Their is a NEW "VideoMix-2 App" just released, that can be found in the right hand column in the bottom blue link download section HERE https://plus.google.com/communities/...artnerid=gplp0 .....
The NEW latest "ShowBox App", it has all the latest Movies, TV Episodes and TV Series ... DOWNLOAD "SHOWBOX" HERE http://www.mediafire.com/download/qm...do.showbox.apk
The NEW Upscale "Video Mix" App (BUILT IN) Even Has It's On Video Resolution Quality Settings (1080p/720p ..ect), This Is What Makes It Truly Upscale[/B] ...
"BeYond XBMC Update Again To V3.1
"Beyond XBMX" NEW thread is HERE http://www.freaktab.com/showthread.p...d-XBMC-(Beta-3) ....
The New Ultimate Upscale "Video Mix" App in the above photo (Built IN 720p/1080p Settings) and the NEW "Beyond XBMC"
TOGETHER on the very same Android 4.2/4.3/4.4 TV Box is the Ultimate Dream Team of TV Entertainment ...
*ALL NEW, the ("PRE-ROOTED, LibMedia.so Hack Ready, OpenVPN Ready") CR11S-CS968 1080p GT-19300 (G3 Spoofed) 2MP/5MP 6210 ROM BUILD, "BeYond XBMC" READY is now ready for download HERE
*2MP CR11S-CS968 Version Pre-Rooted HERE | http://www.sendspace.com/file/n6gtjx |
*8188 CS968 (Wifi Works) Pre-Rooted
Get the NEW ROOTED 8188_GT-19300_htc_t018_public_Mtk_20140127 HERE http://www.sendspace.com/file/4z0woo ....
*TV01 CS968 Pre-Rooted HERE http://www.sendspace.com/file/wtby9s ....
This ROM has the NEW UPSCALE (Built IN NEW Video Mix App) and designed to work with the NEW "Beyond XBMC", NO MXPlayer needed ... The "Beyond XBMC is packing on steroids powerful (StageFright) 4K like video playback, see above photo ....
*You can get the "Beyond XBMC" Downloads*
Beyond XBMC Beta 2.9 (GT-I9300) (Spoofed as a Galaxy S3)
HERE http://www.freaktab.com/showthread.php?9603-Beyond-XBMC .... Thanks to our very own "Flumpster" ...!
*PLEASE NOTE: To make the icons larger, set the icons to 240 ONLY using the Built IN "texdroider_dpi" App and reboot ....
*PLEASE NOTE: This ROM Build also has a built IN "Cache Cleaner" App, go to "Setting", check mark ALL THE BLOCKS ... Set the "Auto Clear Interval" to one (1) Hour ... This Setting will auto clean your Android TV box every hour ... Also set your "Language" ....!
*PLEASE NOTE: If you want more popular XBMC "JUST UPDATED" (Channels) add-ons zip files go HERE https://plus.google.com/communities/...artnerid=gplp0 ... The add-ons zip files download is located in the right column bottom blue links section ...
