live TV for all rk3188 using XBMC and tvheadend
I've read this thread but most of it was over my head. I'm going to buy a MiniX Neo X7 and thinking of purchasing a Kworld UB499-2T. Am I understanding correctly that following the setup in this post that I will be able to watch and record live TV just using those two devices and an external hard drive? Is HD not fully working? One user seems to be having problems with HD.
Originally posted by FlexiPack View PostI've read this thread but most of it was over my head. I'm going to buy a MiniX Neo X7 and thinking of purchasing a Kworld UB499-2T. Am I understanding correctly that following the setup in this post that I will be able to watch and record live TV just using those two devices and an external hard drive? Is HD not fully working? One user seems to be having problems with HD.
Originally posted by Finless View PostAh OK doing a little research. Is there a stick that you can connect a cable TV input? This uses an antenna which limits the broadcasted channels here in the US.
a list of ATSC USB tuners http://www.linuxtv.org/wiki/index.php/ATSC_USB_Devices
a list of DVB-C USB tuners http://www.linuxtv.org/wiki/index.php/DVB-C_USB_Devices
Originally posted by hasafly View Post@Sam321, Hi
i have an Minix X7, and an PCTV nanostick T2 (290e).
Can you provide me needed files so i can get Tvheadend working on my android box, with my tuner stick?
Appreciate it, so i can test if it works well!
Congratulations and thank you for your support here in this forum.
Regards
Re: live TV for all rk3188 using XBMC and tvheadend
Originally posted by sam321 View PostThe Kworld UB499-2T is not a HD tuner so you will not be able to watch HD, and yes you will be able to watch and record programs just using your MiniX X7 And the Kworld UB499-2T
Sent from my Desire S using Tapatalk
Originally posted by FlexiPack View PostThanks for the info Sam. Can you recommend a HD DVB-T stick that's compatible? Are any DVB-T2 sticks compatible?
Originally posted by sam321 View Posttechnically speaking if the drivers load and work, it should work OK , however it depends whether the TV broadcast format is supported by the hardware acceleration, I do not own any DVB-T2 tuners so I cannot really say for sure and they are too expensive for me to buy just to test. As an educated guess I would say that it is too much for the system as the USB is not fast enough as it is not a full speed usb2 controler also the drivers that controle the USB are not very good, of course I could be wrong and there could be one tuner out there that would work perfectly, I cannot buy every one to try. In all honesty you would be better off using a raspberry pi as a backend as it runs on linux and the comunity support is amazingLast edited by FlexiPack; 22 December 2013, 00:47.
Originally posted by FlexiPack View PostI agree, I think the current gen of products are probably not up to recording HD. Maybe one or two gens from now they might be. If it weren't for the fact I wanted android for things then I would've looked into the RasPi. Thanks for your help.If I were you I buy it
Matrix ARM Mini PC is a single board mini computer based on ARM with a wide range of interface, equipped with a powerful i.MX6 Freescale processor, it can run Android, Linux and other operating systems, a switch between different operating systems can be done within just a few minutes! Matrix also has great support for TBS USB tuners and popular software such as XBMC, VDR, Tvheadend, DVBLast and so on.
"10/100/1000 wired Ethernet" pcı express vovvvvv
How to play Matrix with TBS Tuners.
A super PC + TBS tuner (PCIe/ USB), with XBMC/ VDR/ Tvheaded
buydvb.net ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf buydvb.net alles. Wir hoffen, dass Sie hier das Gesuchte finden!
If I had not minix x7. 'd buy tbs-2910-matrix
Matrix is a single board mini computer based on ARM with a wide range of interface, equipped with a powerful i.MX6 Freescale processor,it can run Android, Linux and other operating systems, a switch between different operating systems can be done within just a few minutes.Matrix also has great support for TBS USB tuners and popular software such as XBMC, VDR, Tvhead end, DVBLast and so on.
android 4.2.2
linux vdr, tvheadend, xbmc
ubuntu imagefull
- Software
- Android
- http://sourceforge.net/projects/open...2.zip/download
- Linux
- TBS customized Linux system v1.0.0.0, which is with TBS tuner, and VDR/XBMC support
- http://sourceforge.net/projects/open...0.zip/download
- Ubuntu
- Source code
- The Source code for Matrix ARM Mini PC
- https://sourceforge.net/projects/openpctv/
- works with tuner
- Optional:
1x TBS5220 USB DVB-T2 / T / C Tuner TV Stick. Save US$10! ( +US$58.99 ) (+160g)
1x TBS5680 DVB-C TV Tuner CI USB. Save US$10! ( +US$88.99 ) (+1100g)
1x TBS5922 USB DVB-S2 TV Box. Save US$10! ( +US$68.99 ) (+630g)
1x TBS5925 USB DVB-S2 Professional TV Box. Save US$10! ( +US$239.99 ) (+1000g)
1x TBS5980 USB DVB S2 TV QBox CI. Save US$10! ( +US$78.99 ) (+1200g)
1x USB DVB-C TV Stick. Save US$10! ( +US$68.99 ) (+150g)
http://www.****.com/itm/TBS2910-Matr...-/331085685686
- Software
Originally posted by hasafly View PostThank you Sam321. I will wait for it.
Regards
how to install
1: download this file and extract it http://www.cloudstor.es/file/m1_Nzc2OA/
2: using a up to date version of ES Explorer mount all drives as rw
3: copy and overwright all the following folders
copy firmware to system/etc
copy modules to system/lib
copy dvb to data
copy init.d to system/etc
Originally posted by sam321 View Postthis is your driver pack for PCTV Nanostic
how to install
copy dvb to data
I will try it and leave some feedback here
Thank you for your great support.
Regards.
There are currently 1536 users online. 0 members and 1536 guests.
