                  81041027
                  0817 KOREA
                  For USB Chip :
                  PLX
                  NET2282-AB33PC F
                  0811 C
                  L35 JAPAN
                  Big Chip :
                  TechniSat
                  FLEXCOP IIB
                  MQCFM-000
                  0816
                  exactly your modules
                  CX24123.ko
                  CX24113.ko
                  b2c2-flexcop-usb.ko
                  b2c2-flexcop.ko
                  copy paste and send us dmesg (dmesg | grep dvb , dmesg | grep -i usb) log
                    CX24123.ko
                    CX24113.ko
                    b2c2-flexcop-usb.ko
                    b2c2-flexcop.ko
                    http://www76.zippyshare.com/v/93386042/file.html
                    must delete old modules ?
                      Yes. delete old modules. new zip has init.d folder new script
                      #!/system/bin/sh
                      # DVB-T
                      while [ ""`getprop dev.bootcomplete` != "1" ] ; do sleep 1; done
                      insmod /system/lib/modules/dvb-core.ko
                      insmod /system/lib/modules/dvb-pll.ko
                      insmod /system/lib/modules/dvb-usb.ko force_pid_filter_usage=1
                      insmod /system/lib/modules/dvb-usb-ttusb2.ko
                      insmod /system/lib/modules/dvb-usb-technisat-usb2.ko
                      insmod /system/lib/modules/b2c2-flexcop-usb.ko
                      insmod /system/lib/modules/b2c2-flexcop.ko
                      insmod /system/lib/modules/cx24123.ko
                      insmod /system/lib/modules/cx24113.ko
                      insmod /system/lib/modules/isl6421.ko
                      insmod /system/lib/modules/rc-core.ko
                      sleep 1
                      mkdir /dev/dvb
                      mkdir /data/dvb/.hts
                      mkdir /data/dvb/.hts/imagecache
                      mkdir /dev/dvb/adapter0
                      ln -s /dev/dvb0.frontend0 /dev/dvb/adapter0/frontend0
                      ln -s /dev/dvb0.demux0 /dev/dvb/adapter0/demux0
                      ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0
                      ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0.ts
                      ln -s /dev/dvb0/ca0 /dev/dvb/adapter0/ca0
                      mkdir /dev/dvb/adapter1
                      ln -s /dev/dvb1.frontend0 /dev/dvb/adapter1/frontend0
                      ln -s /dev/dvb1.demux0 /dev/dvb/adapter1/demux0
                      ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0
                      ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0.ts
                      ln -s /dev/dvb1/ca0 /dev/dvb/adapter1/ca0
                      chmod 777 /data/dvb/.hts
                      chmod 777 /data/dvb/.hts/imagecache
                      chmod 777 /data/dvb*
                      chmod 777 /data/dvb/tvheadend
                      ./data/dvb/tvheadend -C -c /data/dvb/.hts
                      # done
                        root@android:/ # dmesg | grep dvb
                        <6>[ 68.623759] usbcore: registered new interface driver dvb_usb_ttusb2
                        <4>[ 68.684368] dvb_usb_technisat_usb2: Unknown symbol stv090x_set_gpio (err 0)
                        root@android:/ # dmesg | grep -i usb
                        <6>[ 0.439683] usbcore: registered new interface driver usbfs
                        <6>[ 0.439795] usbcore: registered new interface driver hub
                        <6>[ 0.454050] usbcore: registered new device driver usb
                        <6>[ 1.002470] usbcore: registered new interface driver r8152
                        <6>[ 1.002521] usbcore: registered new interface driver asix
                        <6>[ 1.002571] usbcore: registered new interface driver cdc_ether
                        <6>[ 1.002621] usbcore: registered new interface driver dm9620
                        <6>[ 1.002670] usbcore: registered new interface driver SR9700_android
                        <6>[ 1.002726] usbcore: registered new interface driver net1080
                        <6>[ 1.002774] usbcore: registered new interface driver cdc_subset
                        <6>[ 1.002825] usbcore: registered new interface driver zaurus
                        <6>[ 1.002898] usbcore: registered new interface driver cdc_ncm
                        <6>[ 1.002987] Initializing USB Mass Storage driver...
                        <6>[ 1.003038] usbcore: registered new interface driver usb-storage
                        <6>[ 1.003074] USB Mass Storage support registered.
