Minix X7 Hybrid Firmware (HFW) 3.2 by lewy20041
Originally posted by joebejm View PostTo Infinity and Beyond.... XBMC
Originally posted by Flumpster View PostWell if it was a mistake you wrote up two completely different reviews as I have emails sent to me when someone replies to threads with the content in it and I have both of them here and they are not the same or directed at the same rom. How can you write two completely different reviews by mistake ?
Originally posted by lewy20041 View PostOC but probably in next relise i will go with stock. If you want to use stock ones they are in system/preinstall so you can flash them if you want.
Please tell me, if i want to use oc kernel (from /preinstall) - i must to "reflash" my t428 again ? Can i flash only kernel.img or i must full reflash (boot,system,Loader etc)?
Also i found *.prop files in /preinstall - What should I do with them?
nice ROM - great thanks!
if you wan to use difrent kernel just replace 720p.img/1080p.img (witchever you have) in preinstall folder
go to settings->advanced->and switch resolution
it will flash your kernelEverything is possible if we work together!
Originally posted by lewy20041 View Postgo to settings->advanced->and switch resolution
Also, if we are discussing here the whole firmware, I want to draw attention to the device drivers. Especially on the drivers for wifi-usb. There are many modules rt53*.ko
But they all gathered for version 3.0.8+ and, accordingly, they do not work. Can anyone rebuild all modules, so that they work on version 3.0.36+ (or specify github kernel - I'll try to collect them myself)
lewy20041
Do you plan to further development of the kernel? Or stopped development on this? I'm testing a few wifi adapters, but I can not compile the driver (rtl8187, rk5370) because it is not known kernel configuration? Is it possible to learn it?Last edited by Toologic; 19 March 2014, 14:18.
I create rtl8187.ko and rk28x0 (for 5370) modules and they normal work.
But I see in /system/lib/modules a complete mixing modules of different versions, with one version of a module called (ex. 3.0.36+) is actually another (for vermagic 3.0.8+) Why do that? Are there problems with the assembly of modules of current kernel version 3.0.36 +?
And last question. I have a nobranding full analog T428 tv stik. What version of your firmware is the most stable and the latter? T428 (HFW) 2.0.3 or Minix (HFW) 3.2?
Cannot set Wallpaper after Hiding the Taskbar
Hi lewy20041,
First of all thanks for your commitment to the Android platform and especially for your work on the Minix Neo X7 which I also use.
I have a number of issues:
a) When I Permanently Hide the System bar, I am unable to set a Wallpaper. It just defaults to the bubbled wallpaper. Is there a folder where I can copy my Wallpaper to?
b) Please check your PM for my other requests.
Thanks & Regards,
Kon
There are currently 2070 users online. 0 members and 2070 guests.
