live TV for all rk3188 using XBMC and tvheadend
    Originally posted by dados View Post
    Hi Dennis,
    i have exact the same message in tvheadend.
    There is nothing with your modules, if they are properly loaded, because kernel is also 3.0.6+
    lsmod shows that all modules loaded and dmesg shows DVB: registering adapter 0 frontend 0.
    I think there is a problem with permissions and wasser has to fix it in his next release, if he can.
    Regards
    Daniel
    weird, asked over in the ROM thread, maybe he has an idea
      tvheaden 20.06.2014 new binary and library
      I think no need kitkat kernel that 3.0.36+
      dont create wasser kernel? can you try terminal before tvheadend start
      mkdir /dev/dvb
      mkdir /data/dvb/.hts
      mkdir /dev/dvb/adapter0
      ln -s /dev/dvb0.frontend0 /dev/dvb/adapter0/frontend0
      ln -s /dev/dvb0.demux0 /dev/dvb/adapter0/demux0
      ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0
      ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0.ts
      mkdir /dev/dvb/adapter1
      ln -s /dev/dvb1.frontend0 /dev/dvb/adapter1/frontend0
      ln -s /dev/dvb1.demux0 /dev/dvb/adapter1/demux0
      ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0
      ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0.ts
      touch /tmp/camd.socket
      mkdir /tmp/.oscam
      chmod 777 /tmp/.oscam
      chmod 777 /tmp/camd.socket
      chmod 777 /data/dvb/.hts
      chmod 777 /data/dvb*
      chmod 777 /data/dvb/tvheadend
      touch /tmp/came.socket
        mkdir /dev/dvb
        mkdir /tmp/.oscam
        Tried this. No luck. Still unable to open...
        Code:
        <6>[ 1103.572335] usb 2-1.3: new high speed USB device number 7 using usb20_host
        <6>[ 1103.673003] usb 2-1.3: New USB device found, idVendor=187f, idProduct=0202
        <6>[ 1103.673033] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        <6>[ 1103.673064] usb 2-1.3: Product: MDTV Receiver
        <6>[ 1103.673083] usb 2-1.3: Manufacturer: MDTV Receiver
        <6>[ 1104.282323] smscore_set_device_mode: firmware download success: dvb_nova_12mhz_b0.inp
        <6>[ 1104.282625] DVB: registering new adapter (Siano Nice Digital Receiver)
        <4>[ 1104.283585] DVB: registering adapter 0 frontend 0 (Siano Mobile Digital MDTV Receiver)...
        and
        Code:
        2014-06-20 17:43:02.907 [   INFO] charset: 138 entries loaded
        2014-06-20 17:43:06.916 [  ERROR] linuxdvb: unable to open /dev/dvb/adapter0/frontend0
        2014-06-20 17:43:06.927 [   INFO] epggrab: module eit created
        2014-06-20 17:43:06.927 [   INFO] epggrab: module uk_freesat created
        2014-06-20 17:43:06.927 [   INFO] epggrab: module uk_freeview created
        2014-06-20 17:43:06.927 [   INFO] epggrab: module viasat_baltic created
        2014-06-20 17:43:06.941 [   INFO] epggrab: module opentv-ausat created
        2014-06-20 17:43:06.942 [   INFO] epggrab: module opentv-skyuk created
        2014-06-20 17:43:06.942 [   INFO] epggrab: module opentv-skyit created
        2014-06-20 17:43:06.942 [   INFO] epggrab: module pyepg created
        2014-06-20 17:43:06.942 [   INFO] epggrab: module xmltv created
        2014-06-20 17:43:06.948 [   INFO] epgdb: loaded v2
        2014-06-20 17:43:06.948 [   INFO] epgdb:   channels   0
        2014-06-20 17:43:06.948 [   INFO] epgdb:   brands     0
        2014-06-20 17:43:06.948 [   INFO] epgdb:   seasons    0
        2014-06-20 17:43:06.948 [   INFO] epgdb:   episodes   0
        2014-06-20 17:43:06.948 [   INFO] epgdb:   broadcasts 0
        2014-06-20 17:43:06.948 [   INFO] dvr: Creating new configuration ''
        2014-06-20 17:43:06.948 [WARNING] dvr: Output directory for video recording is not yet configured for DVR configuration "". Defaulting to to "/". This can be changed from the web user interface.
