UPDATED- NEW - MK908 Finless 1.7a ROM
Originally posted by ulises1954 View PostHi Finless,
I also would like to know, what are the differences between your MK908 Finless 1.6a ROM and the MK908 Finless 1.7a ROM?
Which of these two do you recommend for use in the CX-919 v2?
Thanks in advace!
Which one of these two will work better with the CX-919 v2?
Thanks for help!Last edited by ulises1954; 14 December 2013, 22:18.
AW: UPDATED- NEW - MK908 Finless 1.7a ROM
There seems to be a bug in the framework that sometimes lets the notifications disappear and only way to bring them up again is by producing a new notification. This was the case on the stock rom as well, but not in your previous rom.
_________________________
tapatalked from GalaxyS3
I have 2 sticks V5...
The first one i put finless 1.7a on. Everything works fine.
The second, something went wrong... It starts (i see the blue led) But then nothing happened.
I tried several times to flash the unit again, and try to put finless 1.7a... But nothing changes: The stick starts, (blue led), but i cant see anything on the screen.
Anyone who knows how to bring my stick back to life?
Originally posted by FadeFx View PostThere seems to be a bug in the framework that sometimes lets the notifications disappear and only way to bring them up again is by producing a new notification. This was the case on the stock rom as well, but not in your previous rom.
Only some tiny points to complain, first is that video.useoverlay=1 does not fill the screen completely for some reason, there is a black border to the right, top and bottom of the screen. This is not the case if i set dpi to 240.
And the kernel spalsh screen in the 1080kernels is 720 only and uggly as hell.
edit:
what about something like this:
tapatalked from GalaxyS3Last edited by FadeFx; 17 December 2013, 17:03.
Originally posted by FadeFx View PostLooks like i err... it hasnt happened anymore at least. However, this firmware is great, first time i can use my device without limitations even with a 1080p kernel.
edit:
I believe I have a V5 (purchased end of nov 2013 - but didnt open it to make sure). I was able to get finless 1.6b working just fine (flashed from stock rom without a hitch). Now its time to get 1.7a working, and its been a no go. I've tried several combinations of finless1.7a with Boot, Recovery, and Kernels from Jo5H1. I've tried flashing 1.7a in its original form. I even downloaded the overseas stock rom update and flashed via RKbatchtool and after that flash it did not boot. All I get is a black screen. When I flash back the 1.6b it works fine.
When I clear NAND, it clears fine. It will flash everything I mentioned above just fine. Computer recognizes the tronsmart perfectly fine.
Any help would be much appreciated.
thanks
Flash Error
Purchased a mk908 and want it to flash with the 1.7a rom.
After pressing 'Flash Rom' it starts writing data to nand. Then it starts to check download data and shortly thereafter I get an error (ERROR: download file failed).
Tried a second time to flash with a new redownloaded 1.7a image but still the same error.
Need some advise here!
OK lets see.
The boarders around the screen can be adjusted in settings. Go into settings>screen and increase the scale slider.
Sorry about the splash screen in the kernel. I like the one you made and will use it in the next release.
V5, V3, etc. So far this ROM has been reported to work on all models. Maybe you have yet another clone?
If you getting an error after flash and while checking, this is usually a bad USB cable or some process on your PC is tying up the USB port in some way. Try another cable or try changing USB ports.
Another thing you can try is changing the port type for the flash tool. In my ROM kit open the file settings.ini in notepad and edit this
SUPPORTUSB11=0
Change the value to =1 and try that.
I purchased the 908. From geekbuying.com.
It is the tronsmart cx-919 with external antenna. Is this a clone?
I'll also try another usb cable, though I dont get any flash errors.
If you want i can give you the .pst file so you can edit it yourselfs, just drop me a note.
Originally posted by Finless View PostI am confused.... do you have a MK908 or a CX-919? If you have a CX-919 go into the Measy and CX forum and download my CX-919 ROM.
Apparently so am I. I feel like such a goof. I have the CX-919. No wonder none of this is working! I just checked, the latest is the 1.6b rom for CX-919. The rom in this forum, obviously does NOT work with the CX-919. Do you plan on releasing a 1.7 equiv for the CX-919?
I'm sorry to have wasted your time. If I wanted to get another one, which do you recommend MK908 or CX-919? It seems that the MK908 has A LOT more development.
There are currently 4391 users online. 2 members and 4389 guests.
