live TV for all rk3188 using XBMC and tvheadend
    Re: live TV for all rk3188 using XBMC and tvheadend
    Originally posted by sam321 View Post
    I cannot edit the first post anymore, however if you just want a dvb stick that just works go for the KWorld UB499-2T T09, it does not do HD but you can watch one channel while watching another , it is the one that I use and it has not let me down yet
    Thanks a lot. I have tried to search for it but it is not easy.
    Could i suposse that ANY USB stick with ITE IT9135 or IT9137 or AF9015 will work in SD channels ?
    Why a quadcore CPU like minix X7 can't manage with HD ?
    Best,
    Enviado desde mi Xoom Wifi mediante Tapatalk
      I hace found , for example geniatech t328b. Will it work?
      thanks
      Enviado desde mi GT-I8160 mediante Tapatalk
        No EPG and XBMC Crash
        Originally posted by taki View Post
        I compiled new binary tvheadend. That is solved all problem except for HD channel. perpectly works on rk3188 with sd channel. all channel mapped and playing. before version not work truely.
        I use .ht folder on data/dvb/.hts beacuse sdcard some time reset channel list. you can use Gotham beta 3 official XBMC. tvheadend use FFMPEG library. I try to Hd channel but rikomagic not decode mpeg4 h264 ts file.
        tvheadend send raw ts thus ffmpeg library dont decode need hw accelaration. I activate libav for tvheadend soon. need add NDK folder FFMPEG source but dont find truely config script and ffmpeg library source. Who know ffmpeg library android for rikomagic.
        all files copy to data/dvb.
        I installed Tvheadend 3.5.204.zip, I use Beyond XBMC with hardware:
        CX-919
        DVB-T with IT9315 like this
        http://www.****.com/itm/Super-HDTV-T...item19e4d4d0a6
        There is no EPG ?
        I can see tv+radio channels but with glitch and occasionally xbmc crash.
        any idea ?
          use http://mirrors.xbmc.org/releases/and...rmeabi-v7a.apk must be work. I have only two problem
          hd CHANNELS AND OTG eror.
          Only Otg dcw eror dvb usb stick. Tvheadend take usb stick data packages. But not aling eror.
          Are you map channels. I have all dvbs channel epg and dvr record no eror. Beyond xbmc uses alot of cpu. Thus perfect gotham. I try to compile ffmeg add for ndk. If I can add ndk may be activate libav. I know rk3188 not enought transcodind. But tvheadend send raw mpeg mkv. Full tvheadend compile like linux.
          your usb tick give OTG DCW eror.
          pls send dmesg
            pls send dmesg
            Taki, Sam123, thanks a lot for your work.
            As bugmenot said, I have just bougth a Media Tech MT4171 DVB-T USB reciver.
            I will try it with the first post drivers and instructions when it arrives.
            Taki, you are getting a great progress to get HD working, thanks a lot. I'm noob but it's incredible that a QUAD CORE chip can manage with TS files. My 3 years old Inves TV (800 Mhz Single core with DVB-T HD can record and play perfectly, and the new "powerfull" Minix Neo X7 can't. Why then we need lost of cores and Mhz ?
            I hope you get your goal, Taki. Thanks a lot.
            Best,
              Originally posted by juan3211 View Post
              Best,
              yes I always ask Why dont decode HD ts rk3188.
              indeed aml8726 m3 single cpu and single mali gpu play HD ts, aml 8726 m6/x dual core and dual gpu play HD.ts
              but rk3188 quadro core and quadro mali 400 dont decode ?
              I think rk3188 no HW accelatarion for ts. amlogic 8726 m3 uses amplayer (ffmpeg library) for ts decoding.
