Q7 Rk3188 Device - What Works & Help Please?
Originally posted by hackadroid View Post
So, I actually have a dump of my box and have dug through it. The whole rom would work great but it needs that patch for the VSync. I am trying to get enough time to build a custom kernel but I am still learning how to incorporate drivers from image dumps. Until now I have only done builds with board configs already built. If anyone out there has some input, I could try and crank this out in the next week or so.
Originally posted by wazzuperz123 View PostSo, I actually have a dump of my box and have dug through it. The whole rom would work great but it needs that patch for the VSync. I am trying to get enough time to build a custom kernel but I am still learning how to incorporate drivers from image dumps. Until now I have only done builds with board configs already built. If anyone out there has some input, I could try and crank this out in the next week or so.
Originally posted by wazzuperz123 View PostI have a device that looks like the image below and seems to have a lot of similarities as other devices : I will update this post with exact chipset info as I have it in another location. I wanted to contribute as after a LOT of digging and trying things, this forum has by far helped me the most!
CHIPS INSIDE
WLAN: RTL8188
LAN: RTL8201F
Bluetooth: Mediatek MT6622
Back of Device / Board Print all specify the "Q7" or "XT-Q7-V10". I have dug into these forums trying to match any print from the board or model and have found nothing so far.
Getting Perfect Playback on 1080p & 720p MKV :
Full Flash - K-R42 Hybrid Firmware (HFW) 3.2 by lewy20041 Firmware
Flash Kernel Only From - K-R42 firmware by wasser 1.2.3
As far as I can tell the 1.2.3 kernel from wasser has the stutter video fix - 1.2.4 does not
With these wifi / bluetooth / Blue Button do not work but USB / Wired Do
I have also dumped the original firmware from the box including kernel, which if flashed has all the drivers to make everything work, however, I loose the video stutter fix. I tried the patch the kernel with the rkpatchomatic which gave no errors and was successful. When flashed it did not boot though. I tried a couple times to make sure and had the same result every time.
I was wondering if someone here could possibly patch the kernel or build a kernel with the patch if all chipsets were specified.
Thanks again for all the contributions from everyone who has helped me get my device working so good already!
I have the same q7 your
attempt to change the recovery but I can not.
get your change?
you completely worked wasser 124 rom?
thanks
Hey Miss, you have to restore with the original firmware above. Everything should work except xbmc will have a lag. I used the rkpatchomatic tool to patch the kernel and remove the frame skip. It will have to be unpacked though to get to the kernel. You can use RKtools to get at it. I am away from the location now. I'll try and upload it once have access.
Oh, you can flash that image with the tool in lewi's rom i believe. just select your downloaded image instead of his. I think wasser has the individual flash tool to flash individual partitions like kernel only or system only. Like I said though, you will have to unpack the image above with rktools to see the separate files.
Originally posted by wazzuperz123 View PostHey Miss, you have to restore with the original firmware above. Everything should work except xbmc will have a lag. I used the rkpatchomatic tool to patch the kernel and remove the frame skip. It will have to be unpacked though to get to the kernel. You can use RKtools to get at it. I am away from the location now. I'll try and upload it once have access.
I think I'll wait that you upload rom, thank you very much
Get a new firmware for Q7 TV BOX, will upload and share with you guys.
and try the beyond xbmc on Q7, it is the best xbmc version we have tested.Looking for developers
FOR Q7 tv box, new firmware is here:
it's built in a XBMC version,however,i test it, no good as beyond xbmc. still recommend to use Beyond xbmc on this q7 tv box.Looking for developers
There are currently 3427 users online. 1 members and 3426 guests.