        2014-06-20 17:43:06.949 [ NOTICE] START: HTS Tvheadend version 0.0.0~unknown started, running as PID:3500 UID:0 GID:0, CWD:/ CNF:/storage/emulated/legacy/.hts
        with your first version of tvheadend i get
        Code:
        Jun 20 17:48:51 [   INFO]:START: initialisingJun 20 17:48:51 [   INFO]:charset: 71 entries loaded
        Jun 20 17:48:51 [  ALERT]:dvb: /dev/dvb/adapter0/frontend0: unable to query (err=Invalid argument)
          Pls try minix stock firmware that I used and no problem
            Yes the stock works fine like before
              No one an idea what makes it work with wassers KitKat?
                mkdir /dev/dvb
                mkdir /tmp/.oscam
                H, Taki.
                This weekend I tried again to configure my Minix Neo X7.
                I have flash stock rom (010 versión, last) with XMBC 13.1 for minix (there is a apk file in minix neo x7's support web page), load the drivers (IT9135) and put your 20140620 TVHEADEND versión
                With other versions I always get "connection lost" in XBMC.
                But when I put your 20140620 versión, XBMC reboots. And tvheadend front end doesn't work
                Is there any log that I can check and put here to get some help ?
                I dont mind to get the last versión of tvheadend, but where can I find any information about "conection lost" in XBMC ?
                Thanks a lot.
                Best regards,
                  first 23062014 new exec binary tvheadend
                  most stable
                  try to terminal Why dotn start tvheadend. if tvheadend start. you look tvheadend adapter menu. that can be find.
                    Originally posted by juan3211 View Post
                    H, Taki.
                    Thanks a lot.
                    Best regards,
                    unable stat path error
                    solition=configure tvheadend recoder path and no more error.
                    connection lost=
                    tvheaden and tuner driver dont works
                      Hi Taki,
                      Thanks a lot for your help.
                      I decided to begin again, so I reset minix.
                      I have 010 versión
                      Install "first post" files and dvb-usb-it9135-01.fw and dvb-usb-it9135-02.fw
                      The 02dvb init.d file is like your post 06-20-2014, 06:24 AM in order to save config files in internal memory (see later)
                      Install Uni_init.apk
                      REBOOT and my "su" and "dmesg | grep dvb" show this:
                      usb 2-1.2: dvb_usb_v2: found a 'ITE 9135 Generic' in warm state
                      usb 2-1.2: dvb_usb_v2: will pass the complete MPEG2 trasnport stream to the software demuxer
                      usb 2-1.2: dvb_usb_v2: PID filter enabled by module option
                      usb 2-1.2: dvb_usb_v2: 'ITE 9135 Generic' successfully initialized and connected
                      usbcore: registrered new interface driver dvb_usb_it913x
                      usbcore: registrered new interface driver dvb_usb_af9015
                      dmesg | grep tvh:
                      NOTHING
                      Open localhost:9981 in CHROME
                      Show perfectly.
                      Config in web config page of tvheadend:
                      DVB inputs: select adapter "ITE 9135 Generic_1"
                      Enabled: click it , so .... YES
                      save button
                      Idle scanning is yes by default
                      close device handle whne idle is NO by default
                      the other options: default
                      add dvb network by location .... it finds 37 services in 12 muxes.
                      map dvb services to channels
                      save again this "window"
                      in Services tab apears all dvb channels that "i want".
                      in channel/epg also
                      recording tab: recording system path: I put /mnt/sdcard (only to check) and SAVE
                      timeshift: enabled: NO (default)
                      STATUS TAB:
                      Adapters: ITE 9135 Generic_1 /dev/dvb/adapter0, currently tuned to DTTV: 834,000 kHz, Bandwidth 512Kb/s Bit error rate 639976 , an so on
                      If i click play in any channel, I get a message that I dont have VLC Mozille pligin for your browser
                      I can see also EPG
                      dmesg | grep tvh:
                      NOTHING
                      Terminal emulator: why can I see anything about tvheadend ? Do i have to write any other command ?
