UPDATED- NEW - MK908 Finless 1.7a ROM
    UPDATE 12/10/2013
    Here is 1.7a. The ONLY change is a new recovery.img that works with all models of MK908.
    If your already up and running on 1.7 there is no reason to reflash the entire ROM.
    Link below now updated to 1.7a
    _________________________
    OK folks you have been asking and I finally got around to it. A new ROM made from the latest beelink/tronsmart ROM "overseas".
    This kernel still had the old frame skipping issues so I fixed that by patching the kernel. Special thanks to Mr. Anderson for his patcher that makes the job a lot easier
    THEN... this time around I bring you a set of vsync patched Over-Clock kernels. They are a separate download for those that want to use them. USE AT YOUR OWN RISK!
    ________________________________
    Features and release notes for my 1.7 ROM:
    0) Sorry I hated the new launcher provided with this ROM. It sucks in my opinion!
    So I put back the AOSP Android launcher.
    1) Rooted and new SU and Superuser applied that supports Android 4.2.2
    2) Stock ROM was only 2 Gig of APP space.
    BUT you also have parameter file options!
    There are also 1gb, 2gb, 4gb and 6gb options.
    Read below for how to change that in the flash tool.
    Realize if you use this 6gb option, internal SDcard will only have about 600 megs of free space!
    3) Debloated of junk APPs and Google Apps you can get from Google Play.
    I also updated Google Play and required Google APPs to the latest version.
    4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
    5) I re-enabled location services. This is now in the settings menu.
    Tested and working with all APPs that use it.
    Remember to turn off GPS as we have no GPS.
    6) I also re-enabled accessibility options in settings.
    7) Gameloft fix. Rockchip sources now have this fix in!
    We at Freaktab learned this fix from Christian Tory. Then FreakTab dev's passed it on to Minix, then this obviously got to Rockchip!
    Amazing! All RockChip ROMs have had this GameLoft issue for 3 years. Now because of us Android lovers, RockChip finally fixed this! I am proud as I am sure all FreakTab Dev's are, to have helped Android progress even from Chip makers like RockChip! Eventually they do listen to us users
    With that said.... ROCKCHIP! RELEASE SOURCES!
    If your going to use the communities developers to help you, THEN HELP US! Do the right thing!
    Sorry folks... Rant over...
    8) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
    I am spoofing a Samsung device that will show almost any APP as compatible.
    Your device will show up in google play as Samsung device nopt a MK908 or RKSDK! Understand this please.
    I also left the original build.prop in the ROM called build.orig.
    If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
    Then rename build.orig to build.prop.
    Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
    Reboot! You should be back to showing up as a 908ii.
    WARNING if you do this, you need to be using the 1080 kernel or your screen will be oversized!
    9) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
    10) I provide the stock kernel but it does have the micro frame skipping issue!
    BUT I have also created Vsync patched kernels that fix the micro frame skipping!
    I have set the flash tool to use a 720P vsync kernel by default.
    11) 1080P Kernel if you want it!
    I also created a stock 1080 kernel (has frame skipping) as well as a vsync patched 1080 kernel.
    See instructions below for how to choose the correct boot.img and kernel.img
    720P boot and kernel is the default setup in my flash tool.
    12) By request I added TUN.KO for VPN support. It was not in the kernel by default.
    ___________________________________
    Here is the link for MK908 1.7a ROM
    ROM -> Tronsmart MK908 Finless 1.7a ROM (272 megs)
    Here is the links for MK908 1.7 ROM - OC kernel set
    ROM -> Tronsmart MK908 Finless 1.7 ROM - Over Clocked Vsync Kernels (121 megs)
    Enjoy,
    Thank u.thank u Bob..will try it out tonight
      Just tried updating my MK908 v5 but getting nothing but black screen (sometimes white vertical lines) Tried resetting a few times, no change :s
        I cant help right now with the v5 hopefully soon.
          That's fine, but can you tell me where to get the rom to get it back to the way it was please?
          Sorry very new to this kind of stuff :P
          EDIT: It's ok I managed to get it back to (mostly) stock
            Your going to have to read through this post.
              Thanks man that's the thread that got me back to working order
              (Sorry for cluttering up your release thread :s you can delete these posts if you want, just quietly awaiting your video stutter fix for the V5 now)
                Antutu over 18000 WOW!!
                  Thx Finless... Would you perhaps also Add FTDI Drivers in your Rom?
                    Nice work bro, will try it out
                    Tronsmart MK908 Since 2013
                    Himedia Q5 III Since 2014
                      Does this work on the v3?
                        AW: NEW - MK908 Finless 1.7 ROM
                        according to this thresd: http://www.FreakTab.com/showthread.php?t=8313 you will most likely have to pack either the new recovery provided by j05h, or even multiple recoverys depending on if that one works for the v1 and v3 as well....
                        tapatalked from MK908v3
                          Re : NEW - MK908 Finless 1.7 ROM
                          Word fine on v3
                          Envoyé de mon GT-I9505 en utilisant Tapatalk
                            I will try tonight on my MK908 v3. Thanks!
                            www.sacvideolari.com www.babatorik.com
                              It's alive!
                              Thanks! Works nice on my MK908 V3!
