live TV for all rk3188 using XBMC and tvheadend
Originally posted by ferrariale View Postand in the file init.d i write dvb-usb-rtl28xxu.ko or dvb-usb-rtl2832u.ko and which driver video4linux or liplianin-s2-liplianin-v37
how to install
1: download this file and extract it http://www.cloudstor.es/file/m1_NzY4OQ/
2: using a up to date version of ES Explorer mount all drives as rw
3: copy and overwright all the following folders
copy firmware to system/etc
copy modules to system/lib
copy dvb to data
copy init.d to system/etc
Hey Sam, good work on all of this. I feel I should sticky this somewhere?
Anyway if I was to buy one of these, which do you recommend if money is no object?
Originally posted by sam321 View Postthis is your driver pack
how to install
copy dvb to data
Originally posted by Finless View PostHey Sam, good work on all of this. I feel I should sticky this somewhere?
Originally posted by ferrariale View Postthis is my dmesg:
[ATTACH]4419[/ATTACH]
how to install
1: download this file and extract it http://www.cloudstor.es/file/m1_NzY5Mg/
copy dvb to data
thank you very much everything now works!! great job SAM321was missing in the first rar e4000.ko
if you happen to come to Italy, I offer you a drinkLast edited by ferrariale; 19 December 2013, 09:58.
X7 + Tvheadend + PCTV 290e
@Sam321, Hi
i have an Minix X7, and an PCTV nanostick T2 (290e).
Can you provide me needed files so i can get Tvheadend working on my android box, with my tuner stick?
Appreciate it, so i can test if it works well!
Congratulations and thank you for your support here in this forum.
Regards
minix neox7 tvheadend streaming server
I tested streaming perform minix. I setup hot spot minix and connect my laptop.
5 sd channels perfect streaming
2 hd channel streamin (sometime stutering)
1hd channel perfect sreaming (9mb/sn)
look this photo.
I found android minix dont play streaming HD channel. dont have this codech or cpu frequency not enought
all other problem signal locked and driver my usb dvb-s2 stick. local oscillator not sensitive. may be other skystar HD usb mey be good perform with tvheadend
look this photo.
all other problem signal locked and driver my usb dvb-s2 stick. local oscillator not sensitive. may be other skystar HD usb mey be good perform with tvheadendthat not enought stock rom.
I loaded eerthing ok. but finless rom1.8 not copy system firmware modules and init.d. ES explorer said not enought space thus dont copy.
kernel1080_cpu1704h_gpu798h_ddr720
Originally posted by sam321 View Postwell it is difficult giving recommendations on what tuner to get as I know some of these drivers will not work properly in android and sometimes the drivers source code needs altering slightly to make it work. however if someone wants to buy a tuner specifically for the android box I would recommend KWorld UB499-2T T09 as I have been running this tuner 24/7 for weeks and it is 100% stable, even watching one channel while recording another works really good. My K-R42 is never turned off now
There are currently 4814 users online. 0 members and 4814 guests.