                      I have installed VLC for Android Beta
                      Web page "disappears" so I have to reboot, this never happens with clean rom. (may be the reset is isnt a full reset, so I left some libraries of your tvheadend 20062014\system\lib in firmware lib.)
                      Settings has been saved, but not settings of recording tab system path.
                      All the channels are there.
                      The same, I click "play", and can't see anything because i dont have the plugin.
                      Launch XBMC Minix Edition, configure tvheadend as livetv (xbmcminix-armeabi-v7a_13.1_3.apk that is in minix oficial web page)
                      Enabled
                      Power saving enabled: NO, (dafualt)
                      TVHEADEND HTSP CLIENT 1.9.27
                      I dont remember when , but others roms( QSv2) once i could see channels (Little time) in xbmc.
                      Put thheadend of your last version:
                      REBOOT again
                      Now, I can connect with localhost:9981
                      I will reinstall a clean 010 versión room and root it again.
                      But I want to know:
                      what commands I need to check if dvb and thheadend is well "done" ? I want to know if is a dvb problem, tvheadend problem, or xbmc problem.
                      could i record directly with thheadend web page instead with xbmc ?
                      Is there any other program that I can use to see if tvheadend is working or not ?
                      Thanks a lot.
                      My 02dvb file:
                      #!/system/bin/sh
                      # DVB-T
                      while [ ""`getprop dev.bootcomplete` != "1" ] ; do sleep 1; done
                      insmod /system/lib/modules/dvb-core.ko
                      insmod /system/lib/modules/dvb-pll.ko
                      insmod /system/lib/modules/dvb_usb_v2.ko force_pid_filter_usage=1
                      insmod /system/lib/modules/altera-stapl.ko
                      insmod /system/lib/modules/af9013.ko
                      insmod /system/lib/modules/mc44s803.ko
                      insmod /system/lib/modules/mt2060.ko
                      insmod /system/lib/modules/mxl5005s.ko
                      insmod /system/lib/modules/mxl5007t.ko
                      insmod /system/lib/modules/qt1010.ko
                      insmod /system/lib/modules/tda18218.ko
                      insmod /system/lib/modules/tda18271.ko
                      insmod /system/lib/modules/it913x-fe.ko
                      insmod /system/lib/modules/dvb-usb-it913x.ko
                      insmod /system/lib/modules/dvb-usb-af9015.ko
                      sleep 1
                      mkdir /dev/dvb
                      mkdir /tmp/.oscam
                      ./data/dvb/tvheadend -C -c /data/dvb/.hts
                      # done
                        Hi Taki,
                        I have 010 versión
                        dmesg | grep tvh:
                        NOTHING
                        Show perfectly.
                        save button
                        in channel/epg also
                        STATUS TAB:
                        I can see also EPG
                        dmesg | grep tvh:
                        NOTHING
                        Enabled
                        REBOOT again
                        But I want to know:
                        Thanks a lot.
                        ./data/tvheadend -d --stderr Enable debug on stderr
                        ./data/tvheadend -s --syslog Enable debug on stderr
                        I'll consider it, but at the moment that option (as I've already said) is not intended to be set permanently. If you really need to set it permanently then you have the option by setting the appropriate command line options, but I'm rather concerned about it being permanently set through the UI.
                        Look at output from --help, and specifically the --debug and --trace options.
                        Select --stderr, -l OR -s by default (for compatibility) will always add the equivalent of --debug all. Though you can override with --debug option.
                        unfortunately lestest compiled tvheadend give me [ ERROR] tcp: bind: *: Address already in use
                        and no record save tuner setup and no usable diseq options.
