Minix X7 Hybrid Firmware (HFW) 3.2 by lewy20041
Went back to 3.1 HFW FROM 3.2
Was getting more force closes.
I'm also using fin bobs kernels 1700cpu 798gpu and 800 ram. It gets hot but it plays games great.
I bounced around yesterday and tried quickshot rom, fin bobs 1.8 rom and fin bobs 1.7 definite improvement ie far less ANR all around, guess that's because the latest minx base from minix has these improvements implemented? Unfortunately these minix base, sixaxis wireless doesn't work and xbox 360 wireless doesn't work?
I'm surprised Minix hasn't made wireless controller support a priority. Gaming on android is pretty important
Hi strix, you do not have problems with "xbmcminix-armeabi-v7a_12.3.81.apk" ?
I ' install the "xbmcminix-armeabi-v7a_12.3.81.apk" in Tronsmart T428 (3.1 HFW),
and when I run XBMCMinix V2 he said :
Error, this XBMC package is only compatible with Minix devices.
Should i do something to make it work?
here on the forum is the same packaga but it works on devices spoofed as galaxy s3.
look for it in xbmc threadEverything is possible if we work together!
Why do you want tu update super su and terminal?
Just go to settings and its there.
If you are a adwanced user u should know that you need to delete terminal and super su from system/app if you want to use playstore ver.
Thats becouse i sign the one with my firmware with diffrent keys.Everything is possible if we work together!
Originally posted by lewy20041 View PostWhy do you want tu update super su and terminal?
I flash the device few times, so after first or second reboot I go to playstore and install my apps and update the apps that came with the rom, all is well except for this two, so I take a screenshot and post it. But just with de idea to provide some feedback nothing more.
issues for me on 3.1
on a few occasions now sometimes after boot there is some serious screen lag, solved with a reboot usualy. today though after reboot i notice half my apps are missing? went to reboot againand as its powering down a message pops up anouncing my internel flash is blank?
now box doesnt boot up. i can get into recovery. will try to restore from backup. would love to know why im having this issue.
I'm a total newbie, just trying to give some feedback, is not important o necesary to me update or replace those programs , just found this and think is maybe usefull for somebody.
i was only curious why do you need to update this;p
feedback is important and thank you for pointing that out, so now some new users will know why its like thisEverything is possible if we work together!
did you modified anything?Everything is possible if we work together!
Originally posted by Cantenna View PostIm using fin bobs latest of kernel 1080 thats about it? Using folder mount. Maybe o should wipe data factoy reset in recovery then restore from backup?
Probably its the kernel foult as its from difrent firmware. Try stock 1080p or oc one from system/preinstall folder.Everything is possible if we work together!
There are currently 2005 users online. 4 members and 2001 guests.