              I found source dvb player and ffmpeg 0.8 source LibPlayer for aml8726 m3
              I record HD channel with tvheadend (dvr support ts and mkv format for record
              D:ATV HD.mkv
              General
              Complete name : D:ATV HD.mkv
              Format : Matroska
              Format version : Version 2
              File size : 38.6 MiB
              Duration : 31s 800ms
              Overall bit rate : 10.2 Mbps
              Movie name : ATV HD
              Writing application : Tvheadend 0.0.0~unknown
              Writing library : Tvheadend Matroska muxer
              Video #1
              Format : AVC
              Format/Info : Advanced Video Codec
              Format profile : [email protected]
              Format settings, CABAC : Yes
              Format settings, ReFrames : 4 frames
              Format settings, GOP : M=8, N=24
              Codec ID : V_MPEG4/ISO/AVC
              Bit rate : 9 667 Kbps
              Width : 1 920 pixels
              Height : 1 088 pixels
              Original height : 1 080 pixels
              Display aspect ratio : 16:9
              Original display aspect ratio : 16:9
              Frame rate : 25.000 fps
              Color space : YUV
              Chroma subsampling : 4:2:0
              Bit depth : 8 bits
              Scan type : MBAFF
              Bits/(Pixel*Frame) : 0.185
              Stream size : 36.6 MiB (95%)
              Language : English
              Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
              Transfer characteristics : BT.709-5, BT.1361
              Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
              Audio #2
              Format : MPEG Audio
              Format version : Version 1
              Format profile : Layer 2
              Codec ID : A_MPEG/L2
              Codec ID/Hint : MP2
              Bit rate mode : Constant
              Bit rate : 320 Kbps
              Channel(s) : 2 channels
              Sampling rate : 48.0 KHz
              Compression mode : Lossy
              Delay relative to video : 1mn 5s
              Stream size : 1.21 MiB (3%)
              Language : English
              and
              D:\TRT HD.ts
              General #1
              Complete name : D:TRT HD.ts
              Format : MPEG-TS
              File size : 81.9 MiB
              Duration : 1mn 15s
              Overall bit rate : 9 111 Kbps
              Video #101
              Menu ID : 1 (0x1)
              Format : AVC
              Format settings, ReFrames : 3 frames
              Codec ID : 27
              Duration : 1mn 13s
              Bit rate : 8 079 Kbps
              Height : 1 080 pixels
              Standard : Component
              Color space : YUV
              Bit depth : 8 bits
              Scan type : Interlaced
              Scan order : Top Field First
              Bits/(Pixel*Frame) : 0.156
              Stream size : 70.5 MiB (86%)
              Audio #256
              Menu ID : 1 (0x1)
              Format : AC-3
              Format/Info : Audio Coding 3
              Mode extension : CM (complete main)
              Codec ID : 129
              Duration : 1mn 15s
              Bit rate : 384 Kbps
              Channel(s) : 6 channels
              Channel positions : Front: L C R, Side: L R, LFE
              Bit depth : 16 bits
              Delay relative to video : -794ms
              Stream size : 3.44 MiB (4%)
              Language : Turkish
              Audio #257
              Menu ID : 1 (0x1)
              Format : MPEG Audio
              Codec ID : 4
              Duration : 1mn 15s
              Bit rate : 192 Kbps
              Delay relative to video : -882ms
              Stream size : 1.72 MiB (2%)
              Language : English
                What are you trying to say ? Did you manage to record a HD cannel ? Is it well recorded ?
                Or you are saying that both TS and MKV files have the same bitrate ?
                Best,
                  Best,
                  May be this helps you:
                    Dont work
                    initialize the tuner of my dvb-t usb dongle (rtl2832+fc0013) but still no succes in scanning any channel
                    dmesg.txt
                      [ATTACH]6370[/ATTACH]
                      You need these two files:
                      fc0013.ko (it starts the tuner of your usb dongle)
                      02dvbt (in the original script I've added the insmod to the tuner)
                      here below you can find the files to download. The 1st one must be put in /modules; the other one must put in /init.d overwriting the already existing file.