                        lates git changed alot of devolping. check this
                        Permission to access video adapters
                        In order for Tvheadend to control video adapters on the system it must be granted access to those devices. Most systems have a 'video' group with write access to the video adapter devices. When Tvheadend is started as a daemon (if Tvheadend is installed from a distribution package this is most likely the way it is) it will change its primary group to 'video' in order to access these groups. If your system is configured in a different way you can either change the group membership of the video adapters (/dev/dvb, etc) or reconfigure the Tvheadend start up parameters.
                        If Tvheadend is started without the '-f' argument it will not demonize nor change its primary UID/GID. Rather it will run with the permissions granted to the user executing the binary. If that's the case you must make sure the current user is granted with access to the video devices.
                          u0_a67@android:/ $ suroot@android:/ # ./data/mumu/mumudvb -l
                          MuMuDVB Version 2.0.0_20140529_mumudvb2
                          --- Build information ---
                          Built without CAM support.
                          Built without SCAM support.
                          Built with ATSC support.
                          Built with support for DVB API Version 5.3.
                          Built with support for DVB-T2.
                          Originally based on dvbstream 0.6 by (C) Dave Chapman 2001-2004
                          Released under the GPL.
                          Latest version available from http://mumudvb.braice.net/
                          Project from the cr@ns (http://www.crans.org)
                          by Brice DUBOST ([email protected])
                          Info: DVB: ==================================
                          Info: DVB: DVB CARDS LISTING
                          ERRO: DVB: FRONTEND DEVICE: /dev/dvb/adapter0/frontend0 : No such device
                          ERRO: DVB: FE_GET_INFO: Bad file number
                          ERRO: DVB: FRONTEND DEVICE: /dev/dvb/adapter1/frontend0 : No such file or directory
                          root@android:/ #
                          I compiled mumudvb
                          MuMuDVB configure results:
                          Features
                          Build with CAM support: no
                          Build with SCAM support: no
                          Build with ATSC long names support: no
                          Build with compatibility for android: yes
                          Debugging
                          Build with code coverage debug symbols no
                          Build with debugging DUMA library no
                          START mumudvb
                          /data/mumu/mumudvb -c /data/mumu/dvb-s2.conf -d -v
                          needfor libdvbcsa android compile support for descramble
                          It is work but like dvb-t I send terminal log
                            root@android:/ # /data/mumu/mumudvb -c /data/mumu/dvb-s2.conf -d -vMuMuDVB Version 2.0.0_20140529_mumudvb2
                            Info: Tune: You will use DVB API version 5 for tuning your card.
                            Info: Main: Autoconfiguration, we activate SAP announces. if you want to disable them see the README.
                            Info: Main: Autoconfiguration, we activate PAT rewriting. if you want to disable it see the README.
                            Info: Main: Autoconfiguration, we activate SDT rewriting. if you want to disable it see the README.
                            Info: Main: ========== End of configuration, MuMuDVB version 2.0.0_20140529_mumudvb2 is starting ==========
                            WARN: Main: Can't create /var/run/mumudvb/channels_streamed_adapter0_tuner0: No such file or directory
                            WARN: Main: Can't create /var/run/mumudvb/channels_unstreamed_adapter0_tuner0: No such file or directory
                            Info: Main: Streaming. Freq 11096000
                            ERRO: Tune: FE_GET_INFO: Bad file number
                            Info: Main: Tuning issue, card 0
                            Info: Main: Closing cleanly. Error 7
                            Info: Main: ========== MuMuDVB version 2.0.0_20140529_mumudvb2 is stopping with ExitCode 7 ==========
                            7|root@android:/ #
                              I compiled latest tvheadend. end of the work that support libav. but dont work transcoding on android. but sharpened mpeg2 tv channel. no more connections lost. can you pass video add on and live tv (no need press the stop key) obviously tvheadend works on android perfectly.
                                http://www18.zippyshare.com/v/51702496/file.html
                                Just compile with 'libav', transcoding would not work. To enabled transcoding, you need to edit source code.
                                line 116, src/plumbing/transcoding.c
                                uint32_t transcoding_enabled = 0;
                                '1' is enable the transcoding.
                                Regards,