                        <6>[ 1.003154] usbcore: registered new interface driver usbserial
                        <6>[ 1.003205] USB Serial support registered for generic
                        <6>[ 1.003261] usbcore: registered new interface driver usbserial_generic
                        <6>[ 1.003299] usbserial: USB Serial Driver core
                        <6>[ 1.003338] USB Serial support registered for GSM modem (1-port)
                        <6>[ 1.003393] usbcore: registered new interface driver option
                        <6>[ 1.003425] option: v0.7.2:USB Driver for GSM modems
                        <6>[ 1.003468] USB Serial support registered for usi-modem
                        <6>[ 1.003514] usbcore: registered new interface driver usi-modem
                        <6>[ 1.225779] usb20_otg usb20_otg: DWC OTG Controller
                        <6>[ 1.225875] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
                        <6>[ 1.225939] usb20_otg usb20_otg: irq 48, io mem 0x00000000
                        <6>[ 1.226085] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
                        <6>[ 1.226124] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                        <6>[ 1.226167] usb usb1: Product: DWC OTG Controller
                        <6>[ 1.226195] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
                        <6>[ 1.226228] usb usb1: SerialNumber: usb20_otg
                        <6>[ 1.226515] hub 1-0:1.0: USB hub found
                        <6>[ 1.439701] usb20_host usb20_host: DWC OTG Controller
                        <6>[ 1.439760] usb20_host usb20_host: new USB bus registered, assigned bus number 2
                        <6>[ 1.439823] usb20_host usb20_host: irq 49, io mem 0x00000000
                        <6>[ 1.439966] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
                        <6>[ 1.440003] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                        <6>[ 1.440043] usb usb2: Product: DWC OTG Controller
                        <6>[ 1.440070] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
                        <6>[ 1.440101] usb usb2: SerialNumber: usb20_host
                        <6>[ 1.440362] hub 2-0:1.0: USB hub found
                        <6>[ 1.513645] android_usb gadget: Mass Storage Function, version: 2009/09/11
                        <6>[ 1.513690] android_usb gadget: Number of LUNs=2
                        <6>[ 1.513923] android_usb gadget: android_usb ready
                        <6>[ 1.514295] usbcore: registered new interface driver xpad
                        <6>[ 1.514355] usbcore: registered new interface driver usb_acecad
                        <6>[ 1.514388] acecad: v3.2:USB Acecad Flair tablet driver
                        <6>[ 1.514437] usbcore: registered new interface driver aiptek
                        <6>[ 1.514467] aiptek: v2.3 (May 2, 2007):Aiptek HyperPen USB Tablet Driver (Linux 2.6.x)
                        <6>[ 1.514567] usbcore: registered new interface driver gtco
                        <4>[ 1.514596] GTCO usb driver version: 2.00.0006
                        <6>[ 1.514640] usbcore: registered new interface driver hanwang
                        <6>[ 1.514692] usbcore: registered new interface driver kbtab
                        <6>[ 1.514722] kbtab: v0.0.2:USB KB Gear JamStudio Tablet driver
                        <6>[ 1.514773] usbcore: registered new interface driver wacom
                        <6>[ 1.514807] wacom: v1.52:USB Wacom tablet driver
                        <6>[ 1.523059] usbcore: registered new interface driver uvcvideo
                        <6>[ 1.523090] USB Video Class driver (v1.1.0)
                        <6>[ 1.570902] usbcore: registered new interface driver usbhid
                        <6>[ 1.570934] usbhid: USB HID core driver
                        <6>[ 1.718078] usbcore: registered new interface driver snd-usb-audio
                        <6>[ 1.829505] usb 2-1: new high speed USB device number 2 using usb20_host
                        <6>[ 2.039730] usb 2-1: New USB device found, idVendor=0424, idProduct=2514
                        <6>[ 2.039760] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                        <6>[ 2.040149] hub 2-1:1.0: USB hub found
                        <6>[ 2.319612] usb 2-1.1: new high speed USB device number 3 using usb20_host
                        <6>[ 2.420614] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=8152
                        <6>[ 2.420650] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        <6>[ 2.420705] usb 2-1.1: Product: USB 10/100 LAN