                      Please, could someone tell me one to save the channels in XBMC. After having mapped all the channels and seen that everything is working, when I close the web interface of tvheadend server, and restart xbmc I'm not able to see tv channels any more!!!!! It is like tvheadend did not save the channels and xbmc is not able to retrive them!!!!
                      pluto69
                        I think that you dont link tvheadend to .hts. folder
                        I made linked no sdcard/.hts
                        /data/dvb/tvheadend -C -c /data/dvb/.hts
                        Perfectly work
                        I recorded all channel (mapped channel) later copy my usb for new firmware intall ( test newfirmware)
                        Tvheadend perfectly work. Send home all device. Only problem on hd channel with android rk3188 (that based hw decoding and codechh
                        (First search channel. Later click map channel. If you mapped channel look inside .hts for checking. You look muxes and channel) everting is ok)
                          Perfectly work
                          Thanks TAKI I will try!
                          To be sure, must I change the script 02dvbt in this way?
                          mkdir /data/dvb/.hts # before was /sdcard/.hts
                          chmod 777 /data/dvb/.hts # before was /sdcard/.hts/sdcard/.hts
                          chmod 777 /dev/dvb*
                          /data/dvb/tvheadend -C -c /data/dvb/.hts # before was /sdcard/.hts
                          P.S. I'm already using TVheadend 3.5.204 modded by you!
                            exactly true pluto69 . I tryed all firmware of minix. at this time all time saw channel list /data/dvb/.hts folder.
                            I use xbmc on minix. otherhand I use HTSclient apk on my phone. my pc playing HD channel from hts SERVER OF MİNİX via wifi and ethernet. Turkish HD channel max bitrate 8-12 mb/sn.
                            But I have to say minix otg dcw driver is very bad. all time give me error from data send packet usb to minix. some body say need to modifiye Imem04.c. any devolper and guru no assit us. Amlogic single mali400 and mali400mp2 capable to decode HD transponder stream. But rk3188 mali400m4 dont work its very execiting. I watc sd channel that cpu usage 40-50%. I try to rockplayer to external player gotham. becuse rockplayer perfectly playing HD channel (ts and mkv). inded I wonder source of problem based usb driver or video codech. I dont buy new dvb-s2 device. I searched a lot of forum. alot of usb dvb device dont work truely under linux (ubuntu etc) but hdstar work perfectly android. channel change 1-2 second max. dont work under ubuntu 12-13 like android of minix . I wonder if otg error fix How its work on android. that may be perfect around to world (abcom prisme cube 237 euro xbmc and stb That is very expensive. cheap solution minix )
                            sam321 helped me for dvb driver. I learned compile kernel. But dont find minix neo x7 config and defconfig. I found a lot of kernel source rk3188. I use mk908 and t42 config. but all time give me error compiling. If I true config and kernel. try to modifiye dvb-usb. minix of team upraged our kernel 3.10.10 may be all problem fixed.
                            mkdir /dev/dvb
                            mkdir /dev/dvb/adapter0
                            ln -s /dev/dvb0.frontend0 /dev/dvb/adapter0/frontend0
                            ln -s /dev/dvb0.demux0 /dev/dvb/adapter0/demux0
                            ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0
                            ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0.ts
                            ln -s /dev/dvb0.ca0 /dev/dvb/adapter0/ca0
                            mkdir /dev/dvb/adapter1
                            ln -s /dev/dvb1.frontend0 /dev/dvb/adapter1/frontend0
                            ln -s /dev/dvb1.demux0 /dev/dvb/adapter1/demux0
                            ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0
                            ln -s /dev/dvb1.dvr0 /dev/dvb/adapter1/dvr0.ts
                            ln -s /dev/dvb1.ca0 /dev/dvb/adapter1/ca0
                            chmod 777 /dev/dvb*
                              taki,
                              with your tips I've definetely fixed my problems with the channel list. thanks a lot
                              Pluto69
                                I don't understand why minix does not push something like this. Would it not make the box a complete multimedia station.
                                Maybe too hard to implement, or it's just old tech. Outdated tv rf signals
                                Without memories we have nothing.
