Only wish that someone can mod the new XBMC so i can run it on this great rom.
Minix X7 Hybrid Firmware (HFW) 3.2 by lewy20041
V3.2 with O/C -> no O/C
Hey Lewy,
I had 3.2 loaded with the O/C and would get intermediate hangs.
Went to flash 3.2 without O/C.
I was setting up WIFI, since X7 works on 5gig band I gave it name for my 5gig band and it would not connect. With the O/V version with your launcher loaded it did not have a problem connecting to the 5gig bandwidth, and now it will only connect with the 2.4gig. Is there something I'm doing wrong? Anyone else having this issue?
Thanks.
Thanks.
Using mainly lan here but I get about 20mbps wifi download on a dd-wrt wireless router
i got a 2nd minix box for a mate and installed the 3.2 rom, it's nice and fast, wifi is better then fineless rom. but sometimes I get hangups which clears in 20 seconds or so....annoying.
also I don't think I've installed the kernels, i just downloaded the firmware and installed it over stock firmware as per instructions from readme.txt. How do I go about updating the kernel? Also how to remove the gamepad icon from the dock?
Thanks.
Originally posted by Orak View Posti got a 2nd minix box for a mate and installed the 3.2 rom, it's nice and fast, wifi is better then fineless rom. but sometimes I get hangups which clears in 20 seconds or so....annoying.
also I don't think I've installed the kernels, i just downloaded the firmware and installed it over stock firmware as per instructions from readme.txt. How do I go about updating the kernel? Thanks.Please consider making a Donation to freakTab
Originally posted by Orak View PostI only used
Minix_X7_HFW_3.2_by_lewy20041\RKBatchTool\RKBatchT ool--1.7.exe
selected FW path and clicked restore and it was done.Please consider making a Donation to freakTab
I just followed the "Changelog + Install.txt" file...
#Install
-unpack arhive (anywhere)
-start \RKBatchTool\RKBatchTool.exe
-put device into flash mode (press and hold reset button, conect otg to pc and box)[if you already using my HFW go to setting>advanced>reboot to bootloader]
-install proper drivers when windows ask from \Drivers\ folder
-when you wil see number 1 in green box select "..." button in right top corner of RKBatchTool
-navigate to HFW_vx.x.x.img
-pres restore button in RKBatchTool
Please can somebody tell me if this sample works ok. https://dl.dropboxusercontent.com/u/...ATiNO.x264.mkv
MXplayer, stock player or XBMC do the same, artifacs, pixels, and etc.
with MXplayer in SW mode no extrange pixels but frameskiping is present.
This happnes to me in few h264 videos, so maybe someone cant tell me if this an android thing or a newbie problem
Originally posted by blinkone View PostOk im not 100% sure about this as I dont use that tool but I would guess that the Rkbatchtool has flashed the kernel aswell,but cant be sure sorry may be someone else who uses that tool can help
Works great for me, i don“t use wifi only ethernet and i have no problem at all.
Originally posted by roolmapool View PostHello Lewy,
Nice jobs as always!
I have just an issue with 3.2: Ethernet don't working after 1m... I delete init.d script about static MAC adress, and it s OKnow...
Re: Minix X7 Hybrid Firmware (HFW) 3.2 by lewy20041
Originally posted by Junker83 View PostHello,when i want to make NFS share over terminal, i get this message:
mount: cant read /etc/fstab: no such file or directory
Any idea?
You need busybox mount command instead of system mount one ;-)
Enviado desde mi GT-I9505 mediante Tapatalk
There are currently 2219 users online. 1 members and 2218 guests.
