Q7 Rk3188 Device - What Works & Help Please?
    I have a device that looks like the image below and seems to have a lot of similarities as other devices : I will update this post with exact chipset info as I have it in another location. I wanted to contribute as after a LOT of digging and trying things, this forum has by far helped me the most!
    CHIPS INSIDE
    WLAN: RTL8188
    LAN: RTL8201F
    Bluetooth: Mediatek MT6622
    Back of Device / Board Print all specify the "Q7" or "XT-Q7-V10". I have dug into these forums trying to match any print from the board or model and have found nothing so far.
    Getting Perfect Playback on 1080p & 720p MKV :
    Full Flash - K-R42 Hybrid Firmware (HFW) 3.2 by lewy20041 Firmware
    Flash Kernel Only From - K-R42 firmware by wasser 1.2.3
    As far as I can tell the 1.2.3 kernel from wasser has the stutter video fix - 1.2.4 does not
    With these wifi / bluetooth / Blue Button do not work but USB / Wired Do
    I have also dumped the original firmware from the box including kernel, which if flashed has all the drivers to make everything work, however, I loose the video stutter fix. I tried the patch the kernel with the rkpatchomatic which gave no errors and was successful. When flashed it did not boot though. I tried a couple times to make sure and had the same result every time.
    I was wondering if someone here could possibly patch the kernel or build a kernel with the patch if all chipsets were specified.
    Thanks again for all the contributions from everyone who has helped me get my device working so good already!
    CHIPS INSIDE
    WLAN: RTL8188
    LAN: RTL8201F
    I have the same box and have sent wasser my gpio and dmesg dumps to analyze. He should hopefully be including our drivers in his next update
      HI
      We already get the stock firmware for this Q7 model, we will upload the stock firmware to cloud, and share with you guys.
      and since this Q7 and MK918, T-R42, CS918 have the same case, i will write an instruction for how to tell the difference, and how to find the correct stock firmware.
      i will post the information on our blog.
      stay tuned.
      Eric
      Geekbuying
      Looking for developers
        Originally posted by geekbuying View Post
        HI
        stay tuned.
        Eric
        Geekbuying
        Thank you very much
          HI
          stay tuned.
          Eric
          Geekbuying
          Thank you for the quick responses and all the help!
            Finally decided to pop the hood on my box and can see "RK3188_Box_V2.0" on the board
            Is that of any use to anyone?
              Yeh, I'm not sure because they like to print so many different numbers on the boards. I would think matching up the 'look' and wifi / wired / bluetooth chip numbers would be best. It sounds like we have the same thing but all I have is printed numbers and decals that all say Q7 in some form or another.
                Cool. I'll upload a pic of the board soon
                  Added board pic to top first post.
                    My Board
                      Guys, can you upload your backup (stock) rom image for this device? There is no link to rom download in the relevant post on geekbuying blog (http://blog.geekbuying.com/index.php...d-core-tv-box/). I would appreciate it very much. I have the same mainboard as hackadroid.
                        Latest firmware available for our box
                        百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
                          http://pan.baidu.com/s/1mgFgGQk
                          Thanks! I will try it out.
                            It's not great!
                            I'm holding out for a custom rom, hopefully not much longer
                              With proper wifi/bt drivers it's going to be sufficient for me at least for now. Some nice custom rom would be great though.
