OK. So after a long wait HFW 3.2 is here.
This rom is based on 006 firmware from minix.
The latest one 007 have a bluetooth bug thats why
i used the older one as a base which is wery good in my opinion.
As always please provide a feedback if you found any bug or how do you like the firmware
If you like the firmware and would like to support my work
donation is appreciated.
Screens:
Changelog:
v3.2
-fix black screen on some devices
-kernel in 720p mode "stock" (default)
-kernel in 1080p mode "516mhz-1.8ghz gpu-stock ddr-800"
(1080p stock kernel in system/preinstall if some one wants it)
v3.1
-fixed remote mapping
-fixed nfs
-fixed some stability bugs
-flash custom kernel under setting-miscllaneous
(place your kernel into /sdcard/HFW/ and rename it to kernel.img)
!(make sure you flashing 1080p kernel in 1080p mode and 720p kernel in 720p mode)!
-melef10 keymap
-better xbox wirless gamepad keymap
v3.0
-rooted
-init.d support
-debloated
-cwm recovery (backup-restore your firmware)
-swich between 1080p kernel and 720p kernel with simple press of a button from your tv
(Settings-Advanced-Switch Resolution)
-new CM like menu under Settings
-pached libmedia for xbmc passtrougt
-new folders in /mnt/ out of the box fro mounting nfs or smb shares
NFS_1 ; Samba_1
NFS_2 ; Samba_2
-mount smb, nfs scripts in /etc/init.d/ for mounting shares (edit to mach your shares and
change permisions to "755" "rwx r-x r-x")
-new shutdown menu
-fixed setting/firmwork-res strings
-new modules
*md4.ko
*Virtual Touch
*Tun
-gamepad button on systembar
-removed volume buttons from systembar
-youtube for gtv 1.7.3
-better webcam support
-wirless tweeks in build.prop
-spoofed as Galaxy S3
-new mouse pointer (LG Google TV)
-new bootanimation
And probably other things i forgot to mention;p
Have Fun!
Firmware:
V3.1
V3.2
XBMC Minix Beta 2:
(For devices spoofed as SGS3)
Download
OC kernels pack:
Download
Make sure that you flashing 720p kernel in 720p mode and 1080p kernel in 1080p mode.
!!Im not responsible if someone will flash this kernels and damage his device!!
!!Its only for people that know what are they doing!!
