Minix X7 Hybrid Firmware (HFW) 3.2 by lewy20041
I think you should tr minix beta 2 moded here on forum.Everything is possible if we work together!
In my T428 only at third or fourht time i manage to install the rom
with update and restore tries i did.
Originally posted by bahor60 View PostI try to put V3.1, after reset the black screen, the previous V3 is put and works. I downloaded already 5-6 timesI help with 4GD663269M466950W
And you ????
My devices:
Tronsmart T428 real 3188 with Finless A928 and D33 Kernel at 720p
Tronsmart Prometheus won on CNX just now....
can not install this rom on minix x7
hi lewy .
there is a problem with with the installation procedure.I have flashed over 5 different roms without any problem but after the successful installation through your guide i get black screen for over 10 minutes.i re flash the Rom 3 times and the same.Can you suggest anything ????
Try to erase/format NAND using fin bobs tool then re flash with lewy flash tool
Have tested this ROM:
1) Latest HULU works fine including AD.
2) Latest NETFLIX ok.
Issues:
1) HDMI passthrough does not work anymore from MXPlayer.
Please rectify! TQ!
Hmm...i ve tested with stock 007E, doesn't shows up the DTS/DD signal anymore in my AVR...:stars:...not sure if its AVR settings or what...Last edited by Matrixlyn; 22 December 2013, 02:25.
There are currently 2283 users online. 0 members and 2283 guests.