                        <6>[ 2.420735] usb 2-1.1: Manufacturer: Realtek
                        <6>[ 2.421656] usb 2-1.1: SerialNumber: 10000021B64D
                        <6>[ 2.423181] cdc_ether 2-1.1:2.0: eth0: register 'cdc_ether' at usb-usb20_host-1.1, CDC Ethernet Device, 10:00:00:21:b6:4d
                        <6>[ 2.423883] cdc_ether 2-1.1:2.0: eth0: unregister 'cdc_ether' usb-usb20_host-1.1, CDC Ethernet Device
                        <6>[ 2.499601] usb 2-1.2: new low speed USB device number 4 using usb20_host
                        <6>[ 2.603913] usb 2-1.2: New USB device found, idVendor=15d9, idProduct=0a4c
                        <6>[ 2.603962] usb 2-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                        <6>[ 2.604010] usb 2-1.2: Product: USB OPTICAL MOUSE
                        <6>[ 2.608456] input: USB OPTICAL MOUSE as /devices/platform/usb20_host/usb2/2-1/2-1.2/2-1.2:1.0/input/input2
                        <6>[ 2.609652] generic-usb 0003:15D9:0A4C.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-usb20_host-1.2/input0
                        <6>[ 2.679486] usb 2-1.1: reset high speed USB device number 3 using usb20_host
                        <6>[ 2.859485] usb 2-1.3: new full speed USB device number 5 using usb20_host
                        <6>[ 2.970973] usb 2-1.3: New USB device found, idVendor=0c40, idProduct=7a18
                        <6>[ 2.977866] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                        <6>[ 2.985191] usb 2-1.3: Product: SAGE AirMouse
                        <6>[ 2.989561] usb 2-1.3: Manufacturer: SAGE Technology
                        <6>[ 3.000063] input: SAGE Technology SAGE AirMouse as /devices/platform/usb20_host/usb2/2-1/2-1.3/2-1.3:1.0/input/input3
                        <6>[ 3.000940] generic-usb 0003:0C40:7A18.0002: input,hidraw1: USB HID v1.10 Keyboard [SAGE Technology SAGE AirMouse] on usb-usb20_host-1.3/input0
                        <6>[ 3.005255] input: SAGE Technology SAGE AirMouse as /devices/platform/usb20_host/usb2/2-1/2-1.3/2-1.3:1.1/input/input4
                        <6>[ 3.005722] generic-usb 0003:0C40:7A18.0003: input,hidraw2: USB HID v1.10 Mouse [SAGE Technology SAGE AirMouse] on usb-usb20_host-1.3/input1
                        <3>[ 6.018544] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
                        <3>[ 6.149952] android_usb: already disabled
                        <3>[ 6.150163] android_usb: already disabled
                        <4>[ 68.736088] b2c2_flexcop_usb: Unknown symbol flexcop_device_exit (err 0)
                        <4>[ 68.736502] b2c2_flexcop_usb: Unknown symbol flexcop_wan_set_speed (err 0)
                        <4>[ 68.736708] b2c2_flexcop_usb: Unknown symbol flexcop_pass_dmx_packets (err 0)
                        <4>[ 68.736987] b2c2_flexcop_usb: Unknown symbol flexcop_sram_set_dest (err 0)
                        <4>[ 68.737222] b2c2_flexcop_usb: Unknown symbol flexcop_device_kmalloc (err 0)
                        <4>[ 68.737465] b2c2_flexcop_usb: Unknown symbol flexcop_sram_ctrl (err 0)
                        <4>[ 68.737728] b2c2_flexcop_usb: Unknown symbol flexcop_device_kfree (err 0)
                        <4>[ 68.737906] b2c2_flexcop_usb: Unknown symbol flexcop_device_initialize (err 0)
                        root@android:/ #
                          i have error lsmod
                          1- "b2c2-flexcop.ko + b2c2-flexcop-usb.ko" = No shch file or directory
                          2- "rc-core.ko" = Exce format error
                            all modules compiled s2-liplanian V39
                            needed related modules (1- "b2c2-flexcop.ko + b2c2-flexcop-usb.ko" = No shch file or directory)
                            no need (2- "rc-core.ko" = Exce format error)
                            I send new v4l dvb driver media git. pls
                            try this modules
                              further more İf you connected usb dvb. we can look idVendor=, idProduct= in dmesg. but looked not connected skystar usb2
                              because
                              idVendor 0x13d0, idProduct 0x2282
                              first connect dvb later open terminal write dmesg | grep usb
                              must be on idVendor 0x13d0, idProduct 0x2282
                              if I were you. I setup ubuntu and find whic modul needed my box. later works on android. we can find needed modules with ubuntu.
                                mumudvb works on minix at this time like dvb-t2 but I activate dvb-s
ID:	434213Click image for larger version
