live TV for all rk3188 using XBMC and tvheadend
    "I changed assembly in two tvheadend to return always valid in function "security_check" and now I can run tvheadend.
    BUT not detect my tuner. In this tvheadend already have tuner configured in source code and always have this tuner in DVB Adapter "Hisilcon AVL6211" and in other tvheadend have "Hisilcon LGDT3305".
    To understand bether."
    which tuner you have? and you compiled your tuner drivers.
    Kolin
    Hey there. Sorry, but how to install tevii s660 drivers to Minix X8?
    just wait we can try to fix minix x8h tuner support
      Kolin
      My STB have 2 internal tuners.
      1 - Hisilicon MXL603 - DVB-C
      DemodType: 3130_inside
      1 - Hisilicon AV2011 - DVB-S2
      DemodType: avl6211
        Pls specifi your device. Photoa and link
        Where is kernel your device
          You can download full SDK (kernel w/ drivers, tools, samples...) for my STB here:
          https://mega.co.nz/#F!QJ0ygSLb!biEknQWvKnAjsnquibzkLQ
          Source driver (MXL603 and AV2011) only for check because is for other kernel but I think is the same files:
          GitHub is where people build software. More than 150 million people use GitHub to discover, fork, and contribute to over 420 million projects.
          Photos:
          DVB-C Tuner
          DVB-S2 Tuner
            Link for SDK (Kernel w/ drivers, tools, samples...) for my STB:
            MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
            The same drivers (MXL603, AV2011) but for other kernel but I think is the same code:
            DVB-S2 Tuner Photos
            DVB-C Tuner Photo
              I can help with anything?
                leandrotsampa
                # define DVB_API_VERSION 5
                #define DVB_API_VERSION_MINOR 10
                your kernel has linux dvbapi 5.10. You can use compiled for android rk3288 and s812 tvheadend.
                I think that your kernel image has dvbtuner driver. but tvheadend need to dvb modules (avl6211.ko and etc). thus you recompile android kernel and change your kernel config y to m
                first you must be find your kernel .config. after compile new kernel and modules. add stock firmware new kernel-boot.img and modules. after tvheadend can see your tuner.
                What is your box name. where you buy it ?
                  leandrotsampa
                  Yes KERNEL have dvbtuner driver, if you checked KERNEL source code you can see this driver is modded to work with Hisilicon hardware and all tuner drivers is compiled in 1 module named hi_tuner.ko.
                  The KERNEL not have dvb driver to work with DVBUSB, need convert hisilicon dvb driver to work with dvbapi.
                  Please check driver in KERNEL source you will understand best.
                  Link for STB
                    Originally posted by sam321 View Post
                    I have a thread in another part of the forum but I thought I would move it here, also the thread was geting quite long and hard to understand
                    for now only the tuners below will work with my Pre built driver pack, it is possible to create your own driver pack to get your tuner working, see the second post for that
                    DVB-T
                    KWorld UB499-2T
                    KWorld UB499-2T T09
                    And any others using ITE IT9135 or IT9137
                    AF9015 DVB-T USB2.0 stick
                    And any others using AF9015
                    see if your stick is supported go here http://linuxtv.org/wiki/index.php/DVB-T_USB_Devices
                    you must be running a ROM with init.d support for this to work
                    how to install
                    1: download this file and extract it http://www.cloudstor.es/file/m1_Njg0Ng/
                    2: using a up to date version of ES Explorer mount all drives as rw
                    3: copy and overwright all the following folders
                    copy firmware to system/etc
                    copy modules to system/lib
                    copy dvb to data
                    copy init.d to system/etc
                    4: reboot
                    to configure tvheadend go to your browser on the box and type http://localhost:9981 for a more indepth guide go here http://wiki.xbmc.org/index.php?title...kend/Tvheadend
                    install XBMC then go to system>settings >live tv >general and click on enable and choose and enable tvheadend
                    I highly recommend to use a hdd for Timeshift / recording as flash memory as a limited read/write
                    Hi everybody,
                    can someone please post again the file "http://www.cloudstor.es/file/m1_Njg0Ng/" i cannot acces to the site.
                    thanks in advance!
                      Hi, I found my DVB Driver in DVB-API, now I need call function in driver to start it.
                      How I can call function: mxl603_attach ??
                      struct dvb_frontend *mxl603_attach(struct dvb_frontend *fe, struct i2c_adapter *i2c, u8 addr, struct mxl603_config *config)
                        hello ,
                        i search with tvheadend + RTL2832U / R820T driver for my tvbox rooted EKB311A 1Gb /8 Gb , RTL8201 and RTL8723AS chips kernel 3.0.36+
                        what link should be taken in this post ?
                        thank you
                          hello,
                          nobody's answering. ???
                          Please
                            help me please
                            i've put in modules
                            dvb-core.ko
                            dvb-pll.ko
                            dvb-usb-v2.ko
                            dvb-usb-rtl28xxu.ko
                            r820t.ko
                            and insmod all
                            but insmod dvb-usb-rtl28xxu.ko
                            rtl2830_get_tuner_i2c_adapter" (err 0)
                            my dvb-t usb is http://fr.aliexpress.com/item/E4000-...580776385.html
                            what I forgot ??
                            thank
                              DVB-T
                              KWorld UB499-2T
                              KWorld UB499-2T T09
                              how to install
                              copy dvb to data
                              4: reboot
                              Please upload it somewhere else. Where is download button?!
                              Thanks.
