Q7 Rk3188 Device - What Works & Help Please?
Hi all from Ukraine. Thank you so much for geekbuying firmware, wazzuperz123 for the theme. Firmware helped. There were problems with the micro sd card and yusb. While everything is OK. This firmware Root or not? If not, how to get Root. Thank you very much.
Understood. No Root.Last edited by berlser; 09 March 2014, 09:00.
picuntu on the q7
Originally posted by geekbuying View PostFOR Q7 tv box, new firmware is here:
it's built in a XBMC version,however,i test it, no good as beyond xbmc. still recommend to use Beyond xbmc on this q7 tv box.
I have a q7 and tried to install picuntu 4.5 on it using the rk android application under windows xp ...
the binary ran ok but failed to identify the q7 device which was connected via a usb connector to the otg port on the
q7.
I can put the q7 into the android bootloader by pressing the reset button whilst turning it on ...
there is an option to boot .. or to flash the internal ram using the micro sd card port ..but I am not sure how to configure
the files put onto the sc card to make this work ... is all this documented somewhere ...
I think I would like to use this method to load up picuntu
SGP
Originally posted by berlser View PostHi all from Ukraine. Thank you so much for geekbuying firmware, wazzuperz123 for the theme. Firmware helped. There were problems with the micro sd card and yusb. While everything is OK. This firmware Root or not? If not, how to get Root. Thank you very much.
Does the follwoing post help you?
Originally posted by johnsnow5440STOCK FIRMWARES:
Just want to share this... Thanks to Geekbuying for the firmwares
Password: geekbuying.com
Software for installing (comes with usb drivers that will be installed)
Download
ROOTING THE CS918S
Watch this video to know how to root your CS918S. Although it says on the video how to root CS968, it works both ways with any RK3188 devices so CS918S works.
http://www.youtube.com/watch?v=x7DklxNTTzQ
Originally posted by berlser View PostHi! This method did not help me.
I then followed the instructions in the video below, using the files in the download below also.
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
If the software does not recognise your device after following the instructions in the video, check your drivers.
Originally posted by jimbo68 View PostI first installed the firmware below - the latest stock firmware
All right. I have a Root. Install the driver http://blog.geekbuying.com/index.php.../#.Ux7f-j9_uSp
ThanksLast edited by berlser; 11 March 2014, 11:46.
I have the above board. Does someone regonice the version I have. See this link for more information of the devise. http://m.dhgate.com/product/cs918-bl...13.html#pd-103
Hi. I have a problem with the micro sd card. At full power OFF Q7 XT-Q7-V10. After switching dies sd card. You need to format it on the PC. Wi fi is not working. Firmware http://www.mediafire.com/download/q1...1_20140227.zip Remote control does not work. Have someone else this problem ?
There are currently 1931 users online. 0 members and 1931 guests.
